hein weijers
hein weijers
The Netherlands..
Egbert JAS, turflok, Carl Courson, Roddy Walsh, Mark Creighton
10779 Registered Users
franko 133
NickL 61
DavidP 59
MarcB 51
950,455 mail-order LSR
Topics67,525
Posts675,891
Members10,779
56 registered members (Adam M.), 377 guests, and 805 spiders.
A10 dynamo belt drive #764499 02/04/19 6:35 pm
MikeG Offline OP
Wondering if anyone has any experience with this belt drive and voltage regulator? I was all set to order an SRM drive till I read that even with the belt they still want the cavity packed with grease, something that I would like to avoid.
http://dynamoregulators.com/drive-belt-kit.php
1960 BSA A10
2007 Suzuki Bandit
1957 A10
(Used to be a Triumph here)
71 Norton Commando
17 Triumph Bonneville
Re: A10 dynamo belt drive [Re: MikeG] #764517 02/04/19 8:47 pm
chaterlea25 Offline
Hi Mike,
Lots of people have run the SRM setup dry,
mine was run dry for several years without problems, I added some grease the last time I had the cover off
Its supposed to aid cooling,
The worst thing you can do is run the belt too tight, the dynamo tends to rotate tightening the belt as the strap is tightened
I use a small clamp to pull the dynamo housing lip against the inner timing case and then tighten the strap,
Belt needs to be able to twist 90 degrees easily when all clamped up
Dynamo regulators unit uses a wider belt than the original SRM , that said I am still running the first belt that came with the kit, probably 20k miles on it
Re: A10 dynamo belt drive [Re: MikeG] #764524 02/04/19 9:38 pm
MikeG Offline OP
Thanks John:
I had some grease migration from the drive cavity into the oil pump area. Not much and due to bad sealing on the gasket but I'd still prefer to run the belt dry.
1960 BSA A10
2007 Suzuki Bandit
1957 A10
71 Norton Commando
