Shadrach
Shadrach
Maryland
65 registered members (AML), 460 guests, and 498 spiders.
matg80s, Al Anderson, John Billerbeck, JMOnTwoWheels, SteveCompton
10572 Registered Users
franko 96
NickL 68
809,666 mail-order LSR
Topics67,467
Posts668,991
Members10,572
Wassell Hepolite BSA A65 piston broke #764297
02/02/19 8:48 pm
02/02/19 8:48 pm
England
Servodyne Offline OP
England
Hello all.
A cautionary tale about the 'genuine' Hepolite pistons being sold by Wassell for our classic British bikes.
I bought my 71 BSA Firebird from a chap who'd done a partial restoration including new pistons, fitted into newly +20 re-bored barrels. I rode the bike quite vigorously over a 4 year period whilst carrying out further restoration to other parts of the bike, including chrome, paintwork and various upgrades. I had covered around 18000 miles when I was throttling down to about 50mph and all hell let loose inside the engine. I immediately pulled the clutch and coasted to a standstill. After getting the Firebird home and lifting the head, I discovered something seriously amiss with the pistons being at different heights and one being turned though 90 deg. On removal of the barrel, one piston came with it and it's conrod was still carrying the gudgeon pin and the remains of one gudgeon pin boss.
The piston had failed in spectacular fashion with both gudgeon pin bosses being ripped out of the piston skirt. Luckily there was no damage to the conrod and only a small crack to the barrel skirt. I showed the piston to several dealers who supply 'Hepolite' pistons, to ask if they had ever seen anything like it, which they hadn't. There's no evidence of the piston seizing or of any pre-ignition. It's as though the gudgeon pin bosses in the piston just decided to let go. If you look at the 'good' piston, you can see at the intersection where the boss meets the skirt, that it's quite a sharp corner whereas a genuine genuine Hepolite or BSA piston they have a generous blend radius. I can only assume that this is a weak spot that could be prone to fatigue failure.
It would be interesting to know weather anyone else has had a similar issue with these 'Genuine' pistons.
1957 BSA A10 Spitfire
1971 BSA A65 Firebird
1971 BSA A70 Lightning
1975 Norton Commando
1961 Norton 99
Re: Wassell Hepolite BSA A65 piston broke [Re: Servodyne] #764305
02/02/19 9:49 pm
02/02/19 9:49 pm
The pin looks a bit blue. You may be hasty to exclude detonation as a cause.
The Taiwanese pistons are at least as good as the originals.
Re: Wassell Hepolite BSA A65 piston broke [Re: Servodyne] #764318
02/02/19 11:54 pm
02/02/19 11:54 pm
Aus
NickL Offline
NickL  Offline
Aus
They don't look like JCC pistons which are the current 'hepolite' branded ones.
Did wassell sell other types branded as hepolite at any time?
I've used quite a few JCC with no problems although i was very sceptical at first.
j
Bring in the 'Comfy Chair'
Re: Wassell Hepolite BSA A65 piston broke [Re: Servodyne] #764359
02/03/19 9:17 am
02/03/19 9:17 am
Duesseldorf/Germany
Phil in Germany Offline
Duesseldorf/Germany
Hmmmm....
The piston might be made by JCC although it visually differs from the latest ones I had in hands.
Have you looked at the piston's inside? Usually there is a manufacturer's marking cast in.
The one pictured is made byJCC and marked accordingly although it is a +.060".
But I have never had any issue with JCC-pistons. I would not discard the detonation issue either looking at the gudgeon pin's colour.
Cheers!
Ph.
Best regards
Phil
Duesseldorf/Germany
'56 DB 34
'62 A 65 Star (disassembled)
'69 A 65 Lightning
'71 A 65 Firebird
'75 T 160
'84 Yamaha SR 500
Re: Wassell Hepolite BSA A65 piston broke [Re: Servodyne] #764361
02/03/19 11:02 am
02/03/19 11:02 am
England
England
They are JCC. You can just make it out in the photo. Also the bluing on the original photos is down to using a flash and it doesn't look like the pistons have been running unduly hot. If fact the good piston looks like it had been running quite happily.
What I don't like about these pistons is the way the ends of the gudgeon pin coincides almost exactly with the 90 deg transition from the gudgeon pin boss to the skirt.
I've actually rebuilt the Firebird now and have again used the same type of piston because there aren't many alternatives, but I'm wondering if the same thing might happen again or whether it was a one off!
1961 Norton 99
Re: Wassell Hepolite BSA A65 piston broke [Re: Servodyne] #764363
02/03/19 11:41 am
02/03/19 11:41 am
Duesseldorf/Germany
Duesseldorf/Germany
I do sincerely hope your piston failure was a one-off.
And yes indeed., piston alternatives are not that readily available for an A 65. Either you go for JP which are quite heavy or you go for GPM which have a reputation for expanding a tad more than JCCs or AE Hepolites if you can get hold of them and are prepared to spend a fortune.
When rebuilding my own '71 Firebird I had heated my shop oven and measured the heat expansions of AE Hepolites and JCCs (delivered in a Cyclecraft cardboard box). Since then I am quite aware why I get my barrels honed for JCCs with 12/100 mm clearance, whilst the AE Hepolite could work with 10/100 mm. Unfortunately I did not have a GPM or JP at hand back then.
Cheers!
Ph.
Best regards
Phil
Duesseldorf/Germany
'56 DB 34
'69 A 65 Lightning
'71 A 65 Firebird
'75 T 160
'84 Yamaha SR 500
Re: Wassell Hepolite BSA A65 piston broke [Re: Servodyne] #764370
02/03/19 1:52 pm
02/03/19 1:52 pm
I don’t know what made your piston do that, but there are processes that put stresses on pistons, that they are not made for.
Detonation is the obvious one, but that sort of carnage is not usually the first symptom. Certainly worth checking mixture and timing on both cylinders after the repair though. You may have bent the conrod.
Another thing the pin bosses don’t like is the hammering effect of loose rod bearings.
Of course a flaw in the piston could have caused a crack to start and grow, but flaws in these pistons seem to be rare. Detonation and Unit BSA big end problems are not rare.
Re: Wassell Hepolite BSA A65 piston broke [Re: triton thrasher] #764391
02/03/19 5:38 pm
02/03/19 5:38 pm
England
England
Funny you should mention this. The serviceable piston that I took out had to be heated up to remove the gudgeon pin. The gudgeon pins in the new Hepolite pistons were as easy push in fit cold which surprised me. It would be interesting to know what brought about this change in fit. The new pistons also came with Hastings rings which look to be a big improvement over the ones I took out.
1961 Norton 99
Re: Wassell Hepolite BSA A65 piston broke [Re: Servodyne] #764395
02/03/19 6:07 pm
02/03/19 6:07 pm
A cold push fit is satisfactory, as is a fit that requires the piston to be heated.
The dimensional difference is miniscule.
Re: Wassell Hepolite BSA A65 piston broke [Re: Servodyne] #764399
02/03/19 6:26 pm
02/03/19 6:26 pm
Monclova
sloppyoil Offline
sloppyoil  Offline
Monclova
Cir clip probably broke or was not fitted correct. Just a guess but have seen that before, makes a mess so you don't know exactly.
Re: Wassell Hepolite BSA A65 piston broke [Re: sloppyoil] #764400
02/03/19 6:36 pm
02/03/19 6:36 pm
England
England
One circlip was still in the piston and the other was intact at the bottom of the engine with all the other shrapnel. It doesn't look like it came outwards from the piston as there's no damage to the cylinder bore. Mystery?
Of the one you have seen before was it a Wassell piston?
1961 Norton 99
Re: Wassell Hepolite BSA A65 piston broke [Re: Servodyne] #764401
02/03/19 6:37 pm
02/03/19 6:37 pm
Monclova
sloppyoil Offline
sloppyoil  Offline
Monclova
Or were the clips still in the piston?
Re: Wassell Hepolite BSA A65 piston broke [Re: Servodyne] #764404
02/03/19 6:38 pm
02/03/19 6:38 pm
West Yorkshire
West Yorkshire
Ed V in Vermont USA supplies JE pistons, they are about the best you’ll find. You also find quite a few NOS Hepolite Powermax pistons around on eBay.
The underside of the piston is showing a bit of baked on oil. Probably a tad too lean at the top end?
Re: Wassell Hepolite BSA A65 piston broke [Re: Servodyne] #764419
02/03/19 8:19 pm
02/03/19 8:19 pm
Monclova
sloppyoil Offline
sloppyoil  Offline
Monclova
I believe they were Japanese knock offs. However the cir clip gave way on that one. Sounds like a crack in the pin boss area. No way to know unless your in the habit of zyglowing the pistons before re assembly. A practice I do on older hemis and hi po engines if re using. Always found at least two pistons with cracks in those areas especially on the hemis. reason? Unknown, or due to age and heat cycles.
