Dick Harris
Dick Harris
East Bethany New York
Leninovich, Mje, Hans Morten, Randy Schneider, Ian Thomas
10708 Registered Users
franko 125
DavidP 49
quinten 41
NickL 41
901,093 mail-order LSR
Topics66,912
Posts671,149
Members10,708
58 registered members (allen_m56), 318 guests, and 851 spiders.
B25 Fork internal upgrade. #764223
02/01/19 10:36 pm
02/01/19 10:36 pm
Canada
Alexp Offline OP
Alexp  Offline OP
Canada
Hi all. I want to upgrade the internals of the 1970 b25 fork, but would like to keep the stock appearance. Is there a kit available? If not, give me your tips and tricks! I’m looking for something that won’t dive under braking, and is a bit more sporty! Is this as simple as a spring rate change? Or is there more to it?
Thanks in advance!
Alex
Re: B25 Fork internal upgrade. [Re: Alexp] #764225
02/01/19 11:16 pm
02/01/19 11:16 pm
ca, us
DMadigan Offline
DMadigan  Offline
ca, us
I am not familiar with the internals of these but how fast it compresses is damping, how far is spring.
Re: B25 Fork internal upgrade. [Re: Alexp] #764231
02/02/19 12:10 am
02/02/19 12:10 am
Canada
Alexp Offline OP
Alexp  Offline OP
Canada
Hey DMagidan! I’ve got that part! I come from downhill bicycle racing where suspension setup was everything. I’m looking to upgrade my rear shocks ASAP, but would like to focus on my fork. Is anyone making a kit that allows me to adjust compression dampening, rebound, rebound dampening etc on the fly using click dials in the top of the stanchion? I’ve searched everywhere with no luck, but hoping someone here has a hidden gem I haven’t seen!
Alex
Re: B25 Fork internal upgrade. [Re: Alexp] #764234
02/02/19 12:26 am
02/02/19 12:26 am
gavin eisler Online content
gavin eisler  Online Content
Softer springs, BSA catered for two up riders
Re: B25 Fork internal upgrade. [Re: Alexp] #764235
02/02/19 12:28 am
02/02/19 12:28 am
That wont help the brake dive, speak to "Kommando" about dampers. use the PM.He sorted out my 71 A65 forks with trick dampers, Hi and Low speed.
Re: B25 Fork internal upgrade. [Re: Alexp] #764243
02/02/19 1:20 am
02/02/19 1:20 am
Canada
Alexp Offline OP
Alexp  Offline OP
Canada
Thank you Gavin!!!
Alex
Re: B25 Fork internal upgrade. [Re: Alexp] #764258
02/02/19 9:27 am
02/02/19 9:27 am
kommando Offline
kommando  Offline
Your springs are probably old and saggy, also due in 70 they switched to a lighter spring due to complaints about too stiff a spring. I prefer the weaker spring but not an old saggy one.
On the damping go for a thicker oil to increase damping, that will still leave you with the issue of the valve giving no damping during its movement from compression to rebound and back. You feel this as a vague feeling on flat roads as the valves repeatedly moved position but not enough to start damping. Only cure to that is completely different internals.
Re: B25 Fork internal upgrade. [Re: Alexp] #764260
02/02/19 10:10 am
02/02/19 10:10 am
West Yorkshire
West Yorkshire
My 68’ forks are different as they have damper rods, but I rebuilt them completely and changed everything inside also fitted progressive springs and the change was night and day. I tried a few different type of dampers before and all helped but non were as good as it is now. Before i had to shift my weight off the front wheel when going over speed bumps to reduce the pogo effect, now it glides over them.
As the actual damper rod wasn’t available to buy and mine was all pitted from corrosion. I bought some drill rod and turned them to size on the lathe.
For the rears I fitted NJB ultimate shocks. Far superior to the Hagons for a similar cost.
Back to topic though, I’ve ridden an A65 with the later triumph shocks and they were pretty sweet (same on a rocket 3 were not so and dived under braking) so possibly just a rebuild with some decent springs would sort our problem.
Re: B25 Fork internal upgrade. [Re: Alexp] #764263
02/02/19 12:20 pm
02/02/19 12:20 pm
Canada
Alexp Offline OP
Alexp  Offline OP
Canada
Thank you everyone!
Kommando, that’s what I want to do. Get all new internals. And Alan, that’s fantastic!thats exactly what i want to do, but i don’t have a lathe to turn my own rods. Would like to pick both your brains on something I can put together to make my front end fantastic.
I’m going to definitely be adding a heavier weight oil to the fork, but I want new springs, dampening rods etc. Basically I would like a racier setup to make it corner nicer, as well as being able to handle low speed bumps (speed bumps in parking lots etc), better. I want more tyre contact to the pavement basically.
Thanks!
Alex
Alex.
Re: B25 Fork internal upgrade. [Re: Alexp] #764265
02/02/19 12:37 pm
02/02/19 12:37 pm
kommando Offline
kommando  Offline
You cannot have both racier at speed (high damping force at low speed fork defections) and being able to handle large bumps at slow speeds (low damping force at high speed deflections) without going for modern shim stacked cartridge inserts. None are available off the shelf and you need access to a lathe and precision bore steel tube to adapt them to fit. Otherwise you can only choose racier or supermarket bumps and optimise for one.
Re: B25 Fork internal upgrade. [Re: Alexp] #764322
02/03/19 12:41 am
02/03/19 12:41 am
Canada
Alexp Offline OP
Alexp  Offline OP
Canada
Racier it is....
Alex
Re: B25 Fork internal upgrade. [Re: Alexp] #764409
02/03/19 7:10 pm
02/03/19 7:10 pm
West Yorkshire
West Yorkshire
The <68 type on mine uses the rods which yours won’t use. However the triumph forms which yours should have work really well when built properly.
Kommando knows a lot about shocks so I wouldn’t take anything he says with a pinch of salt, with mine I just rebuilt everything with a keen eye. The progressive fork springs were a good buy in my opinion and I think help with the varied deflection high and low. But as long as you have them so they are pretty smooth on the road, the rest is down to riding, it’ll never handle like a modern bike but that’s most of the fun.
Re: B25 Fork internal upgrade. [Re: Alexp] #764439
02/03/19 10:45 pm
02/03/19 10:45 pm
Canada
Alexp Offline OP
Alexp  Offline OP
Canada
That is absolutely half the fun of it!!! I think I’m going to do progressive springs, a heavier weight oil, and trial and error it as much as I can. Will be my project next weekend!!! And I agree about Kommando. I don’t take anything he says lightly. I’m here to learn, and I know when to shut my trap and listen!
Cheers!
Alex
Re: B25 Fork internal upgrade. [Re: Alexp] #764480
02/04/19 1:19 pm
02/04/19 1:19 pm
kommando Offline
kommando  Offline
Both the BSA rod damper and Triumph's shuttle valve achieve the same end result but with different parts, they both suffer from no damping when moving between the 2 positions. The valves 2 positions giving 2 different damping rates, you can change the damping rates by using different viscosity oil which will affect both rates equally or you can change the holes/clearances on one valve position to change that damping rate alone. First however you need to set your static sag, so with you on the bike and off the center stand the front suspension should only use up 1/6 of it, more than that and you risk bottoming out. Plastic drain pipe makes a good spacer to increase the preload on the spring and decrease the sag.
