The Bonneville Shop
KC in S.B.
KC in S.B.
Santa Barbara, California
36 registered members (Bodie), 246 guests, and 381 spiders.
SuzyTice, Steve Funke, JD8, John Rowley, Zoot
10531 Registered Users
franko 92
Lannis 80
NickL 68
787,674 mail-order LSR
Topics69,242
Posts674,479
Members10,531
Re: 1970 A65 Clutch Activator #762477
01/13/19 9:44 pm
01/13/19 9:44 pm
London, UK
Ianbuck Offline OP
Ianbuck  Offline OP
London, UK
Just installed a new SRM clutch (The old one was knackered), I also filtered their aluminium billet pressure plate and release bearing. The problem I'm now having is the 1970 (Triumph) style lift mechanism isn't working properly (if it ever did?).
There is a loud knocking (clicking) noise coming from the lifter with the vibration felt though the calble and bar lever, as it reaches the end of its pull. I assume this is from the ball bearings in the lifter not rolling in unison.
The lever side of the lifter looks to be is good condition, however the fixed thrust plate side was a bit pitted. I cleaned the ball bearing indents with a round grinding stone, and they are now quite smooth. I also initially used a light oil to lubricate the mechanism as this was recommended for a smoother operation, but i have also tried a general purpose grease, with only a slight improvement.
Is there anything else I can try before sourcing replacement parts, assuming they are readily available?
Would shaping the ball bearing pockets on the thrust plate side, making them a slightly oval to introduce a longer ramp help? It would have to be done by eye with a dremel, so would not be super precise. Or would this interfere with the return action of the lifter?
Any advice would be appreciated.
Ian
Re: 1970 A65 Clutch Activator [Re: Ianbuck] #762479
01/13/19 10:05 pm
01/13/19 10:05 pm
Aus
NickL Offline
NickL  Offline
Aus
The clicking noise is quite a common thing, it's normally due to the actuator mechanism being adjusted
too far out by the cable. Try stating from scratch, back the cable off, adjust the clutch centre nut,
then re-adjust the cable.
How much did you cut off the pushrod when you fitted the srm pressure plate? It may be if you removed too
much then the rod may need cutting in half and a small ball bearing put in the centre.
Bring in the 'Comfy Chair'
Re: 1970 A65 Clutch Activator [Re: Ianbuck] #762486
01/13/19 10:51 pm
01/13/19 10:51 pm
London, UK
Ianbuck Offline OP
Ianbuck  Offline OP
London, UK
Trying to work out how much to cut off was quite difficult to judge, but after much measuring I cut off 33mm (1-1/8ins). I've adjusted the free play at the clutch centre (1/4 turn) and I still have a bit of free play left at the lever. I'll try adding a small shim in the end of the lifter shalf tomorrow. Too cold in the garage now 😨
Thanks for that suggestion Nick.
Ian
Re: 1970 A65 Clutch Activator [Re: Ianbuck] #762495
01/13/19 11:34 pm
01/13/19 11:34 pm
Aus
NickL Offline
NickL  Offline
Aus
Looking at that photo it seems like the ball bearing in the lifter is a bit big, the pushrod
should sit into the mech a little and be able to rotate. what size is that ball?
Re: 1970 A65 Clutch Activator [Re: Ianbuck] #762496
01/14/19 12:04 am
01/14/19 12:04 am
London, UK
Ianbuck Offline OP
Ianbuck  Offline OP
London, UK
Yeah your spot on there Nick, that photo is a bit old. I dug that one out and found the flat end of the original ball bearing below it. I have since replaced it with one of the correct size.
Re: 1970 A65 Clutch Activator [Re: Ianbuck] #762530
01/14/19 11:41 am
01/14/19 11:41 am
gavin eisler Offline
IME The "click" is caused by the balls going over the top of the ramps, what Nickl says,start from scratch, slack cable, leave a half turn of play at the centre adjuster,leave generous slack at the cable end, should now operate OK. None of this is helped by the clutch bar lever, most repops have a larger 1 1/8" centre distance from pivot to nipple, this over pulls the mech, original levers were only 7/8* on this critical dimension. if you have a lever with the larger distance leave enough slack to stop it over pulling the 3 ball mech.
Re: 1970 A65 Clutch Activator [Re: Ianbuck] #762598
01/14/19 9:50 pm
01/14/19 9:50 pm
London, UK
Ianbuck Offline OP
Ianbuck  Offline OP
London, UK
Just had a measure up on the levers. The levers that came with the bike were not original, but they do have a 7/8" pivot distance. I'm sure I wasn't getting this problem with those levers.
However, in my desire to give the bike a clubman style make-over, I've fitted Ace Bars and a set of repro Doherty type 200 alloy levers (Spirtfire style), and these do have a 1" pivot centre.
I've just given the cable more slack at lever adjuster and it has reduced the occurrence and ferocity of the clicking.
So i think you have solved that for me Gavin ..... Thanks. I'll refit the old lever tomorrow, to confirm.
However, I do like the alloy levers and I wonder if I could move the bolt over an 1/8" ? I would obviously need to get the pivot holes welded up ...... a future project ☺.
Ian
Re: 1970 A65 Clutch Activator [Re: Ianbuck] #762602
01/14/19 10:36 pm
01/14/19 10:36 pm
"repro Doherty type 200 alloy levers (Spirtfire style), and these do have a 1" pivot centre. "
great to look at , horrible to use.Possibly the least ergonomic levers ever made. Unless you have pickpockets fingers.
Make sure the 3 ball ramp mech is lubed well, I like to use black bearing grease here, the stuff with Moly in it.
Re: 1970 A65 Clutch Activator [Re: Ianbuck] #762983
01/19/19 8:33 pm
01/19/19 8:33 pm
London, UK
Ianbuck Offline OP
Ianbuck  Offline OP
London, UK
Reporting progress.
I've just solved the clicking ball bearings in my lifter mechanism. As mentioned above the problem is a result of too much rotation of the moving half of the lifter. This raises the ball bearings to the top of the retention cups ramps (pressed into the mechanism plates) and causes one of the balls to slip and produce a loud clicking noise.
Firstly checked the length of my shortened clutch push rod (to suit the new style SRM clutch pressure plate) and I have the rod spot on, which is pleasing to know. Just got to harden the cut end now.
I found slackening the cable tension in the Doherty lever did reduce the frequency and severity of the clicking, but the amount of cable free play was too much and I couldn't live with that.
So I refitted the original clutch lever ( 7/8" pivot/nipple dimension) and it still produced the clicking noise, and also required a slack cable. However, a bit less slack than the Doherty lever, but it still looked untidy.
I removed the lifter mechanism, took it apart and using a mini sanding drum ( in a dremel ) I polished and slightly elongated the ball bearing ramps on the fixed bottom plate of the lifter. I got a really nice smooth surface finish.
I then used a moly based grease as Gavin suggested, refitted the Doherty lever and to my amazement I now have a completely silent clutch lifter, with nominal free play at the lever.
I have to say I really like these Doherty type 200 levers, I take a M/L glove and don't consider my hands to be small. I find the reach is just about right.
Happy Days
Ian
Re: 1970 A65 Clutch Activator [Re: Ianbuck] #763049
01/20/19 7:31 pm
01/20/19 7:31 pm
West Yorkshire
West Yorkshire
After finding the same problems as yourself, I lubricate mine with nothing more than WD40, it never clicked after that and got full lift at the clutch.
Re: 1970 A65 Clutch Activator [Re: Ianbuck] #763062
01/20/19 9:24 pm
01/20/19 9:24 pm
London, UK
Ianbuck Offline OP
Ianbuck  Offline OP
London, UK
I tried a very light oil, but it would have been interesting to try WD40.
However, the fixed plate on my lifter was a bit pitted in the cups that hold the ball bearings, so they really needed a sanding to get them smooth. The moving plate looks like new, so it was probably replaced as some stage.
By polishing the cups I have only removed a tiny amount of material, so I am still able to dial in the required amount of free play and lift.
Any recommendations for a good low friction clutch cable supplier. ?
Ian
Re: 1970 A65 Clutch Activator [Re: Ianbuck] #763111
Yesterday at 02:01 PM
West Yorkshire
West Yorkshire
Mine was with a NOS part but agree about having the smooth ramp. At the time I kept diluting grease with WD40, I also wanted to make sure I had maximum lift, in the end I ended up with only the WD40. Something like Duck oil may have been good to try.
I always make my own cables using the venhill kits available. Although Venhill will supply a cable of standard or heavy duty (you want heavy duty for the front brake) if your making a few cables the bird cage tool is a good piece of kit to have.
If you are making your own, find the smoothest run possible before you cut anything, it will probably be a longer cable than stock but it will make for a much lighter clutch. Once you feel you have it right, cut the outer cable and place that in position, slide the inner cable through and check again it should slide through with zero drag.
Solder on the trumpet nipple for the ball ramp end, then use a soldier less nipple
On the lever end. This way you can adjust and be sure you have the right length before you start, then remove again, remove the nipple, slide over the solder nipple (and trumpet if it needs one) and use a solder pot to solder the cable in place (flux the cable first)
To make a solder pot,
I use a cheap stainless steel measuring cup from the kitchen.
Place in the cup a roll of plumbing grade solder (some have an element of silver in there) don’t use electrical solder, it won’t hold. Then place the cup over a camping stove, (or the kitchen hob if your brave) then place the fluxed cable into the pot, only as deep as the nipple/trumpet and long enough so that it stops bubbling. This will ensure full soldering of the cable.
