Another use for the 3D printer, a model of the chamber at TDC. This is the chamber of the A74 (80 x 74mm) head with the 7mm stem Subaru valves.
Not obvious is the squish band around the bottom edge to match the piston. I can measure the volume of this and compare to the CAM solid model for an accurate compression ratio.
