Excalibur
Excalibur
New Zealand
Page 4 of 4 1 2 3 4
Re: new engine
Whisper #758649 12/09/18 1:47 am
Online Sleepy
Originally Posted by Whisper
I trust that you wore some heat-proof gloves when you pushed the bearing out with your fingers at 200 degrees :-)
Ha, I said that I COULD have pushed it out with my fingers! I actually used a shouldered drift that I had a machine shop make for me. I just about got the drift in place and was getting ready to tap it with a hammer when the bearing essentially fell out. The drift was a bit more useful when it came to installing the new bearing.
Re: new engine
lemans #758775 12/10/18 1:20 pm
Originally Posted by lemans
as I was rather pissed of by photobucket's ransom actions already one year ago, I decided to move forward with a raspberry-pi webserver. took some time but this is the result.
tadaaa. a server with my own pictures.
as the chris-crank is of no use yet (not without extensive modifications) I reverted to the tested 360-degree setup (had to, damn)
J.Hill alloy barrel
5-speed gearbox
newby belt
progress is being made
regards A
Probably the best solution for now, I have been discussing it with Mark at PES (CCM Britain, and the maker of Johns 5 speed box) He may be tempted to make an offset crank but will need a few bits to make one against I should imagine.
SRM are now selling an offset crank... However it is (and is advertised as) one of the Norish cranks...
On the Newby belt kit, give Bob a ring and he may machine you a clutch centre to suit the splined mainshaft.
Re: new engine
lemans #758870 12/11/18 3:13 am
Online Sleepy
if referring to the torrington inside the gearbox, a std heatgun and a screwdriver did the trick, no injuries sustained
if referring to the crankshaft timing side bush, applied brute force and again no injuries
but to assemble the needlerollerbearing inner race onto the crankshaft is a tricky operation.
apply heat with the heatgun, then pick up the very hot inner race and position it on the exact position on the crankshaft timing side stub.
and keep holding it in position and wait for the inner race to shrink
cool your fingers and observe position of inner race, repeat untill satisfied.
and yes I wore some gloves
regards A
Sorry for the confusion lemans, Whisper was responding to my post about changing out the high gear bearing on a T140.
Re: new engine
lemans #759202 12/13/18 9:13 pm
lemans Offline OP
some more pictures in random order
the ordered set of Allen bolts had a totally different thread (TPI was different as advertised) I decided to make my own. these are finished now with M6 at the other end
(no it is not to be a std bike)
made a suitable tool for the front sprocket nut. in the past a used a chisel as you can see. my welding ability is not that good but it works
engine as off today
Re: new engine
lemans #762089 01/09/19 7:29 pm
lemans Offline OP
did some work on the timing side cover off the engine today
drawing/designing/fitting of the ugly lump, the axial oil feed to the crankshaft
[Linked Image from 77.163.36.45]
now it has to be welded and drilled to accept the oil-feed
it is not as ugly/protruding as the previous setup but the cover won't fit, pity but then again the modification is obvious.
progress!!
maybe it will be finished this spring
Page 4 of 4 1 2 3 4
