Brian_Dallas_TX
Brian_Dallas_TX
Dallas, TX
Shorty, Tony Proasi, Motolab, rowcrop66, Roger Whittingham
10695 Registered Users
franko 134
NickL 49
895,595 mail-order LSR
Topics66,840
Posts670,562
Members10,695
60 registered members (998John), 365 guests, and 894 spiders.
Indian Fuel Tanks #761362
01/03/19 1:09 pm
01/03/19 1:09 pm
West Yorkshire
Allan Gill Offline OP
West Yorkshire
I have heard some good and bad reports about these in general, I have also seen some good and some bad tanks. Some I'd be happy to fit and some just completely poor in shape and size.
However has anyone yet fitted the OIF Export A65 tanks as seen on eBay?
Re: Indian Fuel Tanks [Re: Allan Gill] #761381
01/03/19 3:49 pm
01/03/19 3:49 pm
Illinois
Spitfire Ken Offline
Illinois
I HAVE NOT SEEN A OIF A65 EXPORT TANK BUT I WOULD EXPECT THE QUALITY TO BE HIT OR MISS LIKE THE REST OF THEM. I HAVE A REAL PROBLEM WITH THE WELDING BEING SO POOR THAT YOU MUST HAVE THE TANK SEALED TO MAKE SURE IT DOES NOT LEAK.
DOES ANYONE KNOW FOR SURE THAT THE SEALANTS CURRENTLY AVAILABLE WILL HOLD UP TO ETHENOL FOR AN EXTENDED PERIOD OF TIME SO YOU CAN SAFELY STORE THE BIKE WITH GAS IT.
The Devil is in the details.
1967 BSA A65 West Coast Hornet (under rstoration)
2001 Kawasaki W650
Re: Indian Fuel Tanks [Re: Allan Gill] #761387
01/03/19 4:42 pm
01/03/19 4:42 pm
kommando Offline
kommando  Offline
By sticking to the recommended sellers you should have a better chance, pummy.8081 has been selling the earlier 2 Gal A65 Spitfire tank and has had several good reviews on this site, so I assume he should be good on other tanks. There are too many Indian eBay sellers that pop up and then disappear once the feedback goes pear shaped, stick with the established ones with good feedback for a number of years,
Re: Indian Fuel Tanks [Re: Spitfire Ken] #761388
01/03/19 4:43 pm
01/03/19 4:43 pm
England
Servodyne Offline
Servodyne  Offline
England
I seriously looked at the export A65 OIF tanks for my A70 as I was getting totally disillusioned with the original BSA ones that kept leaking on the seams. I've got three factory export tanks and they all leak in exactly the same places around the top and bottom of the embellishment strip. The Indian ones appear to have welded seams whereas the BSA ones look like they may even be soldered, either way the original ones all seem to leak after a while and are very difficult to seal with sealant.
I ended up buying an Indian Mk2 Rocket 3 tank that BSA were seen to be experimenting with fitting to the OIF in the dying days of BSA. The central tunnel is made for the wide tube on the OIF but you need to weld on an extra bracket for the tank bolt as it's in a lower position.
I can't fault the quality so far. It fits perfectly and the welds and standard of chrome finish is very good. I'm also running a 57 A10 Spitfire with an Indian tank. Again it fits very good with very good welds, but the chrome finish is not perfect. Both tanks have sealant inside but I believe this was more as rust prevention than to stop them leaking, as some of the early Indian tanks were found to be horribly rusted inside when delivered.
So in summary, I wouldn't be put off buying an Indian tank, but I wouldn't just go for the cheapest because as you said the quality can vary.
1971 BSA A65 Firebird
1971 BSA A70 Lightning
1975 Norton Commando
1961 Norton 99
Re: Indian Fuel Tanks [Re: Spitfire Ken] #761400
01/03/19 6:04 pm
01/03/19 6:04 pm
Rich B Online happy
Rich B  Online Happy
I tried KBS Coatings tank sealer on a Bultaco fiberglass tank. It has worked quite well. The fiberglass tanks are the hardest to seal.
KBS is a thin urethane coating instead of the epoxy type coating a lot of others coatings are. The urethane will flex with the tank.
The KBS is a 3 step system of wash, etch, seal. You HAVE to follow the instructions to the letter, especially the part about times and rotation of the tank.
I am at the end of step 1 on an original M33 tank right now. Likely this weekend, the tank will get etched.
Re: Indian Fuel Tanks [Re: Allan Gill] #761413
01/03/19 7:55 pm
01/03/19 7:55 pm
gavin eisler Online content
gavin eisler  Online Content
@ Servodyne, thats a very good idea, using the MK2 rocket 3 tank, I like that, how does it marry with the front rubber buffers fitted to the OIF, or are they only needed for the larger bread bin ? Is there a gap at the seat , do the fuel taps play nice with the carb tops? I wouldnt mind fitting one of these.
I wouldnt be too picky about welding quality, I have a NOS BSA breadbin with some horrible welds underneath, on the other hand my Goldie pal tells me that some of the best Indian Goldie tanks are identifiable by their impressively neat welds , way better than BSA ,
Re: Indian Fuel Tanks [Re: Servodyne] #761414
01/03/19 8:13 pm
01/03/19 8:13 pm
Arlington, Massachusetts 02474
kurt fischer Offline
#irideslow
#irideslow
I ended up buying an Indian Mk2 Rocket 3 tank that BSA were seen to be experimenting with fitting to the OIF in the dying days of BSA. The central tunnel is made for the wide tube on the OIF but you need to weld on an extra bracket for the tank bolt as it's in a lower position. ...
Looks like an interesting option. Could you please provide a link or the name of the seller?
Kurt
1968-70-71 Triumph TR6R Bitsa - 1969 Triumph TR6R - 1971 BSA A65L - 1973 Triumph TR5T
1980 Suzuki GS1000G - 2005 Ducati Multistrada 1000S - 2012 Ducati Hypermotard 796 - 2014 Kawasaki ZX1000
Re: Indian Fuel Tanks [Re: kurt fischer] #761431
01/03/19 10:39 pm
01/03/19 10:39 pm
England
Servodyne Offline
Servodyne  Offline
England
I was recommended to buy from pummy.8081 at Royal crusaders but ended up buying a tank in chrome finish from US.VIDHI, as he had a respectable amount of positive feedback whilst being reasonable in price. As Kommando states, there are many indian ebayers selling a lot cheaper but have little on no feedback so you pays your money etc. I made the seller an offer and got mine for £240 inc postage but had to pay an extra £24 duty.
On the standard A65 export tank, I think I would actually prefer an Indian one for the reasons previously stated.
https://www.eBay.co.uk/itm/NEW-BSA-A75-MARK-2-CHROME-PETROL-FUEL-TANK-GUARANTEED-PRODUCT/253730209311?hash=item3b137fbe1f:g:hlgAAOSwKJlbPOPE:rk:1:pf:0
1961 Norton 99
Re: Indian Fuel Tanks [Re: Allan Gill] #761450
01/04/19 3:46 am
01/04/19 3:46 am
Maryborough Q.L.D.
mdodds Offline
mdodds  Offline
Maryborough Q.L.D.
Hello People. After my Mk11 Spitfire 2 gallon fibreglass began to delaminate due to old age, i purchased a Chrome and Red Firebird tank off Pummy.8081. Very pleased. All i had to do was run a tap through the fuel tap spigots to give a quick clean (1/4 BSP instead of the usual 3/8) Then the screw hole to mount the BSA badge wasn`t 2ba. Eventually ran a new intermediate 3mm metric course tap gently through. Perfect! Used the usual tank mounting rubbers underneath and modified a dommie tank rubber under the front one to set it straight and ensure it sits well away from any nasty vibration.The chrome and paint are excellent. Cheers from sunny QLD Australia.
Re: Indian Fuel Tanks [Re: Allan Gill] #761458
01/04/19 10:33 am
01/04/19 10:33 am
TripleTown Offline
TripleTown  Offline
While there are a lot of Indian traders selling tanks, the actual number of manufacturing sources is very limited, most originate from a particular family. The 'local market' buys up whatever can be produced, including 'seconds' and retails them on, with or without paint jobs/chrome plating etc
Over the years, there's been a wide range of feedback on the quality, and much of this stems from who actually made the tank in the first place. Tossing a coin stuff!
Re: Indian Fuel Tanks [Re: Servodyne] #761463
01/04/19 12:41 pm
01/04/19 12:41 pm
West Yorkshire
West Yorkshire
https://www.ebay.co.uk/itm/NEW-BSA-A75-MARK-2-CHROME-PETROL-FUEL-TANK-GUARANTEED-PRODUCT/253730209311?hash=item3b137fbe1f:g:hlgAAOSwKJlbPOPE:rk:1:pf:0
Just the info I needed, I beleive Gordon Grey used Pummy for his steel copy of the 68 Starfire tank.
This is what I would be looking at getting As you mention finding a decent 2 gallon tank becomes difficult also of late the prices being asked are a stupid amount and it could still need working on.
The plain steel finish doesn't show up the detail so Here it is in red
US.VIDHI looks to have the same supplier or at least the same photos
Red tank again
They are even listed as virtually the same title so I wonder if there is a closer connection.....
Re: Indian Fuel Tanks [Re: TripleTown] #761471
01/04/19 3:20 pm
01/04/19 3:20 pm
kommando Offline
kommando  Offline
That's my understanding too, a couple of makers but lots of sellers, the sellers buy various qualities with the cheapest being the rejects, they do not always repair the rejects before selling so cheapest is best avoided. They do like to haggle however which makes going by price alone difficult so reputation is best to go by.
Re: Indian Fuel Tanks [Re: Allan Gill] #761475
01/04/19 3:46 pm
01/04/19 3:46 pm
bon Offline
bon  Offline
I have had the misfortune over the years to buy some indian made tools and motorcycle spares. In variably they have been pure rubbish. I would not waste time or money on indian made stuff.
Re: Indian Fuel Tanks [Re: bon] #761476
01/04/19 3:53 pm
01/04/19 3:53 pm
West Yorkshire
West Yorkshire
I understand this statement, and a friend of mine has had to have a tank sealed because it leaked at one of the welds (been fine for all the many years since) however guaranteeing that a good second hand one is going to be as good is not easy and whilst I would have one repared the price of buying one in the first place is not worth considering.
Re: Indian Fuel Tanks [Re: Allan Gill] #761606
01/05/19 10:22 am
01/05/19 10:22 am
West Yorkshire
West Yorkshire
Do you have any photos Nick?
Re: Indian Fuel Tanks [Re: Allan Gill] #761633
01/05/19 4:19 pm
01/05/19 4:19 pm
bon Offline
bon  Offline
I remember buying an indian made single seat for a rigid frame triumph. The metal frame of the seat weighed about the same as the whole motorcycle frame, hugely heavy, and no matter what i did i could not stop the thing rusting. The springs, turned out to be mild steel, not springs at all, once they stretched, they stayed that way. Finally the cover turned out not to be leather, but some sort of bizarre plastic/paper/god knows what hybrid, that yes, also rotted in short order. An 80 year old english made seat picked up at a jumble, even though it needed restoring was in better condition.
Some of their stuff maybe good, but its a gamble, certainly if they got their materials and quality control together, they could really do well selling spares.
Re: Indian Fuel Tanks [Re: Allan Gill] #761691
01/06/19 1:32 am
01/06/19 1:32 am
Nick, happy new year, your tank pic, the fuel tap location, thats an improvement, on my T type the taps are much further back , that location looks a lot easier to work with. Good reflections. Thats a good deal I reckon. Gettin an old tank chromed would cost more in the UK
Re: Indian Fuel Tanks [Re: Allan Gill] #761696
01/06/19 2:22 am
01/06/19 2:22 am
I think there is method in the fuel tank madness, the front part is like a sump for debris, when reserve runs dry you put the front wheel up high and the float bowls fill, allowing slow forward progress, i dont use funny filters, have never lined the tank, or aggressively cleaned it. I drain stuff out of the float bowls once a year , their is rust , but its not a show stopper. i am a bit scared to stir that stuff up.
Re: Indian Fuel Tanks [Re: Allan Gill] #761782
01/06/19 11:59 pm
01/06/19 11:59 pm
San Luis Obispo, CA
Richard Phillips Offline
San Luis Obispo, CA
Can't seem to find this guy pummy.8081 at Royal crusaders any links
Richard
Re: Indian Fuel Tanks [Re: Richard Phillips] #761796
01/07/19 2:17 am
01/07/19 2:17 am
Jon W. Whitley Online content
Richard
FWIW,
https://www.ebay.com/usr/pummy.8081
I purchased my Spitfire/Hornet tank from pummy.8081 and it is identical to my original BSA fiberglass Spitfire/Hornet tank.
Re: Indian Fuel Tanks [Re: Jon W. Whitley] #761837
01/07/19 7:46 pm
01/07/19 7:46 pm
kelso scotland
Y
yosemite Offline
yosemite  Offline
Y
kelso scotland
Richard
FWIW,
seems to have stppped selling
Re: Indian Fuel Tanks [Re: Allan Gill] #761853
01/07/19 10:00 pm
01/07/19 10:00 pm
kommando Offline
kommando  Offline
Look on eBay.co.uk, definitely still there.
Re: Indian Fuel Tanks [Re: kommando] #761854
01/07/19 10:07 pm
01/07/19 10:07 pm
#irideslow
#irideslow
Originally Posted by kommando
Look on ebay.co.uk, definitely still there.
https://tinyurl.com/pummy-ebay-uk
Kurt
