65 registered members (AML),
460
guests, and 498
spiders. |
Key:
Admin,
Global Mod,
Mod
Topics67,467
Posts668,991
Members10,572
Most Online3,995 Feb 13th, 2017
Re: Fuel hose, clear plastic or black rubber
[Re: SidSnot]
#761285
01/02/19 8:29 pm
01/02/19 8:29 pm
Posts: 959 Farnham, Surrey, UK
gunner
Farnham, Surrey, UK
Unless you are really keen with originality, I would use Tygon fuel hose, which despite being a translucent yellow colour, appears to remain flexible for years, doesn't turn brown and become brittle.
[Re: SidSnot]
#761290
01/02/19 9:01 pm
01/02/19 9:01 pm
Posts: 1,329 Bolton Lancs UK
Andy Higham
Bolton Lancs UK
Both black rubber and clear plastic are unsuitable for fuel hose long term. The petrol rots the rubber which then blocks the carb. Petrol hardens plastic hose causing leaks at the fittings. The black synthetic rubber used on Japanese bikes lasts well as does the yellowish Tygon hose
BSA B31 500 "Stargazer" Greeves 200 "Blue Meanie" Greeves 350 Greeves 360 Suzuki GSX1100 EFE "Sorcerers Apprentice" GM500 sprint/LSR bike "Deofol" Jawa 500 "Llareggub" Aprilia RSV Mille "Lo Stregone" '35 & '36 OK Supreme Kawasaki ZZR1400 "Kuro no senshi"
[Re: SidSnot]
#761304
01/02/19 10:42 pm
01/02/19 10:42 pm
Posts: 4,349 argyll. scotland, uk
gavin eisler
Fuel lines last about 5 years tops for me, thats the black rubber stuff, it starts to crack on bends eventually. Especially where UV gets it. Never tried the dayglo stuff. Sounds great. Havent used clear stuff for years , it gets too brittle.
71 Devimead A65 750 56 Norbsa 68 Longstroke A65 Cagiva Raptor 650 MZ TS 250 The poster formerly known as Pod
[Re: SidSnot]
#761314
01/02/19 11:35 pm
01/02/19 11:35 pm
Posts: 3,829 gastonia nc
raf940
gastonia nc
I use clear thickwalled polyurethane made for ultralight aircraft stays flexible for a very long time https://www.air-techinc.com/maingroups.php?pmid=12
1972 Triumph T120 1968 BSA A65 1968 MGB Roadster 1979 Chevrolet Camaro Berlinetta 1969 Honda Mini Trail 1939 farmall f30 tractor 2004 Honda Shadow Aero 1972 BSA Thunderbolt 1975 yamaha xs650b 1972 Norton commando 2 olive drab WWII military bicycle replicas
[Re: SidSnot]
#761317
01/03/19 12:47 am
01/03/19 12:47 am
Posts: 1,368 Nanaimo, B.C. Canada
Wilfred
What's the consensus on black fuel line when you don't have to buy ethanal fuel? In these parts, we have more than one choice of non ethanal including Chevron 94 and haven't had a problem yet.
Cheers, Wilf
"It's about the ride..."
[Re: SidSnot]
#761323
01/03/19 1:35 am
01/03/19 1:35 am
Posts: 4,650 Owego, NY, USA
I've been using plain ol' double-walled automotive fuel hose for around 40 years, and I've never noticed any swarf in the float bowls (and I run Mikunis, which have no inlet screens).
But, I change hose frequently, I'd say every 1-2 years. At $.35 per foot at the auto supply store, why not?
BTW, if you don't like the writing on the hose, a little acetone or alcohol will take it off.
[Re: SidSnot]
#761502
01/04/19 6:19 pm
01/04/19 6:19 pm
Posts: 2,286 Atlanta, GA USA
Semper Gumby
Atlanta, GA USA
+1 clear. You can SEE it tickling (or not).
Secretly Mediocre....
[Re: SidSnot]
#761550
01/05/19 12:36 am
01/05/19 12:36 am
Posts: 4,340 Aus
NickL
Aus
Whatever i have at the time of building..................prefer clear with a couple of turns of lock wire.
No-one expects the Spanish Inquisition................ Bring in the 'Comfy Chair'
[Re: SidSnot]
#761587
01/05/19 4:31 am
01/05/19 4:31 am
Josh, where would one acquire Tygon hose? And, what is an ROV?
[Re: SidSnot]
#761596
01/05/19 6:18 am
01/05/19 6:18 am
gavin eisler
Remote Operated Vehicle" used to get oil, cheaper than divers.
[Re: SidSnot]
#761607
01/05/19 10:34 am
01/05/19 10:34 am
gunner
Farnham, Surrey, UK
You can buy Tygon tubing on eBay, Amazon etc. There are various formulations around but the one you want is the yellow petrol resistant type, should be marked F4040A, see . This Link from the manufacturers website. Watch out for fake Chinese copies.
[Re: Wilfred]
#761718
01/06/19 6:26 am
01/06/19 6:26 am
Posts: 3,943 Sydney Australia
BSA_WM20
Cheers, Wilf UV light attacks everything and causes them to degrade, people included. Keep your bike out of the sun & the fuel line will remain soft for a very long time. Heat also does the same thing So never ride your bike and the black rubber fuel lines will remain soft for a very long time. There are many different grades of black rubber fuel line. The best is a double layer one with butyl ( petrol proof ) rubber inner sleeve and a neoprene ( oil resistant ) rubber outer sleeve. These come fiberglass reinforced, steel reinforced , stainless steel reinforced & I have just seen some kevlar reinforced ones. The strongest are the fuel injected hoses. As such a lot of fuel line can crack on the outside & not leak. Then there are single wall rubber fuel lines, the best are Bunya-n rubber but the down side of them is when they start to crack on the outside the crack will go all the way through. While it is a PIA to replace them, only properly spiral wound, full soft copper fuel lines are permanent so everything else should be considered a service replacement part. Tygon, made by St Gomain in the USA is the yellow coloured fuel line. They also make a clear , a grey & a blue fuel line. The tygon is a single wall tube so when it starts to crack it must be replaced. Tygon s very expensive & as already mentioned will have the manufacturers code as a continious line for the full length of the tube. I fix lawnmowers & get a lot of spam selling unbranded fuel line in the "Popular yellow colour" Most of this is gelatin based plastic and will dissinergrate while you are riding. A lot of cheap Chinese chain saws come fitted with it as standard and they all fall apart within a year or so. many stories about exploding shainsaws & line trimmers from this line leaking and then the tool bursting into flames. Genuine Tygon is expensive. If it is not expensive then it is not Tygon Some BSA's came fitted with plain old PVC which will also work, but goes hard in a few years thus requiring regular replacement. It is your bike so you decide what you want to fit, just remember no matter what you use it WILL HAVE TO BE REPLACED at some regular interval. The cheaper the tubing the more often you will need to replace it.
Bike Beesa Trevor
[Re: SidSnot]
#761719
01/06/19 11:25 am
01/06/19 11:25 am
Posts: 7,743 scotland
triton thrasher
I recommend against copper fuel line. It breaks.
I have good success with black rubber hose sold as car fuel injection hose.
[Re: SidSnot]
#761741
01/06/19 3:57 pm
01/06/19 3:57 pm
triton thrasher
I wouldn’t be at all surprised if coiling the pipe helps. I doubt that it helps enough. ![[Linked Image]](https://www.bing.com/th?id=OIP.ln5e-17ygSDiXDyG4YmiYAHaFj&pid=1.1.jpg)
[Re: SidSnot]
#761849
01/07/19 8:59 pm
01/07/19 8:59 pm
Andy Higham
Bolton Lancs UK
The so called copper brake pipes are not copper but copper/nickle alloy. Stamping on the brake pedal can produce brake line pressures of over 2000psi, copper would not stand a chance
