Back2Brits
Back2Brits
Philadelphia, PA USA
Phil Andersen, Bud O, knobby, coomo, Chris mannifield
11025 Registered Users
franko 140
DavidP 78
Rohan 59
koan58 58
1,157,510 mail-order LSR
Topics69,027
Posts691,607
Members11,025
76 registered members (Allan Gill), 1,336 guests, and 987 spiders.
A10 End float #759710 12/18/18 3:23 pm
stanoneandonly Offline OP
Building a 57 DA10 bottom end. There should be about 3 thou float. Two questions. As the drive side is bolted up solid and shimmed, why worry about float clearance as it won't float anyway. If it does need shimming on timing side What shims do we use as none are shown in parts book and they would be bigger diameter than drive side. So should there be a thrust washer as A65? Any info gratefully received. Forgot to mention that it has had a new MB bush reamed to size. A solid brass one.
Re: A10 End float [Re: stanoneandonly] #759718 12/18/18 4:37 pm
Allan Gill Online Happy
You only need to shim on the drive side, the reason for the clearance is the crank will grow in the cases (its believed the cases will grow faster than the crank, but I'd destroyed 2 needle roller bearings proving different) when you measure the crank for end float the roller bearing (which would have been standard on your A10) needs to be bolted up tight, you should measure .003" from this point.
Sorry can't comment on the thrust washer with the A10
Re: A10 End float [Re: Allan Gill] #759726 12/18/18 6:55 pm
Tracey Spear Online Content
[quote=Allan Gill]...when you measure the crank for end float the roller bearing ... needs to be bolted up tight, you should measure .003" from this point.
[quote]
In "Building Budget Brits" Brown talks about doing this on an A65 by using a section of old fork tube and a washer to substitute for the rotor. But something in the back of my mind kept asking why? I've never quite understood where the play comes from in the first place. The light came on when I read your statement. Or at least I think it did.
Am I correct in thinking that the Crank and inner bearing are locked together by the rotor and nut on the drive side. So the TS Bush is really only supporting the weight of the crank.
Where is the play in the system, that shims limit to .001-.003?
Is this play within the roller bearing? Or play against the TS thrust washer? Both? Or am I missing the concept completely?.
Since thicker shims move the crank closer to the TS, some of the play must be the thrust washer/bushing interface. On the other side of the thrust washer is the bush with spiral grooves, oil directly from the pump, and the crank with oil groove and passage to center of crank. Is that why this tolerance is so critical, because if over .003 the risk is leaking oil directly to the case from the thrust washer thus starving the rest of the engine?
Re: A10 End float [Re: stanoneandonly] #759732 12/18/18 8:29 pm
trevinoz Offline
Shims are listed in the parts book.
They are fitted between the inner race and the crankshaft.
The drive side is not bolted up tight as the roller race just slides into the outer in the case. The inner race is bolted tight.
The timing side of the crank has a thrust face which bears on the flange of the bush.
You have to get the end float right, I try for around 0.001".
It is a painful job setting it as you have to assemble, measure, then usually remove the inner race to shim then do it again.
Re: A10 End float [Re: NickL] #759768 12/19/18 11:10 am
Originally Posted by NickL
I don't know where you find steel that grows faster than ally....................
I know where your coming from Nick, but really am not making that up.
Re: A10 End float [Re: stanoneandonly] #759769 12/19/18 11:31 am
kommando Offline
Yes when both at at the same temp then the alloy will have expanded more and this is the case on a warmed up engine. Problem is during the warming up, if the heat gets to the crank before the cases eg piston to con rod to crank then for a short period the crank could be warmer and wider than a tightly shimmed crank in the cold alloy cases will allow without binding.
Re: A10 End float [Re: stanoneandonly] #759773 12/19/18 1:26 pm
RGSROB Online Content
One thing I did not see mentioned in this string was OIL, DO NOT attempt to set end float with any oil on the face of the bearings. A film of oil can easily throw your measurements off at least one thou.
I do not know where the .003" end float target came from. It is incorrect and should be .001. Definitely grows as the motor warms up.
Re: A10 End float [Re: stanoneandonly] #759793 12/19/18 4:07 pm
gavin eisler Online Content
"I do not know where the .003" end float target came from"
1970 A65 factory manual, crankshaft end float 0.0015 "- 0.003", presumably A10s are similar.
going by this 0.001" is too ticht.
t
Re: A10 End float [Re: Allan Gill] #759900 12/20/18 6:14 pm
wak Offline
Allen are you using a roller both ends ?If so what's locating the crank?
BSA lightning
BSA B50MX
TRIUMPH TR6C
BSA BUSHMAN
BSA Gold Star Daytona
BSA Gold Star Scrambler
BSA Rocket Gold Star
BSA C15S
BSA Cyclone
Triumph T120
Triumph T100 Daytona
Triumph 5TA Trials
Triumph T100 Scrambles
Cheney 560 TT
Re: A10 End float [Re: wak] #759967 12/21/18 7:41 am
Hi Wak, at the time I was doing, with an outrigger plate outboard the alternator. With nothing added to the crank it would happily turn under its own weight.
Re: A10 End float [Re: stanoneandonly] #759995 12/21/18 4:17 pm
Roller bearing came off nicely . Adding up all my shims comes to28 thou for a gap of 3 thou. or one 30 thou shim for a gap of one thou. I'm inclined to use the 30 thou shim and expect the sealant to give me another thou clearance. I also think with the roller bearing the shaft will be free to move as it does not bolt up tight. Thanks fro your forbearance. Merry Christmas and a happy new year.
Re: A10 End float [Re: stanoneandonly] #760032 12/22/18 12:04 am
Rub the 30 thou shim with Dundee marmalade on a soft calico cloth , failing that shagreen will do till its 0.029 and 4 /8" and it will be fine
Re: A10 End float [Re: stanoneandonly] #760050 12/22/18 1:46 am
Chivers is pish, for a quality fit and silent gear meshing , there is nothing finer than Dundee marmalade.
Disclaimer, DONT evr put Marmalade in your engine, unless its on the bench, and only then, test for fit and silence , Dont be tempted to use a seedy jam, thats not right.
Last edited by gavin eisler; 12/22/18 2:53 am. Reason: works nicht oot, forgive me, drunk
