rockersj
rockersj
NorCal
99 registered members (actriumph), 618 guests, and 522 spiders.
John Billerbeck, JMOnTwoWheels, SteveCompton, LanceH, 911speedster
10570 Registered Users
franko 93
NickL 71
809,455 mail-order LSR
Topics67,463
Posts668,959
Members10,570
Rear Shock, Travel Geometry & how to set for dirt #748647
09/10/18 7:04 pm
09/10/18 7:04 pm
Sacramento, CA
Denis J Offline OP
Denis J  Offline OP
Sacramento, CA
Rear Shock Options...who else makes them and who is off-roading their machines?
Hi All
I am working on a few machines all set up for offroad
Having listened to a few suspension companies about shoosing the rear shocks I am now fully confused. The information is all over the board
Machines in question
06 Royal Enfield Bullet 500 (pre unit) with stock front forks
66 BSA A65 with Betor Front forks and B50 21" wheel
69 B44 With Ceriani forks
I am looking for a rear shock set that is longer (of course) and will be a plush as allowable for the total travel. The items currently tried/recommended are all too stiff.
I am looking for answers on how to choose the rear spring rate and then maybe pick a damper that will work.
Going the easy route a buying the techno fancy stuff is all good but spending 500-1000 on rear shocks for a weekend banger is not reasonable. I am hoping these can come out less than 200 for a kit
Any experience would be excellent! Thank you
Denis J
- Triumph’s- BSA’s- Norton’s- Matchless’s - Scott’s- A Weslake racer...many others from all over the world.
If it has 2 wheels I might need it.
“You can wheelie any bike if you just try”
Broken Motorcycle Mechanic at The Vintage Monkey in Sacramento, CA ...Old Motorcycle Specialists
Re: Choosing Rear Shocks for Offroad [Re: Denis J] #748677
09/10/18 9:48 pm
09/10/18 9:48 pm
For my B44 I specified a shock 15 lbs lower spring rate than BSA specified, was told it was too much lower but I find it a much less harsh ride.
Re: Choosing Rear Shocks for Offroad [Re: Denis J] #748762
09/11/18 12:26 pm
09/11/18 12:26 pm
Bolton Lancs UK
Andy Higham Offline
Andy Higham  Offline
Bolton Lancs UK
Manufacturers always err on the side of caution when specifying spring rates. Probably ok for 18 stone rider with GF on the back.
A good suspension supplier will take into account the bikes axle weight, the riders weight and riding style
Re: Choosing Rear Shocks for Offroad [Re: Denis J] #748845
09/12/18 3:44 am
09/12/18 3:44 am
Sacramento, CA
Denis J Offline OP
Denis J  Offline OP
Sacramento, CA
Ok
Race Tech literally blew me off. “Well it’s $875 to start so if you’re not serious then we can’t help”
My question was “I’m trying to find an affordable way to get close to 4” of travel in a 14” shock no damping adjustment needed”
Progressive suspension was super helpful but options came to a dead end. They have 1 compatible damper and it requires their 80/120 spring...stiff for a leightweight bike...good for the sportster hooligan class
Hagon has a myriad of options but I,m waiting for email confirmation on travel. According to their charts they have a very long shock 370mm with 100mm of travel and a spring as light at 10kg per cm...all that translated is 14.5 long, 4” travel and a 56lb per inch spring....cushy or bottom out happy?
Is there another company I should look into?
Re: Choosing Rear Shocks for Offroad [Re: Denis J] #750385
09/25/18 6:15 am
09/25/18 6:15 am
Western NY
Pete Suchawreck Offline
Western NY
Falcon shocks, NJB shocks from Speed and Sports
Re: Choosing Rear Shocks for Offroad [Re: Denis J] #750649
09/27/18 12:28 am
09/27/18 12:28 am
Sacramento, CA
Denis J Offline OP
Denis J  Offline OP
Sacramento, CA
Man
There is very little information on this
2 pages in Race techs bible...helpful but likely not applicable
Supposedly there is a book by Tony Foal twin shock setup. Looking for this
Re: Choosing Rear Shocks for Offroad [Re: Denis J] #751095
10/01/18 12:34 pm
10/01/18 12:34 pm
West Yorkshire
West Yorkshire
I heard some bad reports about NJB, many folk stating they were only good for off road/ trials use.... However I fitted a pair of fully enclosed "ultimate shocks" to my A65, not yet had to adjust the pre-load on them, just use and go.... I always thought the hagons were a reasonable shock, but these are a far superior alternative and I imagine to be as good as the Koni/Ikon's but without the price tag... between that and the referbed front end with progressive springs, the bike is a dream to ride, almost too smooth on the road.
Re: Choosing Rear Shocks for Offroad [Re: Denis J] #751139
10/01/18 9:01 pm
10/01/18 9:01 pm
Bolton Lancs UK
Andy Higham Offline
Andy Higham  Offline
Bolton Lancs UK
Falcon will build a pair of shocks to suit your requirements
https://www.falconshockabsorbers.co.uk/
Re: Choosing Rear Shocks for Offroad [Re: Denis J] #752223
10/10/18 8:48 pm
10/10/18 8:48 pm
Sacramento, CA
Denis J Offline OP
Denis J  Offline OP
Sacramento, CA
Thank you for this insight
Here is what I have learned so far..I am unable to verify this is concrete truth. Any engineers are welcome to chime in
The shock is at it's stiffest in the vertical position
Moving the upper shock mount forward will increase the rear axle arc length (increase suspension travel) and soften the effect of the spring
Moving the upper and lower shock mounts to the middle point of the swinger and the mid point of the upper mount-to swing arm pivot point will double the rear axle arc length (double the suspension travel) and cut the spring rate in half (super soft)
If the upper shock mount is closer to the swingarm pivot than the lower the spring rate will become "digressive" meaning the shock will soften up through the range of travel
I feel like I am getting closer to a solution. I can get shock assemblies in the 100mm travel range...moving the BSA A65 upper mount 1" closer to the swing arm pivot should increase the overall travel .9" and soften teh rate of the spring/dampening. How much the spring softens I have yet to figure out a calculation
Inputs?
Re: Choosing Rear Shocks for Offroad [Re: Denis J] #752981
10/16/18 3:07 am
10/16/18 3:07 am
California, USA
c caspary Offline
c caspary  Offline
California, USA
Denis
I agree with Pete S.
Get a hold of Matt at Speed and Sport - he is close to you - https://www.speedandsport.com/
He has the experience to advise you well.
I am using NJBs from Matt and they work well
Charlie
66 TR6 MkIII Rickman
66 TR6 Scrambler
68 T120 Flat Tracker
Re: Choosing Rear Shocks for Offroad [Re: Denis J] #753002
10/16/18 12:30 pm
10/16/18 12:30 pm
gavin eisler Online content
gavin eisler  Online Content
Interesting article on rear shocks here.
http://www.eurospares.com/frame5.htm
Re: Choosing Rear Shocks for Offroad [Re: Denis J] #758415
12/07/18 4:55 am
12/07/18 4:55 am
Atlanta, GA USA
Semper Gumby Offline
Atlanta, GA USA
Hi Dennis.
I bought my 14" Hagons for my 67 Hornet from Bruce Triplet. He spec'd the springs for me based on the weight of me and the bike.
I'm racing this in Flat track and hopefully Road Racing with ARHMA so I'm restricted to 4" travel. If you are not racing AHRMA then you can get more modern Shocks and NJB or Falcon above will also do just fine. I have a set of Falcons on a 1972 Montesa Cota Trials bike and they work just fine. Matt Hidebrand at Speed and Sport is a great source for lotsa bits: cables, ignitions, shocks etc...
http://www.brucessuspension.net/
Secretly Mediocre....
Re: Choosing Rear Shocks for Offroad [Re: Denis J] #758460
12/07/18 4:35 pm
12/07/18 4:35 pm
New Hampshire, USA
David Dunfey Offline
New Hampshire, USA
"Moving the upper shock mount forward will increase the rear axle arc length (increase suspension travel) and soften the effect of the spring."
Denis,
I don't know enough about suspension design to say that you are incorrect, but I think that you are confusing two things that are going on. It is a little counterintuitive, but if you rotate a spring on an angle and apply a load, you will need a stronger spring to support the load. This is about springs and angles, not axle arcs. For example, if you have a 200 lb/in spring that is vertical and supports your load the way you want and you put that spring at a 30 degree angle, you will need to replace that spring with a 230 lb/in spring to support exactly the same load. Saying this another way, as you angle the spring from vertical "it gets weaker" so to speak. Velocette used this on many of their bikes that allow you to move the top bolt of the shock on a slotted arc. This effect is called "the angle correction factor." The good news is it should answer your question about the spring rate at various angles. It turns out that the angle correction factor "acf" for 30 degrees is .87. When you divide 200 by .87 you get 230. You can use Google to find a chart of spring angle correction factors.
I have not done any work on changing the geometry of the arc of the rear axle, but it seems a little off to me. I would think that the attachment points for the shock would be better explained by the concept of a "motion ratio." The motion ratio is calculated by figuring out the lever ratios of the lower shock mount on the swing arm when compared to the upper mount on the bike in relation to the pivot. You are really measuring the levers that are working on the spring and rear wheel. All of this is reasonably eyeball glazing. Ultimately, it is important to measure the "wheel rate" of the rear wheel because that will tell you the "force" that is being generated on the wheel by the particular spring rate after it goes through all of the leverage ratios and angle adjustments. (The wheel rate is the motion ratio squared times the spring rate times the angle correction factor.)
Given the above, I tend to ask experts and copy what others have done. I try to have only the broadest view of the math.
David
Re: Choosing Rear Shocks for Offroad [Re: Denis J] #762982
01/19/19 8:27 pm
01/19/19 8:27 pm
nashville, TN
t.read Offline
t.read  Offline
nashville, TN
I'm sort of in the same boat. Building a T140 to do the LAB2V this year. I have a set of old NJBs that are about 13.5" long. They weren't built for a heavy 750 twin in mind though. But my friend I got them from said they were too stiff for his Bultaco. Just sitting on them in the shop minus a motor, they feel alright. When I get the motor finished, I have some dirt road riding I'll be testing out the shocks on.
One thing though, after going through all this on my old Elsinore. The angle does seem to help as far as the suspension travel and plushness goes. I had a MR250 Elsinore which has a fairly upright shock angle and I had Race Tech build a set of shocks for it. I never could get it to feel very plush for me at the level I wanted to ride cross country races with it, but I only weigh about 160. If you were calling the Race Tech guys in CA, you really need to talk to Matt Wiley about vintage stuff. He's the main guy that does all their vintage builds. He's based in Arizona and is a great help. I ended up selling the Elsinore to a friend and he got it to feel fine for his riding level. I moved on to an '81 Suzuki PE 175 as my cross country bike which has lay down twin shocks. This bike handles as good as my modern dirt bike with an old set of Bilsteins.
You could also look into YSS, Noleen, and GAZI. Had a friend with a set of YSS piggybacks on a Maico and he said they were great. Noleen will build you a set for about the same as Works would. I haven't dealt with GAZI, but I think they can also be built for around $600ish like Noleen and Works. Supposedly Works Performance is back under Gil's daughter, but I think they're called Worx Performance.
Re: Choosing Rear Shocks for Offroad [Re: t.read] #763317
01/23/19 7:31 pm
01/23/19 7:31 pm
Sacramento, CA
Denis J Offline OP
Denis J  Offline OP
Sacramento, CA
Great info. Thanks for sharing. I will look into that as I am hooping to attend the same events in the future!
Moderated by  Allan Gill
