Steve in Ohio
Steve in Ohio
Central Ohio
97 registered members (actriumph), 563 guests, and 557 spiders.
John Billerbeck, JMOnTwoWheels, SteveCompton, LanceH, 911speedster
10570 Registered Users
franko 95
NickL 71
809,467 mail-order LSR
Topics67,463
Posts668,965
Members10,570
And the Winner is - #758408
12/07/18 3:36 am
12/07/18 3:36 am
ca, us
DMadigan Online content OP
DMadigan  Online Content OP
ca, us
I am not a fan of the rubber mounting of the gantry on the triples. It sags and interrupts the flow with the steps between the two spigots and rubber tube. The Japanese rubber mounts had cast couplings that filled the space between the carb and head for a smoother transition. Because of the 15 degree angle of the A75 cylinder, the spigots are cast aluminum and angled to make the carbs sit horizontal. The T150 spigots are steel and straight. The spigots are different diameters, the A75 is 1.25", the T150 is 1.162". The gantry spigot matches the intake spigot diameter so the A75 and T150 gantries are not interchangeable.
The first change was to replace the spigots at the head and gantry with a single tube making a smooth port from carb to valve. The second was to replace the 626 AMAL carbs with a larger diameter carb with a tapered transition tube. I have a couple of 930 Amals from a twin but I would need three. I looked at alternatives and decide on 30mm Oko PWK carbs. These use the same needles and jets as the Kehein PWK so tuning parts are readily available.
I made a new manifold and tubes to mount these carbs.
The AMAL carbs with tube pressed into the gantry looks like this:
The Oko PWK cabs with new manifold looks like this:
The Oko carbs are spigot mount so the manifold has an O-ring to seal the spigot and an aluminum ring with O-rings to adapt the airbox. The airbox bolts clamp the carbs into the manifold.
To compare the three arrangements I put them on the flow bench with a stock head. Measurements were taken at wide open throttle at 0.30" and 0.39" lift. The stock arrangement measured 61 CFM and 61.5 CFM. With the 626 Amals and straight tube measurements were 62 CFM and 63 CFM. The 30mm Oko carbs measured 66 CFM at both lifts.
The smooth tube added little to the stock flow but the larger carb with tapered tube added 8% increase in flow. The same flow at both lifts indicates the limit is probably from the downstream constant diameter in the head.
Re: And the Winner is - [Re: DMadigan] #758577
12/08/18 6:39 am
12/08/18 6:39 am
Great Southern Land
tridentt150v Offline
Great Southern Land
So 8% Dave....is this across the board? or after a certain throttle opening - say 80% throttle opening. The reason I ask is because we would all want to know where we could feel/ use the extra flow [probably an impossible question]. If you are sitting on 1/4 throttle doing 60 mph and you accelerate to overtake a truck etc if its at 80% you still may not see or use that extra flow. But if it is lower down then then you may be able to use it regularly.
Nice work BTW.
Re: And the Winner is - [Re: DMadigan] #758610
12/08/18 5:19 pm
12/08/18 5:19 pm
ca, us
ca, us
I only tested the three variants to see if there was an improvement over the stock setup. The first option, the straight tubes replacing the rubber couplings, was a solution to the T150 carb interference with the starter. The tubes were to be angled up slightly so the carb bowls would not have to be changed to the drainless type. It seemed like a clean work around.
The second option with the Oko carbs would not need the angled tubes at the head because the bowls are shorter than the Amals. Making the flanges angled to the tubes requires pressing them in on a jig to get all three correctly orientated. Then they have to be machined on the head side afterward because the tubes have to be pressed through the flanges to get a smooth bore all the way through. Otherwise there is no easy way to make the nut side of the flange parallel to the head side.
I chose slightly larger bore carbs because a tapered tube accelerates the flow and the measurements show it is better than the straight tube.
The Oko carbs use the same jets and needles as the Kehein PWK carbs so tuning parts should be readily available. Many AMAL carbs are not in the best of shape from wear and age but few will replace them because of the cost.
Re: And the Winner is - [Re: DMadigan] #758656
12/09/18 4:28 am
12/09/18 4:28 am
Fl., U.S.A.
Thunderbutt Offline
Thunderbutt  Offline
Fl., U.S.A.
Dave, any chance of developing a set like this for the T160? I would like to ditch my Amals .
Re: And the Winner is - [Re: DMadigan] #758683
12/09/18 4:54 pm
12/09/18 4:54 pm
ca, us
ca, us
I would have to make runs through the full range of throttle opening to make a comparison. There probably is not a great deal of improvement at small opening since there is a lot of turbulence generated by the slide.
I do not have a T160 to see what differences there are. I presume the head mounting is the same? Does the airbox attach by two bolts between the carbs like the R3/T150? The Oko intake is larger in diameter than the AMAL. I added a ring to seal the end of the carb and provide a flange for the airbox to mount against
Clive Scarfe made a special stainless airbox (perforated R3/T150 style) with the holes to match these carbs. I will be stocking a few over here but they can be ordered direct.
Re: And the Winner is - [Re: DMadigan] #758758
12/10/18 6:01 am
12/10/18 6:01 am
Excellent!
So, how difficult would it be to adapt something like a BMW K75 fuel injection?
Re: And the Winner is - [Re: DMadigan] #758761
12/10/18 6:53 am
12/10/18 6:53 am
ca, us
ca, us
I have no experience with K75 FI but adapting throttle bodies is not a problem. I have put SV1000 throttle bodies on my Lotus Europa and SV650 throttle bodies on my Rickman-Triumph 8 valve twin. Driving them takes a specially programmed micro-controller. At the minimum it takes RPM and throttle position but it really needs air temperature and airbox pressure as well. Engine temperature is needed for cold start enrichment and fast idle warm-up.
Tuning is simpler and cheaper than with carbs since you only need to connect it to a PC and change the maps but few people would want to go this route because it does not look stock.
Re: And the Winner is - [Re: DMadigan] #758777
12/10/18 1:27 pm
12/10/18 1:27 pm
Running from demons in WNY
Hillbilly bike Online content
Tuning injection is not necessarily easier than carbs for a street...Electronic injection has many variables and unless you know the actual values from experience it can take quite a bit of time on a dyno and road testing..Carbs are self correcting to a certain extent and have generally only three adjustable circuits..
In certain automotive drag racing classes, carbs make more power than injection simply because of the the time needed to tune the injection.
But on a street bike with no concerns for emissions,I believe a clever guy with time on his hands can work out a system using off the shelf parts and processor from Micro Squirt or similar aftermarket...A simple speed density street system needs rpm, load( vacuum), ambient and engine temp, throttle position and possibly road speed inputs..And a fuel pump,( might require a larger charging system) hoses, a bunch of wiring and mounting the sensors that many vintage bike guys dislike...I think the advantages could be worth the trouble if cost is within reason
I take off bike parts until it doesn't function, then put on just enough so it functions
Re: And the Winner is - [Re: DMadigan] #758852
12/11/18 1:35 am
12/11/18 1:35 am
Great Southern Land
Great Southern Land
You won't really get much advantage over carbies vs injection on a road going bike unless you add flat topped pistons and a 4 valve head and direct injection. Some, but not enough to justify the work needed IMO.
Re: And the Winner is - [Re: DMadigan] #758877
12/11/18 4:09 am
12/11/18 4:09 am
ca, us
ca, us
FI would not come close to the cost of the OKO triple carb. You might find used K75 throttle bodies but they will still cost more than new Okos.
Re: And the Winner is - [Re: tridentt150v] #758893
12/11/18 12:41 pm
12/11/18 12:41 pm
Carb basic function relies on airflow and has some limitations because of that...Electronic injection does not have the same limitations...On a modified engine this can be an advantage at lower speeds ....I don't believe you need a modern engine design to take advantage of injection as evidence the many old OHV V-8's fitted with EFI. With required emission controls,newer injected OHV Harleys and Guzzis run nicely...But for the typical vintage Brit Bike, I don't think injection offers an advantage other than bragging rights
Re: And the Winner is - [Re: DMadigan] #758932
12/11/18 5:38 pm
12/11/18 5:38 pm
kevin roberts Online content
kevin roberts  Online Content
i think the fact that the fastest old brit bikes currently use magnetos and carburetors is something to think about. that may change over time.
i suspect that the precision tuning offered by injection would be wasted on a machine that is limited in other ways.
Re: And the Winner is - [Re: Hillbilly bike] #758996
12/12/18 3:26 am
12/12/18 3:26 am
Great Southern Land
Great Southern Land
[quote=tridentt150vI don't believe you need a modern engine design to take advantage of injection as evidence the many old OHV V-8's fitted with EFI.
I have limited knowledge of these 'old V8s' but afaik they are throttle body injection [similar to what our bikes would have to go with]. Direct injection came much later. This method was inherently inefficient...dinosaur with a band aid! It was only done in desperation in a declining market and surging fuel prices. I would be amazed if there was any massive benefit from this. I think it was also a knee jeeerk mod to show that the American car industry [and the Australian/English one as well] - so lets say traditional - could match it with the modern offerings from Japan and Europe. It was always a stop gap until they caught up.
This was similar to the V8's that could switch to a 4 cylinder in cruise mode and the petrol motor V8's that had a diesel head slapped on them in cars like the Cadillac.
Again I say "You won't really get much advantage over carbies vs injection on a road going bike unless you add flat topped pistons and a 4 valve head and direct injection"....but note I didn't say NO advantage, just not enough to warrant the work needed.
Inversely, I wouldn't go to the trouble of installing carbies on a throttle body/inlet tract type injected motor.....again....nil advantage.
Re: And the Winner is - [Re: DMadigan] #759006
12/12/18 6:20 am
12/12/18 6:20 am
Melbourne Oz
Steven A Offline
Steven A  Offline
Melbourne Oz
I do! Microsquirt?
Re: And the Winner is - [Re: DMadigan] #759215
12/13/18 10:40 pm
12/13/18 10:40 pm
ca, us
ca, us
So, made a quick comparison of the standard two valve head with the four valve 3D printed model. Just the head with a bellmouth on the port, 10" water. The two valve at 0.35" lift flowed 66.7 CFM, the four valve at 0.25" lift was 87.7 CFM. The four valve still has the no valve seat angle cut in.
Re: And the Winner is - [Re: DMadigan] #759217
12/13/18 11:17 pm
12/13/18 11:17 pm
Great Southern Land
Great Southern Land
^^^ that is interesting, a big difference in flow.
