C.B.S
C.B.S
Lancaster, California
40 registered members (Alan_nc), 390 guests, and 487 spiders.
LanceH, 911speedster, cbowers, Ratbag, Kelly David
10567 Registered Users
franko 93
NickL 70
806,767 mail-order LSR
Topics67,426
Posts668,704
Members10,563
Rear brake plate #757623
11/30/18 2:07 pm
11/30/18 2:07 pm
Maryland
JD Offline OP
Moto-Amish
JD  Offline OP
Moto-Amish
Maryland
I'm in the final process of cleaning up my BSA...again. I've been plating the older threaded iron pieces that have been wire wheeled down to bare metal in the distant past and cleaning up the aluminum bits. My latest head scratcher is the pivot pin on the rear brake plate in the photo. It's notched above the threads, but doesn't seem to want to budge. I don't think it's threaded into the plate, but someone correct me if I'm wrong. Heat hasn't seemed to help. Do I just need a bigger hammer and some marvel mystery oil?
Josh
Re: Rear brake plate [Re: JD] #757632
11/30/18 3:30 pm
11/30/18 3:30 pm
West Yorkshire
West Yorkshire
Turn the oven on full, when its reached full heat, throw the part in. (don't put the part in then heat up the oven) the Alu will expand faster than the steel shaft, after a minute, take it out, dose it with penetrating fluid (non flamible, like WD40) and give it a sharp bob with a mallet. it should come straight out. Leave it in the oven too long and the pin will have expanded also.
Re: Rear brake plate [Re: JD] #757634
11/30/18 3:41 pm
11/30/18 3:41 pm
Farnham, Surrey, UK
gunner Online content
gunner  Online Content
Farnham, Surrey, UK
+1 on what Allen says, the pivot pin is probably corroded in place in which case a good soaking in your favourite dismantling lubricant followed by heat usually works.
Re: Rear brake plate [Re: JD] #757650
11/30/18 6:37 pm
11/30/18 6:37 pm
Maryland
JD Offline OP
Moto-Amish
JD  Offline OP
Moto-Amish
Maryland
Last time I did that was years ago to the main bearing in an apartment after I was first married. Boy, did it piss off my wife.
She just left the house for the next 4 hours, so I have at least that long to clear out the smell.
Josh
Re: Rear brake plate [Re: JD] #757689
12/01/18 1:21 am
12/01/18 1:21 am
Maryland
JD Offline OP
Moto-Amish
JD  Offline OP
Moto-Amish
Maryland
Well, the oven was a failure. Multiple heatings, dunking in cool water to try to shock it has been a failure. I even tried heating it and using a jack and the frame of my 4,800 lbs. truck as a hydraulic press. I was able to lift the truck off the ground with the pivot pin, brake plate and a socket, so I don't think any matter of beating the thing with a hammer is going to work. It's now sitting in penetrating oil overnight so we'll see where it goes tomorrow.
Josh
Re: Rear brake plate [Re: JD] #757735
12/01/18 4:20 pm
12/01/18 4:20 pm
Oklahoma
Tracey Spear Offline
Oklahoma
I found this buried on the C5 Ignitions site: I'm going to try it on some stuck cylinder barrel studs that so far refuse to budge using WD40.
Tired of spending $5 a can for penetrating oil that doesn't work?
Check out this report...
Penetrating oils ........... Average torque load to loosen
No Oil used ................... 516 pounds
WD-40 ..................... ... 238 pounds
PB Blaster .................... 214 pounds
Liquid Wrench ...............127 pounds
Kano Kroil .................... 106 pounds
ATF*-Acetone mix............53 pounds
The ATF-Acetone mix is a "home brew" mix of 50 - 50 automatic transmission fluid and acetone. Note this "home brew" released bolts better than any commercial product in this one particular test.
ATF-Acetone mix is best, but you can also use ATF and lacquer thinner in a 50-50 mix.
*ATF=Automatic Transmission Fluid.
Re: Rear brake plate [Re: JD] #757753
12/01/18 8:35 pm
12/01/18 8:35 pm
West Yorkshire
West Yorkshire
When using the atf blend in a cylinder, you usually ignite the acetone and have a mini bonfire, the 600 degrees or what ever it is allows enough expansion for the ATF to penetrate.
Re: Rear brake plate [Re: JD] #757757
12/01/18 9:04 pm
12/01/18 9:04 pm
Farnham, Surrey, UK
Farnham, Surrey, UK
I've recently found that a 50/50 mix of brake fluid (dot 3 or 4) and acetone makes a really good homemade dismantelling fluid. Suggest you get a bucket filled with this mix and let the brake plate soak for a few days, make sure theres a lid fitted to keep the fumes from evaporating and stirr the mix every day. Hopefully this will free up the seized pivot.
Re: Rear brake plate [Re: Allan Gill] #757760
12/01/18 9:18 pm
12/01/18 9:18 pm
Maryland
JD Offline OP
Moto-Amish
JD  Offline OP
Moto-Amish
Maryland
Kinda like this Allan? That was a 50/50 mix of acetone and ATF. Still no luck getting that piston unstuck and it'll have to be drilled out.
Josh
Re: Rear brake plate [Re: JD] #757809
12/02/18 9:05 am
12/02/18 9:05 am
West Yorkshire
West Yorkshire
I’m Starting to think your blessed with having all things seized solid JD.
This may or not be of some help, but when I worked in a garage I used to release things like track rod ends and drop links by cutting the end of the stud back flush with the nut it was bolted to, keep cutting away until the nut and the shaft were flush and shiny, then soak with WD40 and it comes straight off. In these cases the ball joint would spin in the housing before the nut would undo and then you’d have a pita job on your hands and lost time too.
Doing the above with damage the brake plate, but you could cut the shaft short of where it needs to be leaving a couple of threads showing. Then drill the centre with as big of a bit as your comfortable using then using a hacksaw, cut down the threads (almost like slicing a pizza) drive a punch down the drilled hole, and it should have released the grip from above. You could also use a dremel and break through the wall in 3 points for the part that’s inside the brake plate, I’ve done that with bearing retainers. But either way that pin will be scrap afterwards.
Re: Rear brake plate [Re: Allan Gill] #757812
12/02/18 9:45 am
12/02/18 9:45 am
BSA_WM20 Online content
BSA_WM20  Online Content
If you have an air hammer/chisel around, they work a treat on corroded solid parts.
he 10,000 tiny blows a minute whith you pushing faily hard will break corrosion bonding a lot better than smacking once with a 20 lb hammer, and do far less damage.
