C.B.S
C.B.S
Lancaster, California
38 registered members (Alan_nc), 380 guests, and 507 spiders.
Kelly David, PATony, Bro Vintage, Stuart Kirk, celcius232
10563 Registered Users
franko 93
NickL 70
806,767 mail-order LSR
Topics67,426
Posts668,704
Members10,563
New Triplex Chains #757536
11/29/18 7:20 pm
11/29/18 7:20 pm
London, UK
Ianbuck Offline OP
Ianbuck  Offline OP
London, UK
Just putting together my A65 primary side, with new clutch and chain. While trial fitting prior to sprocket alignment I note that the new Renolds chain has loads of lateral play compared to the old Renolds chain I took off.
You can see in the photo the original old chain has virtually no lateral play, however the new chain (shown fitted on the bike) you can see significant gaps and play in the chain.
Is this normal with these new chains?
I was going to check the sprocket alignment ( with the chain off) but with the new, looser chain I expect alignment is less critical ?
Any comments ?
Ian
Re: New Triplex Chains [Re: Ianbuck] #757538
11/29/18 7:32 pm
11/29/18 7:32 pm
I only buy chain from Andy the chainman, Andy has retired but the new guy uses his name, ask for the Merc duplex timing chain version.
Re: New Triplex Chains [Re: Ianbuck] #757539
11/29/18 7:35 pm
11/29/18 7:35 pm
gavin eisler Offline
looks to me like they both have similar end play, just in different areas, plate to plate ,new, inner plate to roller, old.
not sure if this is normal or not, at Stafford I had a chat with Andy the chain man, he has a duplex option which he reckons is better, convinced me, though I havent tried it yet.
End play is not an excuse for miss alignment, trial fit the primary bits with no chain, clamp a straight edge to the front sprocket edge, see how far out the rear sprocket is, or do it the other way round, check the gap with feeler gauges, make a shim to go behind the front sprocket to compensate, or buy one of the part number options, a tolerance of + or - 5 thou is good enough it doesnt have to be dead on, why create wear and throw away HP.
Re: New Triplex Chains [Re: Ianbuck] #757542
11/29/18 7:54 pm
11/29/18 7:54 pm
London, UK
Ianbuck Offline OP
Ianbuck  Offline OP
London, UK
I'll check the sprocket alignment and take a photo of both chains on the table. It's the amount of side play that surprised me. I don't particulary want to by another new chain.
I also found a crack in the stator wiring outer casing. I was going to just put a bit of silicon on it one the final fitting.
Ian
Re: New Triplex Chains [Re: Ianbuck] #757545
11/29/18 8:32 pm
11/29/18 8:32 pm
London, UK
Ianbuck Offline OP
Ianbuck  Offline OP
London, UK
There you go, the chains are both fully flexed. The one nearer the ruler is the old one. That's nearly 1/2" of lateral flex on the old chain and about 1" on the new chain.
Ian
Re: New Triplex Chains [Re: Ianbuck] #757549
11/29/18 9:08 pm
11/29/18 9:08 pm
Worn out but brand new, sorry but you better buy a new good quality chain.
Re: New Triplex Chains [Re: Ianbuck] #757555
11/29/18 9:32 pm
11/29/18 9:32 pm
London, UK
Ianbuck Offline OP
Ianbuck  Offline OP
London, UK
I thought Renolds chains were be surpossed to be good chains? I think I'll give Renolds a call tomorrow, see what they have to say.
I've just checked the sprocket alignment and its spot on, without any shims. Pity about the chain I could have had that job finished tonight. Bugger !!,
Ian
Re: New Triplex Chains [Re: Ianbuck] #757557
11/29/18 9:43 pm
11/29/18 9:43 pm
Regardless of what they say that chain is junk.
Re: New Triplex Chains [Re: Ianbuck] #757561
11/29/18 10:59 pm
11/29/18 10:59 pm
That isnt good, possibly a low grade industrial . Last triplex I bought came from SRM, its been on for a good while, 20K maybe, still got some left in it. Try Andy the chain man, maybe?
Re: New Triplex Chains [Re: Ianbuck] #757562
11/29/18 11:01 pm
11/29/18 11:01 pm
ca, us
DMadigan Online content
DMadigan  Online Content
ca, us
The last time that I tried to buy triplex chain from a Renolds chain distributor they asked what it was for. When I said motorcycle they said they do not sell chains for motorcycles. Maybe different in the UK.
Re: New Triplex Chains [Re: Ianbuck] #757566
11/30/18 12:15 am
11/30/18 12:15 am
London, UK
Ianbuck Offline OP
Ianbuck  Offline OP
London, UK
This chain came from SRM with the new clutch I bought from them. It's in a Renolds branded box.
Re: New Triplex Chains [Re: Ianbuck] #757569
11/30/18 12:37 am
11/30/18 12:37 am
Get a refund, sent it back with the pic of the old one.
Re: New Triplex Chains [Re: Ianbuck] #757607
11/30/18 12:43 pm
11/30/18 12:43 pm
West Yorkshire
West Yorkshire
I'd refit that old one, and im not one to skimp on a build. However the best way to check strech is pushing the links togehter and then stretching it in a line.... My IWIS megalife chain will have a lot of Bow in it, but this is down to its design, the rollers in that are barrel shaped to take different loads, if you do the push pull technique then youll find virtually no wear.
RE- Reynolds Chain, yes back in the 60's it was the thing to have.... I bought one in 2006 ish and it was a pile of junk also, some lesser quality chain branded up and paying a royalty to use reynolds name I think. That chain I had was constantly being adjusted for the 3500 miles I had it on for, although if you have a new slipper then it will spend most its time cutting its tracks until the roller runs on the slipper and not the end plates..... As a note, unless your slipped is completely goosed, then dont change that either.
Re: New Triplex Chains [Re: Ianbuck] #757620
11/30/18 1:44 pm
11/30/18 1:44 pm
kevin roberts Online content
kevin roberts  Online Content
ive been using renold chain on my race bike-- half the time its at WFO.
chains last two days, then develop tight links. im switching to DID.
Re: New Triplex Chains [Re: Ianbuck] #757631
11/30/18 3:21 pm
11/30/18 3:21 pm
Bolton Lancs UK
Andy Higham Offline
Andy Higham  Offline
Bolton Lancs UK
Back in the day racing tridents used to break clutch shafts due to the load imposed by the triplex chain when the shafts flexed. the cure was to use two single row chains on the outer rows of teeth, this allowed some flex
Re: New Triplex Chains [Re: Ianbuck] #757633
11/30/18 3:40 pm
11/30/18 3:40 pm
Renolds chains have been useless for motorbikes for many years now.
Sorry.
Re: New Triplex Chains [Re: Ianbuck] #757643
11/30/18 4:43 pm
11/30/18 4:43 pm
I changed my first post, the Merc timing chain is duplex not triplex, you fit it to the 2 inner rows of teeth, Andy first used it on Laverda's as their Triplex chain for the 1000 triples was unobtainable and Iwis provided the duplex Merc timing chain, if it copes with Laverda power then any Brit bike is covered. I use it on my 850 Commando and no issues to date, I also use the simplex on the Norton timing chain. The pins and bushes are maxed out sizewise within the confines of the sprocket dimensions so it has the largest bearing surface possible and uses the best materials for long life, the simplex one on the timing chain does not need retensioning after 500 miles unlike the OEM one.
Re: New Triplex Chains [Re: Ianbuck] #757649
11/30/18 6:32 pm
11/30/18 6:32 pm
London, UK
Ianbuck Offline OP
Ianbuck  Offline OP
London, UK
Just to be clear there is no longitudinal play in this chain, the thing that interested me was the lateral play built in to the individual links.
If they used two single chains when racing to allow for some flex, then this chain has that. I suppose if the drive sprocket and clutch basket have no play then any chain (properly tensioned) will only be subject to longitudinal force and will not flex.
Well I spoke to Renolds technical department today, not very enlightening regarding specific use of this chain, although said it could be used for motorbike primary drive. They couldn't comment on side play of links other than say all Renolds triplex chains are made that way now. I was hoping to speak to someone with some technical expertise !,
Spoke to SRM and they have these chains fitted to their own bikes, and haven't experienced problems.
Tried phoning Andy the Chainman but got no reply.
So I will fit it and see what happens. It's relatively easy to replace the chain should it be necessary, I'll report back when I finally get this bike on the road.
Ian
Re: New Triplex Chains [Re: kevin roberts] #757661
11/30/18 8:03 pm
11/30/18 8:03 pm
Auckland NZ
Ignoramus Offline
Ignoramus  Offline
Auckland NZ
Good move .....ive got DID on my A65 best chain ive ever had , havent even had to adjust it.
...infact when i put it on i thought i would be smart and set it slightly tight to save the inevitable adjustment at a few hundred miles..........i had to LOSSEN it off ! no stretch at all
my understanding is that Renolds make several grades of chain....looks like OP got the "budget" version used on agricultural equipment
Re: New Triplex Chains [Re: Ianbuck] #757688
12/01/18 1:20 am
12/01/18 1:20 am
Isle of Wight, UK
koan58 Offline
koan58  Offline
Isle of Wight, UK
If a triplex chain doesn't exhibit any straight compression to extension, but is able to bend as much as shown, then the only "real" chain is the centre row, and the outer rows must have loose clearances between pins and rollers.
Re: New Triplex Chains [Re: Ianbuck] #757945
12/03/18 10:55 am
12/03/18 10:55 am
London, UK
Ianbuck Offline OP
Ianbuck  Offline OP
London, UK
Well i spoke to Andy the Chainman today and he basically said if I have a new chain from Renolds then I should use it. If it is unsatisfactory in service then he can supply another make of my choice. So tomorrow it's going on with a new tensioner, as the wear tracks may differ with the floating links.
Only time will tell if this is a good move? However, with a Siamese exhaust and rearset fitted, removing the primary cover is very easy.
Ian
Re: New Triplex Chains [Re: Ianbuck] #758120
12/04/18 4:40 pm
12/04/18 4:40 pm
TripleTown Offline
TripleTown  Offline
Renold Synergy? Blue? A&S? SD?
Renold Website
Re: New Triplex Chains [Re: Ianbuck] #758147
12/04/18 8:14 pm
12/04/18 8:14 pm
London, UK
Ianbuck Offline OP
Ianbuck  Offline OP
London, UK
I'm not sure what type of Renolds chain it is, but this is the box it came in.
Ian
Re: New Triplex Chains [Re: Ianbuck] #758149
12/04/18 8:50 pm
12/04/18 8:50 pm
London, UK
Ianbuck Offline OP
Ianbuck  Offline OP
London, UK
Just had a look at what's stamped on the links.
Looks like Renolds 08 B, could be 06 B
Does this help identify it.?
Re: New Triplex Chains [Re: Ianbuck] #758155
12/04/18 9:45 pm
12/04/18 9:45 pm
06b is std BS chain spec, nothing to suggest it's not just std industrial grade.
