Al Eckstadt
Al Eckstadt
Jordan, NY
1967 West Coast Hornet Oil Tank
#756940 11/23/18 7:11 pm
I gotta say installing this large oil tank is a PIA. First just getting it up into its saddle requires a lot of finesse. You have to try a number of twists and turns to get it up in there. Then the rubber bumpers fitment is big fun, I used a rubber lube to get it to work. Center bolt went in ok but the tank just seemed to sit funny. I tried to install the lower bracket to the frame using plastic pry bars to adjust it. Finally I had an of sorts fit but when I tightened the Center bolt the tank slipped out of the rubber bumpers.
Of course I contacted Gary Edwards for advise. He had the same problem, suggested I make a new lower bracket with an off set hole to the tank. . How the factory did it is beyond me.
Any comments on you guys restoring one of these would be very interesting
Richard
Re: 1967 West Coast Hornet Oil Tank
Richard Phillips #756942 11/23/18 7:29 pm
I just pulled one out, not quite ready to put it back. Is the problem new rubber bumpers?
Richard Phillips #756960 11/23/18 11:43 pm
I have only seen one of those bigger tanks, and that on eBay a few years ago.
I think it would be great to have the extra oil capacity, for cooler oil maybe?
Irish Swede #757141 11/26/18 4:31 am
The west coast Hornet oil tank is frame specific. It will not fit any other frame other than the west coast model Hornet and Wasp.
Gary E #757169 11/26/18 12:57 pm
A frame could have brackets removed or fitted to accept the tank maybe or is there some serious frame tube surgury required?
Richard Phillips #757173 11/26/18 1:40 pm
I think Gary just explained the cause of the problem: The west-coast Hornet has it's own unique frame,
maybe just to use that oil tank.
Irish Swede #757199 11/26/18 4:32 pm
I seriously doubt (although will accept if it is) that BSA would make serious alterations to a frame just to fit an oil tank, more likely they fitted different mounting tabs and made the tank to fit within the confides of a standard frame shape.
Richard Phillips #757210 11/26/18 6:23 pm
The frame is defiantly West Coast Hornet Specific. The overall shape of the frame is not different, I would say the saddle it sits in, is different ( although not sure) and there is a lug welded to the curved down tube behind where the tool box used to sit.
I should have posted this on the Hornet thread. I am hoping to help anyone up against the installation of 1 gallon oil tank used for the WC Hornet and or hear from others who have done this. By the way the tank has to be installed before shocks are mounted.
I could not use the original BSA bracket to mount to the oil tank and the threaded insert to the frame lug. Gary had the same problem, making his own bracket. I made a card board template aligning the mounting holes then formed the bracket from aluminum. I was able to use a bushed grommet through the bracket to the frame lug, so there is a bit of rubber cushion. Suffice to say this took a few attempts.
Since I have a spare WC Hornet Tank and an A65 Frame I plan to verify the saddle difference, if any.
Sorry I have not mastered the photo attachment. I would be happy to provided a pic of the bracket unmounted and mounted. Plus I would like to post pictures of the restoration process.
Thank you,
Richard
Richard Phillips #757215 11/26/18 8:13 pm
Does anyone have a stripped Hornet frame and be willing to post photos of the oil tank mounting area on this site?
It would be helpful to compare it with the "standard' frame for differences to clarify all of this.
Richard Phillips #757224 11/26/18 9:57 pm
I'm working on it. Since my restoration is in the early phase I can show it. Not sure how to post pics I think my I phone resolution is too many pixels. Advice pleasei
Richard Phillips #757250 11/27/18 1:45 am
.having never seen a western tank ,
Im guessing ,
Parts 11 through 18 ?
Richard Phillips #757259 11/27/18 2:43 am
I put a non-matching oil tank on my '70-framed A65 bitsa - not a large capacity tank, just a regular A65 tank, year unknown, has an outlet spigot near the top for the rocker oil feed, if that dates it. Anyway, I had to jump through a couple of hoops to make it fit. Climbing off its mounts when the rear bracket was lined up, etc. I had to shim up the bottom frame lugs with SS fender washers, one side more so than the other. I had taper-head machine screws welded to the top washer, so I could stack the other washers beneath as needed. The screws go through the holes in the frame lugs and nuts underneath hold everything in place. I can't quite remember how I attached the bumper rubbers to the fender washers, but I think I cut the flanges off the rubbers and glued them in place.
I also reengineered the top rear mount, which I think is necessary in all cases, since the factory setup does not adequately isolate the oil tank lug from both the frame AND the mounting bolt (and nut and washers).
quinten #757260 11/27/18 2:50 am
While researching an old thread last night I came across a poignant statement that seems appropo to this subject, I believe it was from Stuart, to paraphrase:
" If the parts fit, it CAN'T be a BSA!"
Richard Phillips #757261 11/27/18 3:56 am
1966 Factory Spares manual shows no frame differences amongst all models of A50 and A65. I believe the same is true for 1967, but my '67 Spares manual is out on loan.
Richard Phillips #757273 11/27/18 8:46 am
I've got one all apart on my bench now, but I'm not going to relearn how to post photos here. Speaking for 67, there is most assuredly frame differences as mentioned by Gary. I learned this when I got a WC bike with a cracked, leaking tank. No problem, I thinks, just stick in a normal 67 type tank. No way.
Richard Phillips #757339 11/27/18 9:48 pm
I looked at the standard BSA A65 oil tank saddle: defiantly different. The fender mounting hole is single notched tab that hangs down from the oil tank. It has a slot for a nut to hold in place for the lower fender mount. My older frames have two holes one on each side of the oil tank saddle, the saddle itself is accommodating to the standard oil tank
Here again I would like to provide photos but do not understand how to post pictures perhaps one of the Forum Monitors can forward a forward a link
Richard Phillips #757366 11/28/18 3:36 am
Richard, check out postimage.org.
Upload photo to postimage, click on uploaded photo, click on "Share". You'll see a list of URLs; click on the URL that's labeled "Hotlink for forums". Right click, select "Copy". Then just "Paste" into the forum.
Richard Phillips #757456 11/28/18 8:25 pm
Thanks Mark I signed up.
Richard
Irish Swede #757497 11/29/18 5:57 am
Hope these will help (if I have Attachment Manager figured out!)
[Linked Image][Linked Image][Linked Image][Linked Image]
Attached Files IMG_1280 - Copy.JPGIMG_1293.JPGIMG_1285 - Copy.JPGIMG_1287 - Copy.JPGIMG_1298.JPG
Richard Phillips #758036 12/04/18 12:45 am
ljm Offline
Good post Richard
I'm where your at on mine. Its been at least a year since I have been able to get back to the west coast hornet. I need to order the rubber pads and the grommet that holds the tank. Getting the oil tank out of the WC hornet frame wasn't easy. So going back in without scratching everything will probably be as challenging.
ljm
Richard Phillips #758055 12/04/18 1:46 am
Just put one in an hour ago, easy. Easy, that is, if just reusing the old rubber bumpers like you perfectionists don't do. In from the back,fill spigot out thru the frame, swings right into place. Fussiest part is the lower mount bracket.
Mildly interesting: I've had two of these tanks now, both have been cracked at that lower rear mount hole. The first one I welded myself, this one somebody brazed to repair back in the past.
Richard Phillips #758412 12/07/18 4:28 am
Hi Richard - Putting one together right now that I found in a container here in Atlanta! The back bracket, that fits into the RH inside of the frame, was twisted.from the factory. As other people said i used a soft pry bar to position the tank so I could fit the right rear bracket in place. I still have the original rubbers! The Oil drain looks like it will interference with the frame so I may not have it just right. I'm hoping to flat track and road race this bike.
Waiting on a motor from Beno...
Richard Phillips #758971 12/11/18 10:12 pm
I had to make my own bracket as well. Real pain to get in there. Poor design.
Bob M.
Richard Phillips #759933 12/20/18 11:12 pm
Frame Part Numbers:
West Coast Hornet/Wasp Frame: 68-4281
East Coast Hornet/Wasp Frame: 68-4279
The welded in tank saddle is different for the west coast model than the east coast model. It is narrower in width; the round mounting rubber bumps are closer together for the larger capacity west coast tank than on the standard size (east coast Hornet) oil tank. The west coast tank oil in/out hose tubes are located differently than a standard tank. And as Richard pointed out, the rear fender front mount on the rear of the tank saddle is different. Also the mounting tabs on the saddle front are different for mounting the side cover cross bracket.
One could cut out the welded in tank saddle on an east coast frame and weld in a west coast tank saddle, that is, if you had a west coast tank saddle available, but why would you. I guess if someone had a west coast frame that was already cannibalized, there might be the saddle available. But then the upper rear threaded mounting boss has to be welded, not "to", but "INTO" the frame tube...in the correct location and position.
The west coast oil tank installs from the right side of the frame, turning, twisting, angling, all the while verbally cussing that it won't go in without scratching or chipping new frame and tank paint. Install it first in a bare frame before anything else. Oh, and put the filter plug in first, as the plug doesn't want to come all of the way out after the tank is in the frame. Good luck changing the oil later. What a mess you will have.
Can't tell whether a Hornet is a west or east coast model with the side covers on? Look at the oil tank filler. The filler neck is longer on the larger west coast tank.
Images of the differences in the west and east coast model frames and tanks are all in the sticky Hornet, et al thread.
Gary E #778761 07/16/19 1:59 am
My oil tank cracked around the aft mounting hole. Getting it fixed.
Looked like a good idea. But....
Best way to drain the tank is to remove the oil feed line to the motor.
And the L bracket between the tank and the frame on the back of the motor is opposite the diagram above BTW on my bike.
