BritBike SponsorBritBike SponsorBritBike SponsorBritBike SponsorBritBike SponsorBritBike SponsorBritBike SponsorBritBike SponsorThe Bonneville ShopBritBike Sponsor SteadfastCyclesBritBike SponsorBritBike Sponsor
Electric Starter Roller
Geoff Patrick
Geoff Patrick
Southern California
BMac, clive1, Dan87GT, B. Nicholson, AndrewQ
10941 Registered Users
kommando 102
franko 87
DavidP 65
1,067,584 mail-order LSR
Topics68,277
Posts685,034
Members10,941
33 registered members (Alan_nc), 384 guests, and 808 spiders.
Amal 928 to 930 #757220 11/26/18 9:13 pm
Tracey Spear Offline OP
For a '69 Thunderbolt. What are the pros/cons of increasing the carburetor from 928 to 930?
Re: Amal 928 to 930 [Re: Tracey Spear] #757221 11/26/18 9:17 pm
gavin eisler Online Content
The low speed performance will be worsened, correct jetting will be difficult and the fuel economy will drop ,there arent any pros.
Re: Amal 928 to 930 [Re: Tracey Spear] #757223 11/26/18 9:38 pm
It’s been tried by a few people (not me) on here, over the years and reports have been bad.
Re: Amal 928 to 930 [Re: Tracey Spear] #757225 11/26/18 10:10 pm
THAT is why this forum is such a great place. Thank you for the advice.
I ordered a bunch of parts today from The Bonneville Shop to take advantage of their 10% off sale. They have the 930 premier set up for single carb bikes with proper slide. The salesman had me convinced I could get away with the 930. Since your advice was so unambiguous. I called to cancel the 930 from the order and explained the advice y'all shared. He called his supplier. His cost was close enough that he will honor the discount on a 928 Premier, even though he has to order it. In my book that more than makes up for misleading me in the first place. The whole transaction this morning was great. I called in the order because I had a few questions about the fork parts. They made suggestions that saved me a few bucks and carefully reviewed the order for accuracy. And I made a point to thank them for supporting the forum.
Re: Amal 928 to 930 [Re: Tracey Spear] #757233 11/26/18 11:40 pm
kevin roberts Offline
my 65/70 bitsa cyclo-thunder-light runs one. seems to work okay. i did mess with the main jet to get it to run right.
Re: Amal 928 to 930 [Re: Tracey Spear] #757256 11/27/18 2:24 am
Jeff K. Offline
The first year Triumph TR5T used a 630, the next year they went to a 928. Most people that I know who are running the T100c like the 626. Plenty of torque and and others have pointed out great gas milage.
Jeff
Re: Amal 928 to 930 [Re: Tracey Spear] #757265 11/27/18 4:46 am
Deadstiffcatt Offline
Although you have made your choice, here is food for thought:
What is the diameter of the intake manifold versus the 930 carb? For example only and illustrative purposes: If the carb bore were 30mm and the intake manifold bore was 28mm, this would appear to create a "step" of about 1mm all the way around. It would appear to me that this step would cause turbulence at certain flows as the mixture hits the difference height of the step. It would seem that an internally angled spacer would be needed to smooth out the flow from larger carb diameter to smaller intake diameter. Even so, it would also make sense that rejetting, changing the slide, and changing the needle position would all have to be messed with to obtain good results.
I mention the above as I deal with a 1965 Triumph TR6SR fitted with a 389 1 1/8" Monobloc. When fitting, I had the luxury of playing with several different intake manifolds which permitted me to find one that had the same bore at the carb, as well as matching bores from the intake manifold to head side. (And yes, I also found a couple that would cause that stepped effect.) The above food for thought is what I was thinking when setting it up. Runs fine, but many other Triumph 650's I have played with averaged 60 MPG- this one is a constant 50 MPG. I'm not a power freak, so cannot state whether it improved anything or is just eating more gas. But since I now have a collection of 1 1/8" carbs and matching manifolds- looks like I'm stuck with it...…….
What? Spend money on a new carb when I got 5 or 6 old ones to last me a lifetime that all operate smoothly? (Many, many thanks, Bonzo!)
Re: Amal 928 to 930 [Re: Deadstiffcatt] #757287 11/27/18 1:04 pm
Jeff K. Offline
Deadstiffcatt
Has a good point and something that I did not put in my reply. The TR5T manifolds fit the Carburetor. So you nee to match up 26mm to 26mm, 28 to 28 and 30 to 30.
Jeff
Re: Amal 928 to 930 [Re: Deadstiffcatt] #757295 11/27/18 2:49 pm
I picked up on that too. The salesman's answer was to port the manifold. All workarounds. I'm thankful to the members on the forum who provided sound advice, and happy that The Bonneville Shop made it right by ordering the proper carb and still honoring the sale.
Unfortunately, the only carb I have is so corroded from being stored for 40 years in Oklahoma humidity that I'm not even going to try to salvage it.
Re: Amal 928 to 930 [Re: Tracey Spear] #757299 11/27/18 3:37 pm
htown Offline
Some 850 Nortons run a 32mm carb on a 30mm head port via a tapered manifold and it apparently works okay. Good move on buying a new carb instead of pouring money into an junk one. Best thing you can do to get an old Brit bike running right.
1978 Bonneville T140E
1974 Trident
1970 BSA Thunderbolt
1971 Norton Commando
1973 Norton Commando
1974 Norton Commando
2018 Kawasaki Z900RS
Re: Amal 928 to 930 [Re: NickL] #757302 11/27/18 3:50 pm
Allan Gill Online Happy
Worst advice ever would be to port the manifold, if your going to fit a 30mm either use a tapered spacer as Tracey states or keep the step, I machine stepped spacers when I increase carb sizes, I find it better than a smooth taper TBH, it also emulates what goes on with a port on a modern vehicle. Increasing the port size will loose all the bottom end which is where the Thunderbolt is King!
However as mentioned above, I prefer to use a smaller carb where possible, Im using a 32mm carb on a 28mm port lightning head, but this is a case of jetting reasons rather than bigger is better, I simply can't get a 928 or 930 to jet lean enough!
Originally Posted by NickL
My own t'bolt runs out of breath at around 90mph but it's quiet quick up to that.
Thats becasue those magaphone silencers sap a lot of power, my old T-bolt was the same, however with some triumph silencers it went quite a bit better.
Re: Amal 928 to 930 [Re: Tracey Spear] #757320 11/27/18 5:27 pm
Adam M. Offline
Had 2x 32 carbs on my small port head ( 30 mm port going down to 27 ) with stock mufflers without any ill effects.
Bike was very fast for A65.
Re: Amal 928 to 930 [Re: NickL] #757618 11/30/18 1:39 pm
Limiting me to 90mph is not such a bad thing these days Allan.
To be honest its more than fast enough for anyone wanting to keep their licence and stay shiny side up
