TJD
TJD
Devonport Tasmania
Page 2 of 2 1 2
Re: My new toy
DavidP #746021 08/19/18 6:46 am
DavidP Offline OP
Not to worry, Lannis. It appears as if the tank has been lined with some brand I don't recognize. The lining is kind of translucent burgundy color?
If only folks would all take care of their petrol tanks as well as you do.
Re: My new toy
DavidP #746168 08/20/18 2:42 pm
Re: My new toy
DavidP #747940 09/05/18 12:28 am
DavidP Offline OP
I just fired it up, third kick. The oil light went out immediately with oil returning to the tank.
It revs nicely, so I guess those 180 jets are correct. Need to take it down the road to be sure.
I notice the blanking plugs for checking oil pressure are 18tpi. Is that a standard bolt or BSP? I need to get a fitting for a gauge. Of course, that bolt is not listed in the back of the parts book.
Re: My new toy
DavidP #747942 09/05/18 12:49 am
The blanking bolts at the front of the motor are 5/16"-18 SAE. You can connect a mechanical gauge there with a special banjo bolt or at the filter with a ported cap.
Re: My new toy
DavidP #747955 09/05/18 6:35 am
DavidP Offline OP
Just ordered the old Trispark directly from Oz. The points wires are rigged but good enough to ride for a little while.
Engine sounds great. Nothing quite like the sound of a triple. laugh
Re: My new toy
DavidP #748323 09/08/18 5:44 am
DavidP Offline OP
Spent half the day searching, but I found short cables. I got some nice bars with a 2" rise. I'm almost scared to ride it with those goofy US bars.
Next up is a new seat The one on it has a decent cover and pan, but the foam feels like crap from the fabric store. Burtons stocks some nice ones, and with the exchange rate quite reasonable.
Re: My new toy
DavidP #748445 09/09/18 2:58 am
DavidP Offline OP
Glad I didn't ride it yet. I checked the clutch mechanism today, no clearance behind the big nut. I know from personal experience that leads to broken pull rods.
Adjusted properly now, but I'll wait for the new cable to fine tune it. Probably strip the clutch this Winter to renew thrust bearing and pull rod.
Also need to check primary chain alignment, it's a bit noisy.
Re: My new toy
DavidP #748853 09/12/18 10:04 am
More liable to be shock absorber rubbers....they don't like sitting around, the oil gets to them.
Re: My new toy
DavidP #748897 09/12/18 3:43 pm
Yeah, mine were gooey with I stripped the engine.
Re: My new toy
tridentt150v #748902 09/12/18 4:36 pm
Would that explain an intermittent sort of a scraping sound that disappears when the engine is revved?
72 Tiger 650
72 Commando 750
74 Trident
84 BMW K100RS
A fleet of old cars
Re: My new toy
DavidP #749121 09/14/18 9:27 am
Maybe, once you apply a constant load on the spider then it 'stabilises' for want of a better term. But if you back off or rev the motor then the noise should come back because the housing/spider combo is whipping back and forwards and without the support of serviceable shock absorber rubbers it will wobble on its axis. Having said that most shock absorber rubber failures sound more like a bottom end rumble except its back in the primary/clutch area.
But I'm no Dr Google, an intermittent scraping sound could be anything sorry.
Re: My new toy
DavidP #749133 09/14/18 1:15 pm
Have this sound too, vanishing during acceleration, from reading tripleson line forum I know about people having much worse sounds, so don't worry too much about it.
But I.m still curious what causes it ?
Re: My new toy
DavidP #749238 09/15/18 3:17 am
DavidP Offline OP
Put the low bars on the Trident and installed a shorter clutch cable. Did the adjustment as per a TR3OC bulletin. Much easier than trying to get 0.005" clearance behind the nut. Clutch pull is very light now.
Got the 50-tooth rear sprocket in the mail today. The smaller sprocket saves using that stupid offset link to make 107 links in the chain. Gonna be one fast SOB.
I only had to replace the shock rubbers once on my old '74. I don't remember it making any funny noise, just surged as it ran down the road. I won't really know until I ride the bike. I still plan to inspect the primary and clutch this Winter.
Got a pretty new seat from Burton's. That will be the last thing I put on before the first ride.
Re: My new toy
tridentt150v #749251 09/15/18 6:45 am
Trident T150V, My guess is you're right - I'll find out when I pull it apart. I hope so anyway - if the noise is from the engine and not the primary drive, that's not good.
72 Tiger 650
72 Commando 750
74 Trident
84 BMW K100RS
A fleet of old cars
Re: My new toy
DavidP #754415 10/29/18 3:56 am
DavidP Offline OP
I got the front bearings cleaned and repacked. Front brake is sorted and adjusted.
I painted the header. It's a bit tricky to put back on, but I got it done.
Put the new seat on, ready to ride.
Re: My new toy
DavidP #755057 11/04/18 8:24 pm
DavidP Offline OP
I put an OP gauge on temporarily, mounted where the switch goes.
95+psi cold. I think it's safe to ride it.
Re: My new toy
DavidP #755063 11/04/18 9:00 pm
Hot pressure?
Re: My new toy
DavidP #755068 11/04/18 10:17 pm
Yes, it's safe to ride it - my pomp on a cold synthetic oil shows only 90 psi and keeps around 15 - 20 on hot oil in city traffic.
I still feel better with my permanently attached oil pressure gauge.
Re: My new toy
triton thrasher #755102 11/05/18 4:34 am
DavidP Offline OP
Hot pressure?
Sorry, but I'm not riding about with a gauge hanging by a cheap plastic line. And I'm NOT spending too damn much money for a an adapter to the 5/16 fitting which the factory was stupid enough to fit in the front of the case!
Re: My new toy
DavidP #755104 11/05/18 5:17 am
The factory did not put 5/16" bolts in the front of the case for an oil gauge. They were strictly for cross drilling the oil ways. If you want to keep the oil light and have a gauge then you could use a ported machined oil filter cap with braided line. No adapter needed, uses a standard 10mm banjo bolt.
Re: My new toy
DMadigan #755224 11/06/18 4:19 am
DavidP Offline OP
However, the factory workshop manual tells you to use this port to check oil pressure.
I'll just return from a ride and do the same temporary check at the switch port.
Re: My new toy
DavidP #771811 04/22/19 11:36 pm
DavidP Offline OP
I took the Trident for a short ride today just to be sure that everything works. Too much fun!
Even with the tall gearing it pulls like a train, and that header makes the sound of the gods.
The clutch is nice, much lighter pull than my last Trident. Only got as far as third gear, but it shifts nicely.
Now I gotta take the head off to cure the usual Triumph pushrod tube leaks. Good thing I have a complete gasket set. I've had that since '91. A friend won it at the Blue Ridge rally, a certificate from Big D Cycle good for any gasket set. I gave him $10 for it, win, win.
Bodine, thanks for the tip on the main jets. It pulls nicely out to 7K.
Can't wait to get it out of town and open it up.
Page 2 of 2 1 2
Moderated by  Tridentman
