The Bonneville Shop
john toghill
john toghill
chatham kent UK
11 registered members (bsawood), 186 guests, and 376 spiders.
10528 Registered Users
franko 90
NickL 66
785,052 mail-order LSR
Topics69,219
Posts674,257
Members10,528
Mk111 spark issues #754811
11/02/18 2:05 am
11/02/18 2:05 am
Colorado, USA
colorado47 Offline OP
Colorado, USA
Mk111 has pazon ignition, i have no experience with the Pazons. Battery tests good, looked at pazons trouble shooting page. No spark with the plugs out and grounded, when the start button is pressed, however when the button is released it sparks. Any ideas?
Re: Mk111 spark issues [Re: colorado47] #754816
11/02/18 2:18 am
11/02/18 2:18 am
Oztralia
Rohan Offline
Rohan  Offline
Oztralia
What happens when you use the kickstarter only ?
Sounds like not enough volts when the starter motor is involved.
How good is your battery.
Didn't the Mk 3 (with points) have some tricky stuff that shunted off 12v to the coils when starting ?
Re: Mk111 spark issues [Re: colorado47] #754821
11/02/18 3:09 am
11/02/18 3:09 am
Colorado, USA
Colorado, USA
Load tested the battery and jumped with a new one. No change. Has 6v coils with a Pazon ignition. Bike arrived with a bad stator and rotor, replaced with a 3 phase and potronics.
Re: Mk111 spark issues [Re: colorado47] #754822
11/02/18 3:32 am
11/02/18 3:32 am
Oztralia
Rohan Offline
Rohan  Offline
Oztralia
And what happens when you try to just kick start it ?
Re: Mk111 spark issues [Re: colorado47] #754829
11/02/18 7:36 am
11/02/18 7:36 am
triton thrasher Offline
What does the voltage between the ignition box + and - fall to, when the starter is turning?
Re: Mk111 spark issues [Re: colorado47] #754836
11/02/18 9:53 am
11/02/18 9:53 am
Hangtown, CA>
barncobob Offline
barncobob  Offline
Hangtown, CA>
had same problem recently with 74,, bike wouldnt start,,Pazon was bad, replaced with Boyer and it runs better than ever
Re: Mk111 spark issues [Re: colorado47] #754839
11/02/18 10:19 am
11/02/18 10:19 am
Norfolk, UK
L.A.B. Offline
L.A.B.  Offline
Norfolk, UK
Has the white/purple (ballast resistor bypass) wire been disconnected from the solenoid as that would prevent the EI sparking when the starter is operating but should still spark when using the kickstart?
(Do not disconnect the solenoid white/red)
Moderated by  Dave Comeau
