ChrisX
ChrisX
Lake Macquarie NSW Oz
Fraz, Dave Tomz, brknglss, USNFC, Dean Daigle
10644 Registered Users
koan58 99
reverb 71
L.A.B. 60
853,582 mail-order LSR
Topics68,045
Posts673,613
Members10,644
Most Online5,714
Apr 16th, 2019
69 registered members (Allan Gill), 416 guests, and 244 spiders.
Norton Commando Mk111 engine number #754645
10/31/18 9:27 am
10/31/18 9:27 am
England
Servodyne Offline OP
England
Hi all,
I've recently purchased quite a nice Norton Commando Hybrid, in as much it's a Mk11a frame with a Mk111 engine wrapped up in Fastback styling. Unfortunately the engine number is giving me a few sleepless nights worrying whether it's legitimate, although both frame and engine numbers do tally with the V5 log book.
The engine number starts with 850 followed by 537*** with the same six digit number on the Mk111 gearbox. I am led to believe from what I have seen on various websites including Norvil that the Mk111 engine should have a number starting 325*** .
Has anyone seen this before?
Many thanks
Jim
1957 BSA A10 Spitfire
1971 BSA A65 Firebird
1971 BSA A70 Lightning
1975 Norton Commando
1961 Norton 99
Re: Norton Commando Mk111 engine number [Re: Servodyne] #754646
10/31/18 9:46 am
10/31/18 9:46 am
Norfolk, UK
L.A.B. Online content
L.A.B.  Online Content
Norfolk, UK
Yes (but not all). The 'last' 850 Mk3 Commando was 336539.
Re: Norton Commando Mk111 engine number [Re: Servodyne] #754652
10/31/18 10:58 am
10/31/18 10:58 am
If you post a pic of the numbers then it can be gauged whether the stamps are factory or not, 537*** sounds out of range.
It should look like this as long as you have a photobucket fix in place
Note the 3 circles with horizontal lines.
Re: Norton Commando Mk111 engine number [Re: Servodyne] #754654
10/31/18 11:14 am
10/31/18 11:14 am
England
England
Unfortunately I don't have photobucket at the moment, but the numbers look to be in the same format with the three circles and the radial machine marks on the casing.
1961 Norton 99
Re: Norton Commando Mk111 engine number [Re: Servodyne] #754655
10/31/18 11:31 am
10/31/18 11:31 am
If you are seeing the photo then the photobucket fix is in place on your PC, post you pics with some digits covered to
https://postimages.org/
and then link to them here.
There will be a story to how your numbers are what they are but no doubt a lost story. I am struggling to think of a nefarious reason for the numbers you have so suspect it was a spare engine used as a factory replacement and a number used that they expected would never be on a production bike off the line.
Re: Norton Commando Mk111 engine number [Re: Servodyne] #757010
11/24/18 5:42 pm
11/24/18 5:42 pm
Midwest
Jimbo Offline
Jimbo  Offline
Midwest
Please post some photos, if you can, I am dying to see those numbers smile
Re: Norton Commando Mk111 engine number [Re: Jimbo] #757507
11/29/18 12:52 pm
11/29/18 12:52 pm
England
England
It looks as though whoever built the engine was proud of his handywork as there are identifying marks all over the engine including the inside, although I've not ventured that far as it's running so well. Curiously the mk111 gearbox has also been converted to RH footchange with the Mk11a drum brake.
1961 Norton 99
Re: Norton Commando Mk111 engine number [Re: Servodyne] #757514
11/29/18 2:15 pm
11/29/18 2:15 pm
Wonder why the 3 circle stamps with horizontal lines were defaced, making sure it was obvious they are not the original cases to later owners ?
If you have a MK2a and your crankcases burst open and MK3 cases used as a donor then the conversion to right hand gear change allows you to keep the rear wheel and brake plus not have to consider the swingarm changes, foot rests etc with fitting a disc rear wheel.
Does the gearbox have the electric switch insert screwed in from the front for the neutral switch ?
Re: Norton Commando Mk111 engine number [Re: kommando] #757518
11/29/18 3:00 pm
11/29/18 3:00 pm
Norfolk, UK
Norfolk, UK
Or they (plus the similar chisel marks on the head) are an attempt to obliterate somebody else's identification marks?
Re: Norton Commando Mk111 engine number [Re: kommando] #757522
11/29/18 3:26 pm
11/29/18 3:26 pm
England
England
Yes it's got the switch and working neutral light. Even the electric start has had the 4 brush conversion and works very well. In fact without it I don't think I could start it on the kickstart from cold, as it's so stiff to turn over. It's running on straight 40s oil so I may change it to 20W50 along with my other British twins.
1961 Norton 99
Re: Norton Commando Mk111 engine number [Re: Servodyne] #758615
12/08/18 5:53 pm
12/08/18 5:53 pm
Houston, Texas
Samsmc1 Offline
Samsmc1  Offline
Houston, Texas
L.A.B. - Look closely at the number 8 and the number 3 stamped into your case. . They are very different from the numbers stamped into the other case. From my many years in the motorcycle salvage business, I'd bet the numbers on your case have been altered or someone took a new virgin case and stamped the numbers.
Re: Norton Commando Mk111 engine number [Re: Samsmc1] #758618
12/08/18 6:20 pm
12/08/18 6:20 pm
Norfolk, UK
Norfolk, UK
Servodyne, not L.A.B.
Re: Norton Commando Mk111 engine number [Re: Samsmc1] #758620
12/08/18 7:00 pm
12/08/18 7:00 pm
England
England
I would have to agree with you about the virgin case. I don't think original numbers have been rubbed off as the machining marks are still evident on the case and it's not as though anybodies tried to fake an original number because the number series is incorrect. I suppose the biggest mystery is that DVLA have accepted this number and put it into the log book.
1961 Norton 99
Moderated by  Dave Comeau
