The Bonneville Shop
T140EBrian
T140EBrian
Georgia
13 registered members (Bougor), 197 guests, and 422 spiders.
10528 Registered Users
franko 90
NickL 66
785,074 mail-order LSR
Topics69,219
Posts674,259
Members10,528
ignition timing #754300
10/27/18 11:27 pm
10/27/18 11:27 pm
gastonia .. NC
limeyrider Offline OP
gastonia .. NC
To close out the thread .... I set the ignition timing today, set 28 deg. BTDC on the drive side, I got 27 deg. BTDC on the timing side, I turned the motor over several times through 360 deg. and checked each cylinder. I used two different timing discs and got the same results.
I used cigarette paper in the points to indicate the opening point .... in his book , Paul Dunstall recommends using a battery and bulb ( taking out the points centre bolt ) but I did not trust the taper to hold the points sufficiently well.
I am happy with that result .... perhaps not perfect .... but a whole lot better than it was.
Thanks for the help and advice.
Re: ignition timing [Re: limeyrider] #754527
10/30/18 1:56 am
10/30/18 1:56 am
Oztralia
Rohan Offline
Rohan  Offline
Oztralia
Closing off a thread by opening a new one seems a bit of a contradiction ?
Good you got it sorted, maybe your words need to be added to the original thread...
Moderated by  Dave Comeau
