Thomas4
Thomas4
Thun, Berne, Switzerland
34 registered members (benny jensen), 368 guests, and 527 spiders.
Kelly David, PATony, Bro Vintage, Stuart Kirk, celcius232
10563 Registered Users
franko 93
NickL 70
806,767 mail-order LSR
Topics67,426
Posts668,704
Members10,563
Page 48 of 48 1 2 46 47 48
Re: mail-order LSR [Re: kevin roberts] #748846
09/12/18 4:35 am
09/12/18 4:35 am
kevin roberts Online content OP
kevin roberts  Online Content OP
its odd, fernando. doesnt leak at all. i've got loctite 515 or 518 on the crankcase and inner gearbox, then a permatex gray on the outer gearbox, because its dinged a bit. everything else i have drips like an excited puppy.
the pushrod tubes were formerly problematic, but i bought adjustable tubes from dave madigan and that stopped all leakage completely. and the primary is dry. im using copper base and rocker box gaskets with thick copperkote gasket adhesive. did the same with the head gssket but now theres some seepage down the headbolt holes that shows up outside. im pleased with how little it leaks.
of course it spews oil out the back like nobody's business. i have three open breathers that lead to a small catch bottle, and i vent the oil tank to it as well. theres a good two inches of oil in it now. befofe i had the bottle i just spewed it out the rear, to the alarm of the guy with the immaculate zx14 next to me in the pits. he never quite believed me when i told him the back end always looked like that.
Re: mail-order LSR [Re: kevin roberts] #748849
09/12/18 5:02 am
09/12/18 5:02 am
South cone
reverb Offline
reverb  Offline
South cone
...I want to eliminate two very pesky leaks. One (and I have the same type on my 500) that is coming between the head and the cylinder; and for some reason (may be the tappet block do not have the O ring) from the base of the push rod tubes (I think)
All these stain my shoes and pants; so I only rides with the same cloth...
Lots of oil from here (may be is due to the rotary pump¿?)
The other leak is putting oil into the rear tyre; and that is not good. Nothing good.
When I opened the primary I changed the seals of the sprocket and do all the job there, then I found hole in the primary case and refilled with epoxy "welding".
Still I have the primary leaking (I will make a thicker gasket .75) Cannot be the gbox, all new there. but I have (less) oil in the new tyre after some kms at 4000 5000 rpms
-Should I put a catch bottle? I have plenty of spew inside (under) the seat; however¿? the hose is kind of dry...¿?
I will open the top end soon; I am waiting for the fucking customs that do not want to freeing the stuff.
I need to open it soon due I want to go to next country so I m thinking to put between 1200 to 2000 km.
I will dismantle the rocker boxes due to PO did a butchery with the rockers. Too rough lightening; I have some from other (1973) boxes. For piece of mind I want to change them.
Pain in the arse to put those Orings there. I do not have any special tool.
In the past I tried several things; sometimes with some success but sometimes bad.
Re: mail-order LSR [Re: kevin roberts] #748859
09/12/18 12:07 pm
09/12/18 12:07 pm
Arlington, Massachusetts 02474
kurt fischer Offline
#irideslow
#irideslow
kevin --
Tires -- ah, OK. From what I read, there are more 16" options now what with all these maxi-scooters on the market.
Chain -- what reverb said. (I use Tsubaki on my street bikes.)
Kurt
1968-70-71 Triumph TR6R Bitsa - 1969 Triumph TR6R - 1971 BSA A65L - 1973 Triumph TR5T
2005 Ducati MTS 1000S DS - 2012 Ducati Hyper 796 - 2014 Kawasaki ZX1000
Re: mail-order LSR [Re: kevin roberts] #748901
09/12/18 4:07 pm
09/12/18 4:07 pm
kurt, the scooter tires are all 16 inches, but not V-rated. motorcycle fashion for sport tires has moved on to 17-inch tires. i think most are S and T rated.
fernando, where is the oil coming from under the seat? your OIF shouldn't have anything leaking up there.
Re: mail-order LSR [Re: kevin roberts] #748921
09/12/18 6:54 pm
09/12/18 6:54 pm
Bolton Lancs UK
Andy Higham Offline
Andy Higham  Offline
Bolton Lancs UK
Avon make the roadrider V rated tyres in 150/80 x 16 (R), MT90 x 16 (R) and 120/80 x 16 (F or R)
https://www.avontyres.com/en-gb/tyre-details/59/avon-roadrider-avon-tyres/?cartype=motorcycle
Re: mail-order LSR [Re: kevin roberts] #748935
09/12/18 9:05 pm
09/12/18 9:05 pm
andy, at the moment i'm looking for rims that will let me run the racing goodyear front runners. they take a 2.5-inch rim, and i can find those for both front and back. the avons will fit the 2.5-inch rim, but they would be just outside of the recommended fitting.
the front runners are pretty skinny tires, no good for real-world motorcycling, but i'm thinking they would cut rolling resistance in a straight line on an asphalt surface. because they're racing tires, they're not limited by speed ratings, according to the loring tech people. in fact, the 4-inch versions are actually labelled for 300 mph. goodyear tells me they didn't bother labelling the 2.5-inch tires because nobody cares.
Re: mail-order LSR [Re: kevin roberts] #748971
09/13/18 1:32 am
09/13/18 1:32 am
South cone
reverb Offline
reverb  Offline
South cone
...hi Kevin, I am referring to the breather hose. This bike has the hose and the PO cut it under the seat; however, as mentioned, the hose is dry...
When I opened the primary and found that hole, no doubt that breathes that way, but now with the hole filled and nothing obstructing the hose; should be breathe this other way.
I really have a big oil leak; the 2 culprits that I think is the rotary pump (too much oil pumping) and that the breather is not working for some reason that escapes me.
Could be something inside the crankcase? May be silly question, but these ones do not have a seal on the crank (PS) so should be breathing right. I put a LED torch to the hose and looks dry; or always would look that way?
May be the breather is ok and work that way and the problem is that the head is bend or bad torqued and that the tappet do not have the O ring but leaks too much.
Re: mail-order LSR [Re: kevin roberts] #752404
10/12/18 1:27 am
10/12/18 1:27 am
fernando, if you have an oil leak under the seat but the breather tube is dry, it has to be coming from something else.
where is the most forward oily spot on the motor? oil will mostly blow backwards, so the most forward messy bit is likely your problem area.
Re: mail-order LSR [Re: kevin roberts] #757670
11/30/18 9:27 pm
11/30/18 9:27 pm
well, i just bought this:
17 x 3.00, a half-inch wider than the 2.5-inch wheel i already have, but vastly easier to fit, i think.
thank you, othertom, for suggesting that i use a front wheel from something on the back. ^^^this one is from a 1990 katana, a suzuki GSX 750, and i'm thinking it will work for both front and back.
has a simple bolt circle for the two front discs, and i can bolt a disc on one and a sprocket on the other. no cush drive, but i've been running without one so far and haven't self-destructed yet.
it;'s way narrow, so i don't think it will need to be cut, but i haven't taken the race bike apart yet to measure the wheel i have on it now. but i think it will be okay. if it turns out to be too narrow, i can get a simple doughnut spacer turned up to extend the sprocket out a bit. much simpler than trying to manufacture a new sprocket carrier.
the race tire people at goodyear tell me that the 22 x 2.5-inch front runner drag tires will fit on a 3.00-inch rim with no difficulty.
added
just bought another one. japanese stuff is way cheaper than brit, even for quality parts like these.
Re: mail-order LSR [Re: kevin roberts] #757680
12/01/18 12:08 am
12/01/18 12:08 am
Running from demons in WNY
Hillbilly bike Offline
Yeah, the Japanese stuff is easy to find, not expensive and decent quality = ready supply of hot rod parts...
I take off bike parts until it doesn't function, then put on just enough so it functions
Re: mail-order LSR [Re: kevin roberts] #757848
12/02/18 5:43 pm
12/02/18 5:43 pm
i'm approaching the end of what i can do to this bike. wheels and tires, tidier pipes, maybe reposition the left tank so i can contort myself lower.
i could put a hardtail on it and rake the front end out to lengthen and lower it, but tbats not real interezting to me. as it is, i can return this machine to factory stock just by putting the old partz back. the custom frame route is for people who want something different from what im here for.
but i could keep what i have and put the BSA fairing on it, and see how it would do in MPS. that would be interesting. but i want all i can get running nekked first.
Re: mail-order LSR [Re: kevin roberts] #764580
02/05/19 1:22 pm
02/05/19 1:22 pm
Project ROTM Offline
I have only just stumbled across this section of the forum.
This looks like an awesome build, so i am going to start from the very beginning. I might have caught up by this time next year.
Christian
Re: mail-order LSR [Re: kevin roberts] #764621
02/06/19 12:02 am
02/06/19 12:02 am
lol
its the never-ending-story
Moderated by  Allan Gill
