Thomas4
Thomas4
Thun, Berne, Switzerland
34 registered members (benny jensen), 368 guests, and 527 spiders.
Kelly David, PATony, Bro Vintage, Stuart Kirk, celcius232
10563 Registered Users
franko 93
NickL 70
806,767 mail-order LSR
Topics67,426
Posts668,704
Members10,563
Page 3 of 3 1 2 3
Re: Cam timing question with A65 750 [Re: Mark Parker] #750650
09/27/18 12:36 am
09/27/18 12:36 am
kevin roberts Online content
kevin roberts  Online Content
that's a possibility. there's a couple of ER-6s around for sale, no ER-5s. but this area is full of the little ninjas. clearly i need to spend some time with a tape measure.
i'll have to source another motor. the extra one i have now is going into into a period track bike this winter.
Re: Cam timing question with A65 750 [Re: Mark Parker] #750852
09/28/18 9:18 pm
09/28/18 9:18 pm
Skudeneshavn Norway
Stein Roger Offline
Stein Roger  Offline
Skudeneshavn Norway
I saw a Triumph T140 engine in the same type Suzuki frame as Mark’s on the Isle of Man maybe 20 years or so ago.
It was featured in a bike magazine later, but I couldn’t say how the engine was mounted. I’ll look for the magazine l when I get home. As I recall it was a standard engine, nothing fancy.
Re: Cam timing question with A65 750 [Re: Mark Parker] #751586
10/05/18 7:13 am
10/05/18 7:13 am
Mark Parker Offline OP
This is a video of what the BSA does. Still waiting on leaner needle jets, hopefully that's all it is.
https://www.youtube.com/watch?v=F6hos12a3lE&feature=youtu.be
Re: Cam timing question with A65 750 [Re: Mark Parker] #751918
10/08/18 10:43 am
10/08/18 10:43 am
Fitted leaner needle jets but its more or less the same though with much less fuel stand off. CDI units are here so might set them up and see if it's the same. And after that try my carbs.
Re: Cam timing question with A65 750 [Re: Mark Parker] #752031
10/09/18 7:47 am
10/09/18 7:47 am
Well there you go. Two DC CDIs, two coils, two pulse coils, big fat sparks and it's alive, once we put the richer Needle-jets back in. Timing light works at all revs and we can probably open the plug gaps a little. If we added wiring plugs and terminals the total cost of the ignition was less than $100. Advance looks good. It will just be a matter of seeing how it is on the road. Sounds crisp and good.
These are tiny little coils, is there a down side to using this type of set up?
Re: Cam timing question with A65 750 [Re: Mark Parker] #752035
10/09/18 8:30 am
10/09/18 8:30 am
This is the type of coil and DC CDI. What it looks like, may not be the exact same one.
We have instruments, headlights and blinkers and taillight to wire in, and some paintwork to do. Ben likes the idea of blue and white, and it would look good, even if not exactly BSA colours.
Very happy the thing is now revving up and down as it should. And so glad I didn't mess with the cam timing trying to get it running right. I wonder what I had wrong with the Honda ignition? Wonder if the 883 would start and run better with this type of ignition? Would running a bigger plug gap give more hp I wonder?
The ignition on the 883 does not have enough energy to fire the timing light very well at higher rpm, the CDI does.
Re: Cam timing question with A65 750 [Re: Mark Parker] #752156
10/10/18 6:55 am
10/10/18 6:55 am
Forfar, Scotland
JER.Hill Online content
JER.Hill  Online Content
Forfar, Scotland
Hi Mark
Good to hear you got to the bottom of the issue. Where does that ignition unit come from!
regards
Re: Cam timing question with A65 750 [Re: Mark Parker] #752165
10/10/18 1:06 pm
10/10/18 1:06 pm
The units are like this, possibly a different brand, I'll find out, but it would be good to see how they work. Ben ordered the wiring plugs to go with them and we found a wiring diagram. It has a bit of a miss after mounting them properly, so I'll check and solder the connections. Crimp terminals on light wire isn't great. Actually I'll replace the light wire going part way to the triggers. Even on a 360degree twin two of these may be good, where you place the triggers on the points plate determines the firing angles. They need to think they are crankshaft triggered so two screws sitting up on where the old auto adv sat are needed otherwise it won't advance when required.
https://www.aliexpress.com/item/Hig...vid=63f8f085-6c35-41a9-8274-191b1007cf62
Re: Cam timing question with A65 750 [Re: Mark Parker] #752279
10/11/18 7:19 am
10/11/18 7:19 am
Forfar, Scotland
Forfar, Scotland
Hi Mark
Thanks for the information.
regards
Re: Cam timing question with A65 750 [Re: Mark Parker] #752288
10/11/18 9:01 am
10/11/18 9:01 am
Still not right, has a missfire. Might check and ensure there are no air leaks in the intake rubbers or manifold joints or balance tube,
https://www.youtube.com/watch?v=PYSaYt51WNg&feature=youtu.be
Re: Cam timing question with A65 750 [Re: Mark Parker] #752320
10/11/18 1:41 pm
10/11/18 1:41 pm
The DC CDI I posted was what he got. These make things much easier:
https://www.aliexpress.com/item/CDI...ml?shortkey=zMbuyQNb&addresstype=600
I've ordered some trigger/pulse coils that should be easier to mount on the points plate. I'll give an update when I get them. They should be more accurate I think when face down. Triggers are further out and lass disturbed if it wobbles being on a flat plane. I have pulse coils mounted outside the points plate area on the 883, having them on a moveable plate would be much easier for adjusting timing. We never tried adjusting timing with the 883 on the dyno, and it's quite possible that where its set is not optimum. If I have a moveable points plate I can see incremental adjustment, pulling the rotor and moving it makes it more difficult. As does not having a hole in the primary cover.
Re: Cam timing question with A65 750 [Re: Mark Parker] #752425
10/12/18 9:37 am
10/12/18 9:37 am
West Yorkshire
West Yorkshire
Is it still possible that the cam is too lumpy for the capacity of the motor?
I always remember the twin carb A50 that ma friend had, with a 473 lightning cam it went like S**T off a shovel, but I find them quite tame on the A65, there was nothing special about that A50 either. Also (and probably mentioned earlier) that I had retarded a 473 cam on my lightning so that the lobe centres were equal, (I cant remember the values, but they could have both had an LCA of about 105 for inlet and exhaust) the bike went well, accellerated a treat and top end was good too, but somewhere in the middle about 4000 RPM it was flat, completely flat!! wouldn't accelerate for anything, and this was over a 1000RPM window, a better coil improved it and gave it a 500RPM window but still a pain in the butt having the change to a lower gear, to rev it to a point where I could drop it back in above the flat spot.
If your cam allows it, you could advance the cam a tooth, or with a modified pinion, half a tooth (8 degrees) without clipping the valves on the crowns. but if the over lap is too much, for how ever well flowing the head is (it'll only pull in 375cc per cylinder) are you loosing vacuum (dynamic pressure) becasue the overlap is too much, so your not pulling as much fuel/Air through as you need?
All that said I never did work out why the lightning cam in that position was poor at those revs, advanced from that it was fine, and either side of that flat spot it went like stink....
Re: Cam timing question with A65 750 [Re: Mark Parker] #752427
10/12/18 9:48 am
10/12/18 9:48 am
When you retard them you are relying on gas speed forcing the mixture in past the later shutting inlet valve as the piston is coming up, so exhaust and ports and I imagine compression all play a part in what happens when. Generally the slightly later shutting inlet enhances top end, but really that's minor compared to what can be done with the head and ports.
Re: Cam timing question with A65 750 [Re: Allan Gill] #752515
10/12/18 11:13 pm
10/12/18 11:13 pm
Running from demons in WNY
Hillbilly bike Offline
Reversion flat spot...sometimes it can be remedied somewhat with exhaust tuning...I have found on Triumphs and a Norton, longer exhaust length, as in long mufflers, can worsen reversion. On a Trident with a huge flat spot from a aftermarket header, a one inch balance pipe between the pipes about a foot from the head completely eliminated reversion for a slight loss at top end..There are other factors at play like intake length, carb mixture and obviously cam timing and I believe the shape of the piston dome in hemi head Brit engines
I take off bike parts until it doesn't function, then put on just enough so it functions
Re: Cam timing question with A65 750 [Re: JER.Hill] #753103
10/17/18 10:30 am
10/17/18 10:30 am
John, these trigger pulse coils seem the go. I cut the right angled mounting pieces off and drilled mounting holes in the flat part left either side. I'm making an alloy points plate which needs two 20mm holes for the things to sit down in, the wiring terminals will be on the outside hanging over the points plate which on the BSA motors doesn't matter. It's simple to make, they need spacers or bosses under the mounting screws. I should be able to fire the Honda ign with them or try the DC CDI.
https://www.aliexpress.com/item/In-...tml?spm=a2g0s.9042311.0.0.62174c4dvNs96s
Re: Cam timing question with A65 750 [Re: Mark Parker] #753152
10/17/18 6:22 pm
10/17/18 6:22 pm
gavin eisler Offline
Thanks for posting this stuff Mark, these coils are amazingly small. Who would have thought? I used to believe size was everything with coils, sjust another thing i had wrong.
Re: Cam timing question with A65 750 [Re: gavin eisler] #753183
10/17/18 10:55 pm
10/17/18 10:55 pm
Aus
NickL Offline
NickL  Offline
Aus
Remember Gavin, these are CDI units NOT inductive or HEI types. The very short energy pulse gives very little heating and if the core material is good then transfer ratios are good too.
Unlike HEI or Inductive setups, effectively the energy is not stored in the coil but in a charged capacitor, the coil serves as a transformer more or less.
If you look at the small replacement 'Energy Transfer' type coils around now, they are similar in construction.
Also, consider the 'Coil on Plug' type that are used now, they are very small too. Systems govern/control the stack time so well now.
I hope these work out ok for you Mark, my own thoughts are that with only a single plug head and a bore that size you will have ignition energy problems
causing flat spots and incomplete combustion. with those setups. They are designed for small capacity engines. Every manufacturer of CDI setups for
aftermarket use on 'hot rods etc' uses a multi spark system to overcome the CDI shortcomings. You may find a larger plug gap, say 45 thou will help
if the coils will fire it.
I may be talking crap but it's worth noting that both Bosch and Lucas abandoned CDI ignition designs in the '70's for similar reasons. Hitachi, Nippon-Denso, Mitsubishi
carried on with them for use on 2-stroke and small bore motorcycle and similar engines.
Bring in the 'Comfy Chair'
Re: Cam timing question with A65 750 [Re: Mark Parker] #753217
10/18/18 1:31 am
10/18/18 1:31 am
Thanks for explaining that Nick, I will let you know how it goes.
This is just the trigger system which will work with my honda ign as well and it fits nicely on the points plate.
two bolt heads to pulse them, to mimic crank triggering, so the advance works properly.
How it fits.
I'll cut a big hole in the plate so I can see the bolt heads and get a feeler gauge in to set the clearance.
Re: Cam timing question with A65 750 [Re: Mark Parker] #753957
10/25/18 11:37 am
10/25/18 11:37 am
It idles fine, spits out the carbs and stumbles driving off, unless you use a few rpm, above that smooth and ultra responsive. Ignition seems fine. Might do some miles on it and see if it becomes more apparent. Once it has a few rpm, throttle off and back on doesn't seem to have any bad areas only low rpm with load. Lower geared than mine with 20-38 sprockets.
https://www.youtube.com/watch?v=wS_dwydbMqM
Re: Cam timing question with A65 750 [Re: Mark Parker] #756459
11/18/18 6:35 am
11/18/18 6:35 am
So I fixed the carb issues by fitting the above trigger plate to Ben's bike, just started and ran normally with no misfire nor spitting back, changed back to std carb settings, slides etc, std needles were too lean though and switched back to richer needles and it's great. One of the previous trigger coils was likely causing our problems. The only new problem was end float in the idler gear, about .020" which changed the air gap on the triggers, at kick start speed giving no spark, but would push start and run ok.
I made a little bearing housing with a ball race pressed onto the old auto adv centre plate we use as a trigger rotor, the trigger coil plate/(replaces the points plate,) pushes against the nearing housing and eliminates the end float. I could then set the air gap so kick starting gives a spark. There is no sign of reversion or flat spots up to 6000 or a little more. Just good drivable power that starts building progressively from 2500 with serious zoom by 5000. I doubt the clutch is going to cope, it's only 3 spring. It has packer plates and heavy race springs which I will try winding in a bit more, I don't think its particularly slipping yet but feels close.
Re: Cam timing question with A65 750 [Re: Mark Parker] #756468
11/18/18 11:01 am
11/18/18 11:01 am
Good job Mark , my 3 spring clutch is working V well with the 7 plate conversion and 650 springs.
Re: Cam timing question with A65 750 [Re: Mark Parker] #756478
11/18/18 1:18 pm
11/18/18 1:18 pm
I have the 7 plate conversion in mine, definitely very good. Ben's has std plates, as many as will go in, plus the heavy springs. His brother Michael took it for a brief ride this afternoon, we could hear him for quite a while, it sounds like a big block V8 Mike is used to an RSV 1000, he thinks the motor is great, but the clutch isn't coping with the power, it may just need a bit more spring pressure. It's weird that they use the type of screws in the pressure plate, they are hard to fit and engage the thread without pushing the bike over, I made ones with hexes on them and more thread for mine so I can just use a socket which is so much easier.
The motor is really nice, it's virtually the same as the 883 with a shorter stroke, it hasn't got the outright torque of the 883 which is around 73lbft but it should approach similar power at higher rpm. If the torque is proportional to the displacement it should make 60lbft which would be 6lbft better than a Z900. And even if hp was proportional to displacement, (and it's not, it's more proportional to breathing) it would equal the Z900s 81hp, however it should do more than that. Why this little motor is so exciting.
Re: Cam timing question with A65 750 [Re: Mark Parker] #756486
11/18/18 4:39 pm
11/18/18 4:39 pm
Iowa
konon Offline
konon  Offline
Iowa
Glad you got it worked out Mark. Is the bike lighter than a stock BSA?
1968 BSA Firebird
1200 HD
XS 1100
1972 Rickman 125
Re: Cam timing question with A65 750 [Re: Mark Parker] #756513
11/18/18 9:21 pm
11/18/18 9:21 pm
It's a bit lighter, the big difference is the suspension and brakes and weight distribution, tyres, it copes better with rough roads and is like its on rails. The boys are keen to get some good video of it. I'll share it when they do.
Page 3 of 3 1 2 3
Moderated by  Allan Gill
