oilyrag
oilyrag
Lancashire UK
Vidane, BenM, New_Warrior, Chad Bradshaw, Bell47
10661 Registered Users
franko 96
NickL 49
876,424 mail-order LSR
Topics66,573
Posts668,466
Members10,661
73 registered members (Adam M.), 821 guests, and 168 spiders.
Fuel Cap #752043
10/09/18 12:25 pm
10/09/18 12:25 pm
London, UK
Ianbuck Offline OP
Ianbuck  Offline OP
London, UK
I've just reconditioned an American style tank to fit on my A65 and I need a new filler cap.
The replacement I recently bought looks like the original, but it does not seal tight against the filler opening.
The problem is the locking ring does not have a taper on the tightening edges. So it closes but when I go to tighten it with the screw top it is not pulled tight into the filler rim.
Does anyone know if a correct cap, similar to the original is available?
Ian
Re: Fuel Cap [Re: Ianbuck] #752071
10/09/18 3:47 pm
10/09/18 3:47 pm
Lancaster, California
C.B.S Offline
Parts Dealer
C.B.S  Offline
Parts Dealer
The repro's will do that. I add a 82-4048 cork washer under and the tends to seal it up. You can always cut a rubber seal for a better fit and seal.
Re: Fuel Cap [Re: Ianbuck] #752081
10/09/18 4:33 pm
10/09/18 4:33 pm
London, UK
Ianbuck Offline OP
Ianbuck  Offline OP
London, UK
That was the suggestion the supplier gave. However, I would have to glue the cork seal to the cap and I'm still not sure that it would provide a gas tight seal? I would need to experiment with various thicknesses of additional gasget as you suggest.
It may be the only solution I expect.
The other issue is the hinge pin loop is also a bit too high, so that will need bending down. Not ideal on a new aluminium part.
But needs most I suppose.
Ian
Re: Fuel Cap [Re: Ianbuck] #752083
10/09/18 4:45 pm
10/09/18 4:45 pm
Santa Barbara, California
KC in S.B. Offline
KC in S.B.  Offline
I ran into tis exact issue some years back. Cap looked beautiful, but the wing would go past the tightest spot and release! I had posted on the fix back in the photobucket days, but lost now of course. Anyhow, I made a tool. Small block of steel <1/2" wide, cut a hacksaw slot in it. Carefully mounted the cap in a vise. YES, a vise, with cereal box cardboard, in a vertical position. Clamped on the wing stem, and the cap inner base, just tight enough to hold it against a twisting moment which was not huge force. Put the tool slot on the ramp ring and work it into a steeper ramp = a more closing downward push. You can take it off the bench and try it with a temp hinge pin a few time if need be. Mine worked almost immediately. I was, and still am very happy with the cap. Good luck.
If I ever find those pics, may repost them here.
Oops,.. add 1 '65 XLCH
Re: Fuel Cap [Re: KC in S.B.] #752154
10/10/18 6:23 am
10/10/18 6:23 am
London, UK
Ianbuck Offline OP
Ianbuck  Offline OP
London, UK
Thanks for that suggestion KC. I tried bending the ramp just holding the cap in my hand, using some small pliers, but the steel ramp ring was too thick to bend. If I could swap the ramp rings that would be the best solution but I'm not convinced I could get that peened joint apart and 're assembled successfully .
Ian
Re: Fuel Cap [Re: Ianbuck] #752155
10/10/18 6:46 am
10/10/18 6:46 am
West Yorkshire
West Yorkshire
The originals are really good caps and still available NOS on eBay.
Note: they do leak when new or dried out, until the felt has soaked enough fuel up to swell then itโ€™s a charm. I bought one as above to replace my leaky one, by time it arrived it had sorted itself out.
Re: Fuel Cap [Re: Ianbuck] #753027
10/16/18 4:37 pm
10/16/18 4:37 pm
London, UK
Ianbuck Offline OP
Ianbuck  Offline OP
London, UK
Well following KC's suggestion I made a simple tool to bend the locking ring to form a ramp and it worked a treat ๐Ÿ˜
I held the cap a soft jawed vice, closing the jaws on the top of the wing nut and the locking ring. You can hold it quite tightly like this without any risk of damage.
I also had to bend the hinge down to fit the bracket on the tank, another easy task and then reinstall the hinge pin.
I'm vety happy with the result.
Ian
Attached Files 20181016_165258_resized.jpg20181016_165341_resized.jpg20181016_171824-1_resized.jpg
