CafeTbird
CafeTbird
Raleigh, NC
Bigmac, Dexter67, jimmiejag, LAGONAS, TJohn
10995 Registered Users
franko 106
DavidP 61
koan58 54
1,126,499 mail-order LSR
Topics68,718
Posts689,032
Members10,995
59 registered members (Al Eckstadt), 3,318 guests, and 856 spiders.
steering head bearings #751969 10/08/18 4:54 pm
johnpl Offline OP
I have noticed a slight amount of play in the steering head of my 1966 triumph Bonneville. I think I may need to replace the steering head ball bearings. Anyone had any experience using new tapered roller bearings?
Re: steering head bearings [Re: johnpl] #751973 10/08/18 6:26 pm
Stein Roger Offline
I have used tapered roller bearings on many bikes and generally believe they last longer. That is, they don't seem to dig in as readily as the ball bearings are often wont to do.
My opinion only of course. Someone will be along shortly with the opposite view.
Re: steering head bearings [Re: johnpl] #751975 10/08/18 6:31 pm
C.B.S Offline
Parts Dealer
Parts Dealer
I have used both... Stock is fine but I believe the tapered are stronger and will last longer. If you service them they should last for a very long time.
I stock them, and also use them:
https://www.classicbritishspares.co...er-bearing-set-cbs-2000-6t-t120-tr6-t100
Re: steering head bearings [Re: johnpl] #751976 10/08/18 6:36 pm
HawaiianTiger Offline
I've been installing these kits for over 20 years in every bike I work on and own. First off, they've always been way cheaper than the stock ones, and I'm a bit of a cheapskate.
Secondly, I noticed right away a more secure feeling on the road with them.
I would ignore the advice given in certain manuals to "Shock" the bearing with a large hammer, when installing. Yikes...
Hammers and bearings......don't do it.
Re: steering head bearings [Re: johnpl] #751978 10/08/18 6:58 pm
Mori55 Offline
When I did mine I just replaced the ball bearings. Races were fine. They held up for 50 years. I don’t think I’ll be around in another 50.
Re: steering head bearings [Re: Mori55] #751988 10/08/18 8:55 pm
C.B.S Offline
Parts Dealer
Parts Dealer
Exactly how I feel..
Mostly the bearings need to be replaced
As far as installing.. I made a 2 piece drift on my lathe. Top section is threaded, and the bottom piece is the pilot which centers in the frame both with the race installed or not. Then i thread on my nut (on the road) and begin to tighten the nut. The drift will insert the race into the frame. Very clean
If you need photos, i can post.
Re: steering head bearings [Re: johnpl] #752030 10/09/18 7:29 am
dave jones Online Content
John- Did you try adjusting the bearings? You can do this as long as the bars swing freely with the front wheel clear of the ground when the clearance is taken out. If you centralise them they should fall to each stop under their own weight when you give them a gentle push. Loosen the bottom yoke stanchion bolts as well as the clamp behind the adjuster when you adjust. Also, slacken the steering damper off.
