43 registered members (Alan_nc),
389
guests, and 485
spiders. |
Key:
Admin,
Global Mod,
Mod
Topics67,426
Posts668,704
Members10,563
Most Online3,995 Feb 13th, 2017
Re: Side stand mounting lug/clamp disfigurement
[Re: Rickman]
#751753
10/06/18 6:11 pm
10/06/18 6:11 pm
Posts: 4,347 argyll. scotland, uk
gavin eisler
I replaced my 71 A65 side stand mount, ground what was left of the old one back to the frame tube, bought a replacement lug/ strap from "Grins ", it looked like an open armed U shape this had to be heated and massaged to fit, the U closed around the frame tube. drilled and pinned to final fit. then welded on once happy with the position. Not sure what bike you are referring to but the principle will be the same.
71 Devimead A65 750 56 Norbsa 68 Longstroke A65 Cagiva Raptor 650 MZ TS 250 The poster formerly known as Pod
[Re: Rickman]
#751757
10/06/18 6:41 pm
10/06/18 6:41 pm
Posts: 48 CALIFORNIA
slow learner
CALIFORNIA
Sounds like you are dealing with a pre-unit BSA two piece stand lug. It is very common for the removable piece to be bent. It is also common for the frame tube where it mounts to be distorted if not broken. It's a weak design and could not support the weight of someone sitting on the bike when the stand is down. I lack the knowledge to comment on the composition of the lug but have seen dull red heating used when straitening foot pegs etc. Probably the less heat the better. After replacing that section of frame tube on an A10 I had the bottom part of the lub also brazed in place.
Laurence Luce
[Re: Rickman]
#751765
10/06/18 8:43 pm
10/06/18 8:43 pm
Posts: 1,329 Bolton Lancs UK
Andy Higham
Bolton Lancs UK
The A10 I used to own had a broken half lug so it was impossible to fit a stand. I made a bracket from 10mm steel plate that bolted to the bottom engine plate to frame bolt, a Triumph side stand pivoted on this bracket. When not in use the stand was inside the left frame rail, the toe protruding under the pillion footrest loop
BSA B31 500 "Stargazer" Greeves 200 "Blue Meanie" Greeves 350 Greeves 360 Suzuki GSX1100 EFE "Sorcerers Apprentice" GM500 sprint/LSR bike "Deofol" Jawa 500 "Llareggub" Aprilia RSV Mille "Lo Stregone" '35 & '36 OK Supreme Kawasaki ZZR1400 "Kuro no senshi"
[Re: Andy Higham]
#751853
10/07/18 5:47 pm
10/07/18 5:47 pm
Posts: 2,965 Ohio
Rickman
Thanks Laurence, Yes, all 5 A10 frames I have show that distortion to some effect, one even has had the lower clamp/lug welded to the frame, but that isn't one I plan to use, as the neck was raked.
The other one I don't plan to use now apparently was involved with a front ender; the top backbone tube has an ark, and the down tubes are kinked near their top. Such a shame, as this is the most correct and complete frame of the bunch.
Cut-off gas tank centering brackets/buffer mount and tank mount center nut fixture, front seat mount, one even had the rear top engine bracket mount cross tube cracked, almost broken out.
