MikeTRP
MikeTRP
Melbourne, Australia
Stormbringer, Noah from PA, DGW Auctioneers, GoTriples, Jan Hellinge
10830 Registered Users
franko 142
NickL 73
reverb 59
DavidP 57
975,344 mail-order LSR
Topics67,420
Posts677,634
Members10,830
65 registered members (998John), 474 guests, and 796 spiders.
problem starting 850 #747661 09/02/18 6:04 pm
barncobob Offline OP
74, gas on, key to 1st notch,2nd kick starts, idles nicely, astride and ready to ride, click switch to next position, move head lite switch to straight up position, bike dies....reversed all the switchesback to start mode, yes gas is on..and wont start..been trying various choke settings on ,mikuni, no luck,,noyt firing at all, checked fuse by battery, ok..my leg is giving out..
am i missing something,,not even a hint of electrics working,,,should i try starting fluid? HELP the headlite works when i switch it on when not running,,
Re: problem starting 850 [Re: barncobob] #747665 09/02/18 6:39 pm
kommando Online Content
Check the ignition switch is supplying 12v to kill switch and kill switch is supplying 12v to ignition circuit.
Re: problem starting 850 [Re: barncobob] #747689 09/02/18 11:18 pm
Rohan Offline
Originally Posted by barncobob
,should i try starting fluid? ,
Also. Yes, give it a shot of starting fluid when it won't start like that.
If it fires right up, you know its in the carb.
If it still sulks, its elsewhere - could even be spark plugs - sooting up ?
Re: problem starting 850 [Re: barncobob] #747720 09/03/18 9:29 am
iansoady Offline
Sounds like a dead battery to me. Or blown fuse, bad connection somewhere or even dead short.
Ian.
1952 Norton ES2
1982 Moto Guzzi V50
Re: problem starting 850 [Re: barncobob] #747733 09/03/18 12:12 pm
Beach Offline
Thumbs up for dead battery.
1974 Norton Commando
1966 Lightning
1965 Lightning Rocket
1966 Norton Atlas
1967 Norton Atlas
1948 Panhead
Re: problem starting 850 [Re: barncobob] #747749 09/03/18 3:40 pm
I turn the key on and the lights work fine, could the battery be dead then..
im new to this bike,,,,the kill switch(black rectangula r button on bottom) is it a on/off switch or doesit have to be held in to kill engine..
tried new plugs and start fluid. nothing, its not popping, backfiring or showing any sign of spark..
Re: problem starting 850 [Re: barncobob] #747759 09/03/18 4:19 pm
Beach Offline
Try blowing horn with lights on. If they go out battery is dead. Maybe battery has enough for one but not both. I think you have to hold in kill switch. It open hot lead for ignition.
1966 Lightning
1966 Norton Atlas
1967 Norton Atlas
1948 Panhead
Re: problem starting 850 [Re: barncobob] #747972 09/05/18 11:45 am
bill50cal Offline
the kill button is a normally closed switch IE it will supply power to the ign. and stop power when pushed. it is also a known issue of failure to close and is a good place to start looking if no spark..
windy
72 combat
switchbackcreek.com
Re: problem starting 850 [Re: barncobob] #748047 09/05/18 11:16 pm
Rohan Offline
Some electronic ignitions switch thenselves off after a time not running, its not that is it ?
You might want to try running power directly to the ignition system, bypass all the switchery and connections,
see if that brings it back to life. By the time you can do that, you'll know the electrical layout too.
Don't ever forget that a stock Commando is positive earth....
Re: problem starting 850 [Re: barncobob] #749889 09/20/18 5:59 pm
Update..took it to the only guy around here that does British,,turns out the Pazon went bad,,replaced it with Boyer, starts 1st kick now...
Re: problem starting 850 [Re: barncobob] #750038 09/21/18 5:58 pm
bike runs better than ever,easy start and it got rid of that nagging sputtering between 3500-4500.
Re: problem starting 850 [Re: barncobob] #750042 09/21/18 6:54 pm
Read there was a recent spate of DOA Pazons caused but a supplier send a bad batch of components.
Moderated by  Dave Comeau
