Topics68,207
Posts684,470
Members10,936
Most Online14,755 May 5th, 2019
79 registered members (68Newbie),
526
guests, and 853
spiders. |
Key:
Admin,
Global Mod,
Mod
Re: 1968 Triumph T100R Daytona 500 - Super Project
[Re: Mark. L]
#741168
07/08/18 3:22 pm
Jon W. Whitley
Posts: 6,200 |
Hey Dr. Jon, that was a fine bit of surgery you did removing that bolt..... Thanks Mark ! Now, to look through my stash and see if I can find a decent 12 degree AA unit. I do have a Pazon ignition for it but am leaning toward points for initial startup and running right now.
1957 6T Thunderbird 650 1968 T100R Daytona 500 1971 TR6R Tiger 650 1970 BSA A65F 650 1955 Tiger 100 - Project 1971 BSA A65 650 - Project 1972 Norton Commando 750 "Combat"
[Re: Jon W. Whitley]
#741175
07/08/18 4:11 pm
Mark. L
Posts: 179 |
I'm putting a Pazon in my 71 T100R, I was hoping to have the bike on the road about a month ago, but some other non bike related issues happened, what about clutch adjustments, I have new plates and springs and have it pretty much straight, just how much can it be rode without the primary put back on if I want to do some tweaking to the clutch
#741187
07/08/18 6:12 pm
TBolt72
Posts: 304 |
Hey Dr. Jon, that was a fine bit of surgery you did removing that bolt..... Thanks Mark ! Now, to look through my stash and see if I can find a decent 12 degree AA unit. I do have a Pazon ignition for it but am leaning toward points for initial startup and running right now. Ive got a drawer full of advance units. Let me see if I can find one for you.
"I don't want a pickle. I just want to ride on my motor-cicle." Arlo Guthrie Triumphs, BSA's, Nortons, Guzzis, Harleys & a few others.
[Re: TBolt72]
#741239
07/09/18 1:19 am
Jon W. Whitley
Posts: 6,200 |
[quote=Jon W. Whitley]
Ive got a drawer full of advance units. Let me see if I can find one for you. Wow, that's awesome TBolt72 ! I have one in hand and the cam is badly pitted.
#741337
07/09/18 11:32 pm
Jon W. Whitley
Posts: 6,200 |
#741351
07/10/18 1:16 am
TBolt72
Posts: 304 |
[Re: TBolt72]
#741486
07/11/18 10:16 am
Jon W. Whitley
Posts: 6,200 |
![[Linked Image]](https://i187.photobucket.com/albums/x252/crazyroy62/20180709_200621.jpg) $20 plus shipping g. Thanks for looking for the advance unit and posting the pics TBolt72. I have found a decent one in my stash.
#743553
07/29/18 5:08 pm
Red Lapierre
Posts: 354 |
Jon Glad to see things are still moving forward. It looks good.
57 A10 GF 61 A7 61 A10 GF 63 A10 SR 76 CB 125 Honda 76 FLH 2012 FLHTP
[Re: Red Lapierre]
#743554
07/29/18 5:30 pm
Jon W. Whitley
Posts: 6,200 |
Thanks Red. I am working on the gas tank now as well as the oil tank and side cover. I should have the AA unit installed in the next day or two.
#743781
07/31/18 12:49 pm
GrandPaul
Posts: 6,644 |
Sure is looking good!
BSA harness out in today's post...
GrandPaul (does not use emoticons) Author of the book "Old Bikes" Too many bikes to list, mostly Triumph & Norton, some BSA & European "The Iron in your blood should be Vintage"
[Re: GrandPaul]
#743903
08/01/18 10:04 am
Jon W. Whitley
Posts: 6,200 |
Thank you x 2 Paul !
#743929
08/01/18 2:23 pm
GrandPaul
Posts: 6,644 |
Missed the collection time at my neighborhood drop off yesterday, so you'll likely receive it Saturday.
[Re: GrandPaul]
#744078
08/02/18 2:27 pm
Jon W. Whitley
Posts: 6,200 |
No Worries, Saturday is just fine !
#744568
08/05/18 11:08 pm
Jon W. Whitley
Posts: 6,200 |
Proper 12 degree AAU installed as well as the points plate. This was done after bringing the assembly to 38 degrees BTDC, confirmed with both valves closed on RH cylinder, pointer on primary cover pointing to line on alternator rotor aaand timing tool dropped in slot in crankshaft located at the timing plug at the rear of the cylinders.
Getting closer !!
#748507
09/09/18 3:46 pm
Jon W. Whitley
Posts: 6,200 |
Slowly but surely getting things done. Next task is the oil tank. Gas tank with base coat of silver. ![[Linked Image]](https://i.imgur.com/9a86NfT.jpg) Side cover/toolbox stripped and getting ready for some filler to be applied. I hammered most of the deep gash/dent out from the backside. ![[Linked Image]](https://i.imgur.com/8kaj7nF.jpg) ![[Linked Image]](https://i.imgur.com/7AEWB6b.jpg) A PO had cut the middle of the toolbox out with snips or something  I just used my Dremel to clean up the jagged edges and leave it be. ![[Linked Image]](https://i.imgur.com/ewGKfFn.jpg)
#749081
09/13/18 11:32 pm
Jon W. Whitley
Posts: 6,200 |
#749084
09/13/18 11:40 pm
Jon W. Whitley
Posts: 6,200 |
#749131
09/14/18 11:57 am
kurt fischer
#irideslow
#irideslow
Posts: 2,626 |
Lookin' good, Jon! The joys of salvaging these old bikes, bit by bit. Re. Bondo, maybe you do this already ... to cut down on sanding, I use a SurForm file before the Bondo is fully hardened, to shave down the excess before sanding. HTH
Kurt
#749136
09/14/18 1:46 pm
Red Lapierre
Posts: 354 |
Yes Jon it looking good I know it has not been easy. Red
[Re: Red Lapierre]
#749141
09/14/18 2:13 pm
Jon W. Whitley
Posts: 6,200 |
Lookin' good, Jon! The joys of salvaging these old bikes, bit by bit. Re. Bondo, maybe you do this already ... to cut down on sanding, I use a SurForm file before the Bondo is fully hardened, to shave down the excess before sanding. HTH  Thanks Kurt ! I do have the files to cut the Bondo down but just using 80 grit on it for this job for starters. Yes Jon it looking good I know it has not been easy. Red
Thanks Red. Not easy like you say but I'm enjoying it !
#749438
09/17/18 12:32 am
Jon W. Whitley
Posts: 6,200 |
Coating the oil tank with sandable filler primer. ![[Linked Image]](https://i.imgur.com/ZgjsOyc.jpg) Side cover first coat of self-etching primer. ![[Linked Image]](https://i.imgur.com/3nNoj5y.jpg)
#750267
09/24/18 7:34 am
Stuart
Posts: 10,013 |
Hi Jon, Post 713091. Test fitting the coils to the frame. I found a set of coils with the 99-1052 clips. With the standard spacers, they cause the largest part of the coils to contact the gas tank recesses. This is with the 2.5 gallon U.S. spec tank. I like this setup though. ![[Linked Image]](https://i.imgur.com/Q1Oi6gD.jpg) ![[Linked Image]](https://i.imgur.com/NJUdyVD.jpg) 'Fraid I've only just seen this post;  advance apologies if you've solved the problem already. An educated guess says the coils in your pictures are Lucas 17M12 or pattern? When I was building up my T100, I also encountered problems fitting a US-market tank over 'em.  Afaict, the problem is - certainly on late-1960's US-market tanks - Triumph sized the "gas tank recesses" for the "Siba 32,000" coils listed in the late-1960's parts books; however, while 17M coils appear to have been Lucas's '70-on response, the Lucas coils have the ridge around the terminals end that the Sibas don't appear to have. That said, I didn't fiddle around too long with a US-market tank; the UK & General Export tank has bigger recesses (the Lucas MA coils are fatter), as well as being an Imperial gallon bigger. Unlike other Triumph ranges, certainly '67-on C-range UK&GE and US tanks don't look dissimilar (unless you have the two side-by-side) so the bigger tank doesn't look obviously out of place on a US-market bike. Nevertheless, even with the bigger tank/recesses, I still had fitting problems with what were then being peddled by the trade as "standard" spacers.  In the end, I fiddled around under the tank for a ridiculously-long time (would've been quicker to take the engine out, measure and refit the engine  ) to calculate the length of spacers that gave the same clearance between frame and coils and between coils and tank. This might also be an option with your bike's tank? Btw, if the coils in your pictures are Lucas 17M12 or pattern, the "coil clips" in your picture aren't 99-1052. 99-1052 are sized for the fatter MA coils and, when used with the smaller 17M coils, the gap allows for some anti-vibe padding between coil and clip. Not sure what those similar-looking clips that actually fit 17M coils are, they weren't used on '70 UK&GE bikes with '70-on 17M coils; the British Cub parts company Greystone Enterprises sell 'em, so it's possible they were originally intended for mounting 17M coils on Cubs? Hth. Regards,
#752788
10/14/18 11:26 pm
Jon W. Whitley
Posts: 6,200 |
I haven't been neglecting the Daytona and am still working the bodywork and painting of the sheet metal. Still need to do more work on all pieces and will post pics with the completed progress !!
