57nortonmodel77
57nortonmodel77
Concord Township, Ohio
Request Advice on Front Brake Disassembly
#748042 09/05/18 10:57 pm
1. How do I remove the cable from the assembly?
2. How do I remove the brake arms?
3. What size deep socket do I need to remove the nut that holds the brake assembly?
Re: Request Advice on Front Brake Disassembly
Tracey Spear #748044 09/05/18 11:05 pm
The cable clips around the mounting point. Flip the clip off then pull the entire thing out where the clip pivots
Tracey Spear #748219 09/07/18 7:42 am
And the brake rod is a tight sliding fit on the square shaft so a gentle tap wil drive the pivot into the drum releasing the lever.
Get the part number for the nut then look it up in the Stainless Fastners BSA Triump fastener guide that you downloaded saved and then printed out.
Tracey Spear #748266 09/07/18 6:48 pm
partially fit the nut before tapping the end of the brake cam, the nipple end will soon get destroyed if you don't. sometimes a bit of maintenance spray and a good waggle of the lever frees them off, some are as tight as a......
BSA_WM20 #748526 09/09/18 6:12 pm
Hi Tracey,
14-0303 aka 3/8"UNF aka 3/8"-24.
Fwiw, I fit 3/8"UNF stainless dome nuts to keep crap and water out of the grease nipple (and thus the brake cam). I replace the large o.d. washers with stainless so they don't go rusty where the nut scratches 'em. smile
Dome nut fitted loosely over the nipple can be tapped with a hammer to release the lever from the cam without damaging the nipple. thumbsup
Tracey Spear #748528 09/09/18 6:20 pm
I used one of these to get my brake drum levers off recently. They were a very tight fit, probably never been off before, the puller is a battery terminal puller from Machine Mart . I had to lightly file the puller teeth to a slightkg thinner profile to get under the brake lever edge. The puller was around £10.
Ian
Ianbuck #748587 09/10/18 4:43 am
Ian
This is why I love this place.
Neat idea that I never would have thought of.
Tracey Spear #748631 09/10/18 4:14 pm
The puller head is even indented to the same shape as the grease point, couldn't believe my luck ☺
