Dawg
Dawg
England
Alex Lynch, B Mac, Lenz-a-lot, UncleYeti, harold2019
10774 Registered Users
franko 125
NickL 66
MarcB 54
947,323 mail-order LSR
Topics67,488
Posts675,602
Members10,774
48 registered members (Alan_nc), 346 guests, and 849 spiders.
help to identify bsa qd hub #747901 09/04/18 5:42 pm
luke72 Offline OP
can someone please to identify this hub i have a pre 54 plunger frame A7/A10 need to know if fit because i need to buy all the parts to complete the rear wheel
thanks for the help
Re: help to identify bsa qd hub [Re: luke72] #747953 09/05/18 6:10 am
C.B.S Offline
Parts Dealer
Parts Dealer
That is a "QD" "Crinkle" hub..
Look in a 1950-1953 parts book (plunger) and look in a 1954 (swing arm) book and compare part numbers... If same then find the parts, if not, fin another hub.
Try Mikes Classic Parts, he has a lot of BSA A7 / A10 parts. I'm sure he can help you out
Re: help to identify bsa qd hub [Re: C.B.S] #747965 09/05/18 9:36 am
luke72 Offline OP
i tried different part book but no luck it's a mess to put it together in that way
Re: help to identify bsa qd hub [Re: luke72] #747967 09/05/18 10:58 am
Andy Higham Offline
The hub looks like a pre '55 A/B series and gold star up to '62
The part no should be 67-6136, the part no on the hub does not look like a BSA number. The A50/65 B44 type 68-6114 is identical apart for a thread to screw on the speedo drive dog
Re: help to identify bsa qd hub [Re: luke72] #747970 09/05/18 11:36 am
Andy Higham Offline
Is it "Part No" or "Pat(ent) No"?
Re: help to identify bsa qd hub [Re: Andy Higham] #747989 09/05/18 2:58 pm
V
VicCyclone Offline
V
The later hubs 68-6114 do not have the grease nipple - the hub above is one of the earlier types of which I think there is a difference between Plunger and S/A types. See:-
http://www.britbike.com/ubb/bin/ultimatebb.cgi?ubb=next_topic;f=10;t=007221;go=older for some info
VicCyclone
1965 A50 Cyclone Clubman
1966 Victor GP
1967 Victor Special
1968 Victor Special
1968 A65L
2009 HD FXDC
Re: help to identify bsa qd hub [Re: luke72] #747991 09/05/18 3:20 pm
Peter R Offline
The number stamped on the hub (0570250) is a patent nr, not a part number so that will not get you any further.
The plunger frame type hub can be identified by looking at the bearing mounting, (your second picture). The bearing mount should stick out of the crincled section for the plunger type frames.
Wnen the bearing mounting tube is lower than the crincled section, you are dealing with the later type of hub. (swing arm frame)
Re: help to identify bsa qd hub [Re: luke72] #748428 09/08/18 11:51 pm
trevinoz Offline
That is not a plunger hub, the plunger hub has an internal thread on the non splined side and projects further,
Re: help to identify bsa qd hub [Re: VicCyclone] #748460 09/09/18 5:25 am
Allan Gill Online Happy
As Vic says, the A65 series hubs also have raised rivets, as the earlier ones are countersunk into the hub, they were known for pulling/working loose.
