The Bonneville Shop
CaptainPugwash
CaptainPugwash
Conisbrough,Yorkshire, UK
22 registered members (Alan_nc), 204 guests, and 438 spiders.
10528 Registered Users
franko 90
NickL 66
785,121 mail-order LSR
Topics69,220
Posts674,261
Members10,528
Advise on Carb. Specs #747812
09/03/18 9:46 pm
09/03/18 9:46 pm
Wyoming, USA
Doug F Offline OP
Doug F  Offline OP
Wyoming, USA
Hey All.
Been quite a while but finally getting the old 1966 Lightning back together & ready for Carbs. From all I've read & researched I'll go with the AMAL 930 Premier concentrics.
Was reading another thread here about carb set up & got me thinking which size slider to order them with. I take it the 3 inch is for sea level & keeps it a bit richer.
I'm in Wyoming at about 5100 feet or more & plan to ride up into the hills quite often so I think the 21/2 inch is the better choice for altitude.
Any feedback & tips is much appreciated.
Nothing Like getting those OLD things running like NEW
Re: Advise on Carb. Specs [Re: Doug F] #747830
09/03/18 11:59 pm
09/03/18 11:59 pm
Sydney, Oz
Shane in Oz Offline
Shane in Oz  Offline
Sydney, Oz
Don't you have to lean the mixture for higher elevation?
In that case, you'd probably need a smaller main jet and a 3 1/2 or 4 cutaway slide.
Burlen Fuel Systems should be able to give you some tuning advice, and may even have some technical details on their web site regarding tuning for altitude.
Re: Advise on Carb. Specs [Re: Doug F] #747870
09/04/18 8:47 am
09/04/18 8:47 am
gavin eisler Offline
Higher altitude means weaker settings, usually just the main jet goes down a size or two .
Re: Advise on Carb. Specs [Re: Doug F] #747954
09/05/18 6:15 am
09/05/18 6:15 am
Lancaster, California
C.B.S Offline
Parts Dealer
C.B.S  Offline
Parts Dealer
You can try to prepare any carb for any elevation but at the end of the day a carb will have to be installed regardless of the correct or not correct jets in it . I like to install carbs and jet it to how it would of came from the factory. From there, you can tune it step by step. "predicting" carb jetting causes trouble at times because you may start working backwards.
Start with stock slide, pilot, and main jet and work up/down from there based off how the motorcycle is running
Re: Advise on Carb. Specs [Re: gavin eisler] #748003
09/05/18 4:50 pm
09/05/18 4:50 pm
West Yorkshire
West Yorkshire
Spot on Shane
Agreed,
930 (4 stroke) Concentric's on a 66 On Lightning should have:
no.3 slide
106 needle jet
needle clip in top groove
180 Main jet.
As Gavin said, drop a main jet size, the main jet has some effect from half throttle onwards (and runs solely on jet at full throttle) so there will be some/slight leaning off from half throttle also, more noticeable as you get to full throttle. With this in mind I'd fit a 170 main jet, it won't be overly noticeable if you drop below 4-5000 feet and if you go higher you probably won't notice too much it being a tad richer.
anything above 3000 feet takes effect, then for every thousand feet there is a change again. but if you find it is still too rich fit a 160, needle jet and all other positions should be correct AFTER you have sorted the main jet, working to the next jetting position down.
Re: Advise on Carb. Specs [Re: Allan Gill] #748271
09/07/18 7:57 pm
09/07/18 7:57 pm
Wyoming, USA
Doug F Offline OP
Doug F  Offline OP
Wyoming, USA
Hey, Thanks for ail the good advice Folks.
I'll start with the stock slide & needle & main jet 1 size smaller & go from there. makes sense.
do 1 thing at a time
Was just trying to figure what extras to order with the carbs but certainly don't want to over complicate things
and this was the kind of info. I was looking for
Thanks All
and Allan for verifying the jets I figured I'd need to have on hand.
winter is coming fast here & i still have quite a bit to do on this ,
not sure if I'll get it running in time before snow starts falling & bitter cold.
may end up finishing this winter inside & firing up in the spring.
Re: Advise on Carb. Specs [Re: Doug F] #748369
09/08/18 4:17 pm
09/08/18 4:17 pm
West Yorkshire
West Yorkshire
your welcome and good luck with your project
