chris b33
chris b33
oregon usa
1957 Road Rocket, Payne, Mysticbus, T140v, BradM
11016 Registered Users
franko 136
koan58 72
DavidP 56
1,148,925 mail-order LSR
Topics68,937
Posts690,920
Members11,015
71 registered members (998John), 1,835 guests, and 938 spiders.
Diagnosis please #745460 08/14/18 10:34 am
U
Uncle D Offline OP
U
A65T with new AMAL Premier, Sparx EI & regulator, copper wire HT leads, no resistor caps, B8ES plugs, Lucas coils (2x12v in series). Bike had fried a Sparx EI module apparently due to a faulty rotor (but in hindsight perhaps a lack of resistor plugs or caps)...it was replaced approx 12 months ago & was starting and runnng very well (too bloody well obviously).
I had done about 50km at 65mph when suddenly lost power with backfire and flame out exhaust (a colleague said flame from left pipe). The bike then began to run rough / missing and I reached down and felt the plug caps, getting a shock from the left cap only). Plug inspection revealed soot / dry left plug and normal right plug. One of the alternator plugs was disconnected but not sure if the was caused during my fiddling on the side of the road. Kickback while attempting to start. If it starts, backfires and runs rough, then stalls.
Back home and can report the following.
Battery holds 12.4 volts. Alternator provides 13.5v to battery so it and regulator OK.
Switched out the Sparx module for a Boyer MkIII with immediate improvement but still runnng rough (not firing on right cylinder).
Brand new battery, new resistor plugs (BR8ES), new 12v coils, new Lucas ignition switch. Cleaned all earths /replaced some earth connectors.
Fixed a wire that had come off of the oil indicator lamp in headlight.
Continuity throughout the system with no voltage lost in ignition switch circuit.
Power reaching EI module.
Both old and new coils show same resistance (around 4ohms I think).
Trigger connections at stator are sound with continuity through to EI module.
This is one of those cases where something simple may have been complicated by much fiddling. I'm hoping some of these symptoms ring a bell to someone and might give me a lead.
Thinking of replacing whole EI (to Pazon Sure-fire) but want to be sure it's necessary.
Any ideas? (I have tried copious swearing).
My Giddy Aunt!
Re: Diagnosis please [Re: Uncle D] #745485 08/14/18 4:14 pm
gavin eisler Online Content
EI for twins works better with 6 volt coils , try swapping your coils over and see if the rough running swaps sides.
Re: Diagnosis please [Re: Uncle D] #745489 08/14/18 4:44 pm
bodine031 Online Content
I thing 6 ohms is max on EI twin ignitions. My Hornet has a BB with a 3 ohm HD single, dual tower, dual fire 12v coil, copper core plug wires w/ NGK 5 ohm caps and BP7ES for years works fine
Re: Diagnosis please [Re: bodine031] #745494 08/14/18 6:19 pm
LarryLebel Offline
The way you have it now the coils are only getting 6 volts. Wire them in parallel so they are getting 12 volts.
DO NOT DO THIS
Re: Diagnosis please [Re: LarryLebel] #745496 08/14/18 6:29 pm
I know nothing about Sparx, but I think you can’t do that with Boyer or Wassell electronic ignition.
Re: Diagnosis please [Re: Uncle D] #745505 08/14/18 7:57 pm
John Healy Online Content
Ditto TT's comment
Re: Diagnosis please [Re: LarryLebel] #745509 08/14/18 8:27 pm
Stuart Offline
Uncle D,
NO!
Absolutely Do Not!
Like most e.i. for Britbikes, a Sparx e.i. has a single switched output to the coils. A '12V' Lucas or pattern coil draws between 3 and 4 Amps. If you connect more than one in parallel to the same switched output, Amps are added together. Like most e.i. for Britbikes, a Sparx e.i. cannot switch 6 to 8 Amps ...
Re: Diagnosis please [Re: Uncle D] #745560 08/15/18 6:10 am
BSA_WM20 Offline
I ran my 73 ( 71 rebuild ) A65L for 6 years on & off using the original 12 V coils with a red Boyer ( was a while ago )
It ran fine around town but on long runs at high RPM the ignition would play up.
We are talking 80 mph or better.
Now the Boyer sat in the tool tray under the seat so not the best cooling wise.
Other than that there was no problems ignition wise other than when we were having a joint run wih the NOC & I was trying to keep the Commandos in sight so spent a lot ot time reving hard in 3rd on the twisties.
Re: Diagnosis please [Re: BSA_WM20] #745569 08/15/18 8:15 am
U
Uncle D Offline OP
U
Thanks Trev, this feels familiar. The bike was running beautifully...(in fact I had just overtaken a caravan and gesticulated for their pulling out in front of me)...I had been sitting on 65-70mph for about 40km when I just lost all power. This was not a gradual break-down ...there was no sign of it coming which indicates a failure of something. The original coils measured the same resistance and it is unlikely both would fail simultaneously. I only changed them as I had a new pair in the shed and wanted to eliminate them as an issue. Same with the battery...its wasn't brand new but held and put out 12+ volts. My EI sits on top of the oil tank so not the coolest location either.
I think it is simply the EI black box again (due to a combination of factors accentuated by a long hot run)... unfortunately I wont know for sure until I replace it.
PS: There is no way I would wire the two coils in parrallel...i do remember something from my year 11 physics class...actually, that is probably the only thing.
My Giddy Aunt!
Re: Diagnosis please [Re: NickL] #745570 08/15/18 8:17 am
U
Uncle D Offline OP
U
Old heap?! Wash your mouth out. She is a beautifully restored machine that does not leak or burn oil..she just throws a hissy-fit every now and then. Actually I think God was putting me in my place as I was having waaaayyy too much fun!
My Giddy Aunt!
Re: Diagnosis please [Re: Uncle D] #745661 08/16/18 3:11 am
htown Online Content
The Boyer MKIII is very sensitive to low voltage. I've replaced a MKIII box with a MKIV with good results. Most of my bikes have Pazon Surefires which also tolerates lower voltages. Before you scrap your unit though you need to check the voltage supply at the white wire while putting a load on the system. Simply checking it with a voltmeter with no load doesn't tell you much. Procedure is explained here. See the section on checking for voltage drop, although the whole bit is worth going through.
http://vintagebikemagazine.com/technical-articles/Boyer-trouble-shooting/
1978 Bonneville T140E
1974 Trident
1970 BSA Thunderbolt
1971 Norton Commando
1973 Norton Commando
1974 Norton Commando
2018 Kawasaki Z900RS
Re: Diagnosis please [Re: NickL] #745676 08/16/18 6:56 am
U
Uncle D Offline OP
U
Originally Posted by NickL
My apologies old chap, no offence intended. I own and ride one of these old heaps as well.
The description of the on road failure indicates the progressive loss of power supply.
Maybe your alternator lead was the culprit and the battery was being continually drained.
The dying out of the engine, the kicking back on restarting with the subsequent rough running
all point to a poor battery voltage/power supply.
If one plug is fouling more than the other then it has nothing to do with the EI, the EI just switches
the coils on and off same as your old points did, only it switches them both on and off at the same time.
With crap fuel now the ignition does need a bit more power and may not be igniting as well as it could be.
The fitting of a pair of 6 volt coils or a dual output 12 volt one would improve matters but it will impose
a larger load on the power supply.
Failure of the EI is normally total, no restart at all.
Sitting the box on top of your oil tank is not ideal but no real hardship for the EI especially as you were
switching a small 8 ohm load = less than a couple of amps. Losses across the output are typically around
1.8v so 1.8 x say 2 amps = 3.6 watts. Very little ignition box self heating.
Before scrapping the existing system i would first check out the battery and charging system, you may
be spending money unnecessarily replacing the ignition.
Nick
yes you're right Nic...there are plenty of possibilities before a fried EI.
When I sat down in the comfort of the cave and started to look, I did find one of the alternator plugs undone; the trouble is that I'm not sure if this was the cause (as you described it) or was as a result of my roadside fiddling. There were a crew of mates looking over the bike, many with much more knowledge than me so it would be surprising if no-one spotted the unplugged wires...but it is still possible (especially given that the vast majority were Harley riders who were were more focussed on giving me crap for breaking down.
The battery is now brand new, as are the coils and I have given a fair bit of attention to electrical continuity and joints but have found nothing...yet.
My Giddy Aunt!
Re: Diagnosis please [Re: htown] #745677 08/16/18 6:58 am
U
Uncle D Offline OP
U
Thanks Htown
I found and printed that article last night and will work through it on the weekend. Although my EI is a Sparx, I expect that the differences are few and far between.
My Giddy Aunt!
Re: Diagnosis please [Re: Uncle D] #745712 08/16/18 1:24 pm
Allan Gill Online Happy
However you refrence the bike (old heap or beautifully restored machine) a non running bike is that regardless and the principles of how it runs doesn't change either...
Simple thinking though... and you have the ideal situation.. As if it is running on one cylinder then it can only be the things which are not common that are causing fault....
2 cylinders (one giving fault)
1 carb supplying both pots
1 ignition supplying both pots
so in different, they have their own spark plugs (change these before anything)
they have their own HT wires and leads (check these next)
They have their own set of valves (check these after that)
and they have their own exhausts, however unless a wombat has climbed up there, then I doubt that ones the problem.
Re: Diagnosis please [Re: NickL] #745919 08/18/18 11:22 am
U
Uncle D Offline OP
U
Righto, I've been over this thing so many times that the original symptoms are probably not much use.
New battery. No voltage lost in ignition circuit (new ignition switch)
New resistor plugs. Continuity in leads.
Continuity between stator plugs and EI. Resistance across stator plugs is 140 ohms. Wiring looks solid. Rotor is not slipping. Nothing seems to have moved since it was running well.
Alternator rotor is new and charging at 13.8v (I measured this when I managed to start it with mate's Boyer...more luck than anything).
New coils (12v in series). Resistance across single coils...both 4.5ohms...9ohms across the two.
Here are the current symptoms.
Farting /backfire while kicking over...wants to start but won't.
I currently don't have the air filter on (pancake style) to allow access to wires...I know this will richen the mixture but surely can't be causing these symptoms?
The fact that I've got spark at all must mean the EI unit is OK....right?
So the place to look is poor connections and certainly some of those around the coils could be better...that's my next focus.
Any suggestions?
My Giddy Aunt!
Re: Diagnosis please [Re: Uncle D] #745921 08/18/18 11:29 am
U
Uncle D Offline OP
U
Ok here's a random thought.
Before the run on which I encountered the problem, I adjusted the tappets. I had the correct gap specifications and didn't over-tighten (slight grip on the feeler gauge).
The head had recently been professionally refurbished (valve guides, seats...even had seals added).
Any chance these symptoms are associated with something letting go in the top of the engine?
My Giddy Aunt!
Re: Diagnosis please [Re: Uncle D] #745925 08/18/18 12:13 pm
Andy Higham Offline
Check the tappets again
Most ignition problems are either carb or mechanical related
Re: Diagnosis please [Re: Uncle D] #745928 08/18/18 12:58 pm
Stuart Offline
Lack of an air filter without any other carburation changes normally weakens the mixture (more air). Could be giving the symptoms, especially in combination with something else.
Can be a symptom of bad timing. Have you used a crank locating tool to find 38o (or whatever) BTDC and you're sure it was 38o (or whatever) BTDC, not TDC?
Don't know if Sparx e.i. has the same problem but Bransden have long had the problem of the odd "Stator Plate" wired incorrectly - when the Black/White and Black/Yellow wires are connected apparently correctly, the connections on the Stator Plate are actually reversed electrically and the timing is out wildly ... facepalm
One way of being sure is make up a wire to connect battery -ve directly to the "Transistor Box" White wire (assuming standard 'positive earth'). Put a fuse in this wire in a position where you can access it sitting on the bike, because it's the only way of stopping the engine - ignition switch or kill switch won't. Also insulate the end of the standard White or White/Yellow wire from ignition switch or kill switch.
Also, how is are the Sparx Transistor Box and the coils series earthed? Lucas believed using random bits of bike was a crap idea long before e.i. was invented, I was advised against it by John Carpenter, whose Mistral Engineering company handled all sales and warranty work for Lucas Rita e.i. Boyer-Bransden/Sparx/Wassell e.i., I've always connected the Transistor Box Red wire directly to battery +ve (extending the Box wire if necessary) and the coils' series either also to battery +ve or something on the engine, with a wire connection between engine and battery +ve also.
It's much of the battle, but the Box triggering the spark at the right time in suck-squeeze-bang-blow is another necessity ...
+1.
Re: Diagnosis please [Re: Uncle D] #745936 08/18/18 3:10 pm
I had a Sparx that the black white and black yellow wires were wrong. Would start but barely run. Switched them around and ran okay. Eventually binned it and bought a Pazon Surefire. Not impressed with Sparx quality at all.
1974 Trident
Re: Diagnosis please [Re: Stuart] #745981 08/18/18 10:23 pm
U
Uncle D Offline OP
U
This bike has run very well with the stator plate wires in their current position, new alternator rotor and timing set up. This is all still firmly mounted and wires intact so I don't expect anything has changed here.
The + terminal on the second coil is earthed back to the battery + , as per the Sparx installation instructions. This is the same terminal as used by the EI red wire so I assume this is how the box is earthed.
I have read that it is recommended to earth the engine to the battery? I currently have 3 red wires coming out of the loom that are earthed (together) at the battery + and then the battery + to the frame (small clean lug under the seat). There is also an earth at the engine brace bolt under the steering head (shared with the Zener diode heat sink) which leads into the headlight. I assume this is the earth connection between the engine and battery. Do people rely on the brace providing the earth connection to the engine or should I extend the earth wire to the engine (at the other brace bolt) directly?
I can't see any other dedicated earth wires runnng from the engine to the battery +. Are there other locations people use to earth the engine to the battery?
If something had let go in the rocker box, surely I would have head something when the bike lost power....nonetheless, while the tank is off I will have a look.
I will continue to replace all spade fitting to ensure good connections and then put the air filter back on and give it a kick. I can't help thinking that this is something very simple (or a combination thereof).
My Giddy Aunt!
Re: Diagnosis please [Re: NickL] #746028 08/19/18 9:11 am
U
Uncle D Offline OP
U
Checked tappets today...exactly where I left them (.008 inlet & .01 exhaust...slight grabbing on the feeler). All springs move up and down as they should.
Used an Allen key in timing hole and the rotor mark lined up with the timing pin as did the indicator screw and hole on the stator...nothing had moved.
Replaced all spade connectors on coils and replaced air filter.
Removed and blew out the pilot jet (AMAL Premier)... again as I can't get an idle. Set the carb back to default tune (air 1.5 turns out) and turned up the throttle stop.
Checked continuity (good) and resistance (none) the in leads.
Bowl is filling with fuel
She wants to start both with the existing Sparx EI and with a Boyer MkIII module...but backfires with almost every kick. Boyer seems to get a slightly better response but I may just be imagining it.
It ran for a little bit and had warm air at both exhausts ( but not enough for any tell-tales on the plugs). Running really rough, would not idle and did not like any throttle.
I can't help thinking this is something simple. Not overly difficult confident about the leads just because of the screw-in cap design...but they show continuity.
The only other thing I have not studied in detail is the stator as it has not moved, shows correct resistance and continuity to the EI.
My next step will be to remove the coupling plug between EI and wiring in case there is a poor connection that I can't see /feel from the outside.
Frustrating...but that's Old bikes.
(Ive got a 58 Super rocket that is new to me sitting in the shed waiting on a box of parts from NZ so I would like to get this PIA out the way before I launch into the next)!
My Giddy Aunt!
Re: Diagnosis please [Re: Uncle D] #746040 08/19/18 12:24 pm
The original symptoms suggest a disconnection in the power supply to the EI unit, I have had exactly the same when the ignition supply fuse ( non stock wiring) blade connector rattled loose, easy fix in my case.
For your fault I would try a hot wire , by pass the ignition switch and see if this improves things, if so the ignition switch contacts are the source of your problem, if you have a meter set to low ohms you can check the switch function by metering across the terminals and operating the switch, it should break to infinity and close to almost zero ohms, any fluctuation or non repeatability of the closed switch readings means a fail.
Edit, its a new switch, still worth checking though.
Re: Diagnosis please [Re: Uncle D] #746124 08/20/18 4:25 am
Mitch Offline
double check the ignition timing... like the whole procedure for the setup.
Re: Diagnosis please [Re: Uncle D] #746199 08/20/18 8:27 pm
Just to add a bit more sauce to the pot, Before my Boyer shed its power supply , it had been dangling by its leads, for how many miles dunno? loads probably, the velcro had let go, bouncing around behind the side panel. Once the connection was sorted , back to normal, Boyers are pretty tough. My 18 year old Boyer is still happily firing NGK plugs ( all be it through new 6 volt coils) which were rescued from the bin in the bike shop 8,000 miles ago, discarded as diesel fouled . The Boyer I have is a red one Mk IV maybe.
I am on my 3rd ignition switch since new ( presuming it had its original when I first got it)
Re: Diagnosis please [Re: gavin eisler] #746499 08/23/18 8:59 am
Stuart Offline
If spark plugs are being fired by single-ended (one HT lead) coils, that circuit relies on good connections between the plugs ('earthed' through their connection to the engine) and the other end of the coils' HT windings. If an engine uses points, the ignition LT circuit also relies on a good electrical return path to battery +ve. If the engine has an oil pressure switch, that 'earths' through its mounting on the engine. Imho, it's good to have an obvious connection between engine and battery, rather than relying on connections between other components in between.
The boyer I have is a red one
MicroDigital. Mk.4 is still analogue so still Black box.
