KarlB
KarlB
Kent
Support Your #1 Forum
Buy BritBike's staff a coffeeStill here since 1996.. Click here to buy BritBike staff a coffee.
44 registered members (Al de Haas), 373 guests, and 729 spiders.
brennan devine, sivaraj, LarryL, chickin, Hill Easterwood
10612 Registered Users
franko 124
koan58 78
Mori55 71
reverb 70
NickL 61
830,984 mail-order LSR
Topics67,834
Posts671,990
Members10,612
tappets again #744230
08/03/18 7:02 pm
08/03/18 7:02 pm
Springfield Nebraska
Richrd Offline OP
Richrd  Offline OP
(1974 t150 } the book shows tappets with a flat on the shaft and a large hole thru the block. mine have neither, there is a small hole drilled in the side of the block that appears to go nowhere.
Is there any harm in using what was in the bike, or should they be replaced?
75 commando interstate
06 Suzu..Suzu.. uh appliance
couple of beesas a ducati
and the Snake Bike
and a Honda?
Re: tappets again [Re: Richrd] #744311
08/04/18 7:41 am
08/04/18 7:41 am
Norfolk, UK
L.A.B. Online content
L.A.B.  Online Content
Norfolk, UK
71-3213 "Triumph T150 Tappet/Cam follower Set"
http://www.vintage-motorcycle.com/i...d=26869&suchtext=tappet&limit=80
The '74 parts book shows oil feed tappets for the early pressure-fed tappet blocks which were not used on the later triples.
70-8917
http://www.klempfsbritishparts.com/TAPPET--TRPL--EARLY--WOIL-F-0
Some twin cylinder tappets have the large hole but drilled side to side not front to rear as shown on the drawing so those holes shouldn't be on the drawing at all.
http://www.vintage-motorcycle.com/i...=4&pid=95&id=19850&limit=390
Re: tappets again [Re: Richrd] #744316
08/04/18 8:59 am
08/04/18 8:59 am
Great Southern Land
tridentt150v Online content
tridentt150v  Online Content
Great Southern Land
Looks std for a '74 to me Richrd.
Re: tappets again [Re: Richrd] #744368
08/04/18 3:05 pm
08/04/18 3:05 pm
Richrd Offline OP
Richrd  Offline OP
then there is no direction for the drilled hole?
and the Snake Bike
and a Honda?
Re: tappets again [Re: Richrd] #744395
08/04/18 6:21 pm
08/04/18 6:21 pm
shel Offline
shel  Offline
Not anymore, I have a block of wood I drilled shallow holes in many years ago, when I remove tappets and push rods I put them in this block of wood so when I put stuff back together they all go back in the hole they came out of. Maybe unnecessary but I think the parts that bedded in together should probably stay together.
Re: tappets again [Re: Richrd] #744402
08/04/18 6:31 pm
08/04/18 6:31 pm
John Healy Offline
John Healy  Offline
When the tappet is hollow you need a hole to let out the expanding air as you attach the stellite pad. Other wise the air would have to escape through the same surface you are trying to attach the pad. This will upset the bond.
It is a common practice when brazing or silver soldering a tubing where there is no place for the expanding air to go as you weld the joint.
Re: tappets again [Re: Richrd] #744487
08/05/18 9:33 am
08/05/18 9:33 am
Great Southern Land
Great Southern Land
As shel said, you must re install them in exactly the same location and orientation - unless you are having them surface ground, then it is not critical. If you don't get them re surfaced and mess up location/orientation then the bike can suffer from increased follower and/or camshaft lobe wear.
Re: tappets again [Re: Richrd] #745035
08/09/18 10:17 pm
08/09/18 10:17 pm
ca, us
DMadigan Offline
DMadigan  Offline
ca, us
You should blue the tappet surface, install them, turn them against the cam then check the tappet face. That way you can check the tappets are running square to the cam and the curvature is correct - not running off or not wiping close enough to the leading/trailing edges. Only needed for a carefully built motor.
