KarlB
KarlB
Kent
Support Your #1 Forum
Buy BritBike's staff a coffeeStill here since 1996.. Click here to buy BritBike staff a coffee.
45 registered members (Al de Haas), 378 guests, and 729 spiders.
brennan devine, sivaraj, LarryL, chickin, Hill Easterwood
10612 Registered Users
franko 124
koan58 78
Mori55 71
reverb 70
NickL 61
830,984 mail-order LSR
Topics67,834
Posts671,990
Members10,612
Racetech Emulators for damper rod forks? #744436
08/04/18 8:52 pm
08/04/18 8:52 pm
PNW
spuggy Offline OP
spuggy  Offline OP
PNW
Hey guys,
I need to refresh/check the forks on my 1960 TR6; decided I'd like improved damping, so was looking into upgrading/updating at the same time.
Surrounded myself with parts diagrams and it seems you'd have to change many parts to use the 64-67 competition damper rods - let alone upgrade to the even later shuttle-valve type damping (where you'd certainly be replacing most/all of the internals). And it's not even clear if either setup can be massaged into co-operating with the earlier fork sliders (anyone done this and know off-hand?)
In comparison, Racetech Emulators seem like a laughably trivial install; drill extra holes in the damper rods so that they don't anymore, adjust the valve to the desired rebound setting, drop it in, change springs out for Racetech ones, re-assemble, re-fill with the correct oil/amount for your desired compression setting, job done.
Which apparently provides real adjustable damping; folks with later damper-rod forked bikes generally say they're an improvement (although accessing the "adjustability" does involve dismantling/fiddling about).
But overall, it does seem very intriguing - anyone used them or have any experience with them?
There looks to be zero hits on this board searching for "racetech emulator", although google results seem to indicate that many Guzzi/Harley/Yamaha riders - as well as Triumphs less than a decade old - mostly think they're not a waste of time/money, even though some are less enthused than others.
Pretty low bar to get an improvement from stock, so seems worth a try...
Andy
1960 TR6: Skunkworks and Sympathetic restos (sorta concurrently, on the same platform)
Re: Racetech Emulators for damper rod forks? [Re: spuggy] #744478
08/05/18 6:01 am
08/05/18 6:01 am
Ask the question where are you going to fit them if there is no damper tube to sit them on and also no internal spring to hold them in place.
Re: Racetech Emulators for damper rod forks? [Re: kommando] #744546
08/05/18 7:51 pm
08/05/18 7:51 pm
PNW
spuggy Offline OP
spuggy  Offline OP
PNW
Heh. Why, yes, that would be a problem. smile
Maybe you're thinking of the earlier pre-units though? (I can't quite grasp what the heck is going on in their parts diagram - "pressure tube"? huh?)...
My parts diagram for the 1960 duplex 6T, T110, TR6 & T120 shows both damper tube & internal springs; I was under the impression the forks didn't go external spring until 1964 MY.
Re: Racetech Emulators for damper rod forks? [Re: spuggy] #744591
08/06/18 4:38 am
08/06/18 4:38 am
I was considering the 69/70 shuttles, anyway I did solve all these issues and fitted them but instead went Showa 20mm cartridge which needs some steel thin wall precision tubing to replace the alloy Showa tube or the oil cannot freely pass outside the cartridge.
Re: Racetech Emulators for damper rod forks? [Re: spuggy] #747007
08/28/18 2:59 pm
08/28/18 2:59 pm
UK - Bucks
Steve Wilson Offline
UK - Bucks
Fitted these cartridge emulators - or Fork Valves in a couple of sets of forks - worked well for me
There seems to be two options - Racetech or YSS
I've bought both and the quality appears similar - Racetechs customer support is very good as is their website.
http://www.racetech.com/
http://www.racetech.com/HTML_FILES/EMULATORGV.HTML
YSS parts are a bit cheaper generally but support is mainly from vendors like Brook
https://www.brooksuspension.co.uk/fork-internals/yss-fork-emulators.html
As mentioned job is a strip and rebuild of the forks plus Drilling the damper rods (doesn't have to be precision at all just enough, big enough holes) and cutting or making spacers to re-set spring preload.
New springs are not mandatory. Racetech have recommendations but check what you have first they may be spot on. And its not difficult to just change the springs later on a lot of forks.
They also recommend oil viscosity and level.
Just a cautionary note on fork oil - the viscosity varies a lot so make sure you know what you have - or at least what you put in. some 15w is heavier than some 20w and vice-verca (see the chart below)
http://mahonkin.com/~milktree/motorcycle/fork-oil.html
For what its worth Castrol seems consistant here in the UK -
SJW
Re: Racetech Emulators for damper rod forks? [Re: Steve Wilson] #747041
08/28/18 9:24 pm
08/28/18 9:24 pm
Stuart Offline
Stuart  Offline
Hi Steve,
confused The chart puts Castrol "10wt" between a 3.5 and a 4.25 ... "15wt" and "20wt" are more consistent but still a substantial gap between "Reported Viscosity Index" and "Recalculated Viscosity Index".
I've been using Bel-Ray since I started fiddling with suspension, the chart appears to show all viscosities are far more consistent than Castrol's?
Re: Racetech Emulators for damper rod forks? [Re: Stuart] #747337
08/30/18 10:06 pm
08/30/18 10:06 pm
UK - Bucks
UK - Bucks
Well - when I looked at the info that was the conclusion I came to - right wrong or otherwise. The best option - having chosen your poison is to stick to it.
The really important message is that one companies 15w can be very different from another's. So when you change the oil from 15w to 20w you could actually be going anywhere (including the other direction!)
SJW
Re: Racetech Emulators for damper rod forks? [Re: spuggy] #750607
09/26/18 8:07 pm
09/26/18 8:07 pm
Skudeneshavn Norway
Stein Roger Offline
Stein Roger  Offline
Skudeneshavn Norway
On a 1960 fork you could use the earlier damper tube, sans the rod and internal bits, with holes drilled and the top of the tube modified to accommodate a seal and to suit the emulator. However, as kommando pointed out to me in a similar discussion a while back, the inside of a typical Triumph stanchion is pretty rough, and won’t seal well unless machined. And I don’t know if anyone makes emulators small enough to fit in there?
Btw, I think the early damper tube forks can be made to work pretty well, and certainly better than the 64-67 pogo sticks.
