Thomas4
Thomas4
Thun, Berne, Switzerland
34 registered members (benny jensen), 368 guests, and 527 spiders.
Kelly David, PATony, Bro Vintage, Stuart Kirk, celcius232
10563 Registered Users
franko 93
NickL 70
806,767 mail-order LSR
Topics67,426
Posts668,704
Members10,563
Page 2 of 3 1 2 3
Re: replacing Mikunis with Amal, BSA lightning [Re: redrooster] #744757
08/07/18 1:48 pm
08/07/18 1:48 pm
melbourne florida
bodine031 Offline
bodine031  Offline
melbourne florida
I have a single 30mm Kuni on my 64 Hornet. clip in the middle, low jet around where you are, 1 turn out on the A/F screw and it starts and idles hot ,warm, cold just fine. pulls off idle fine
B-B ign. with (1) 3 ohm dual tower 12v factory HD take of coil. That's my set up that works for me that bike. I ride it everyday using reg/unleaded go juice with no additives
Re: replacing Mikunis with Amal, BSA lightning [Re: redrooster] #744781
08/07/18 6:28 pm
08/07/18 6:28 pm
Bristol England
redrooster Offline OP
Bristol England
Hi all, the mik's came in a box with the bike when I got it so I have been riding with them for a while, judging by all replies I think I will persevere and get them right, sort out the mounting and all should be good. Been persuaded off of the Amals.
Konstantinos, my bike is not classic look or build Brief description is 64 star,69 or 70 or 71 later lightning head ? ,mikuni carbs, old Boyer ignition (micro power with micro power ignition coil). External oil filter fitted with later splitter/top end feed (69 I think) fitted before filter and outside of tank, Gold star front end with Eddie Dow TLS brakes, strange bars but comfortable (found in parts pile) that no bar end mount mirrors fit in to ?, Front light of unknown origin, Smiths clock on custom mount. Rear frame chopped and rigid, custom built seat (one rider only), back rest, oil tank, chain guard , rear fender. rear light mount, oil filter mount. Think I might be getting carried away here but.
You either love it or hate it, to me it is a work of genius.
Re: replacing Mikunis with Amal, BSA lightning [Re: bodine031] #744783
08/07/18 6:48 pm
08/07/18 6:48 pm
Bristol England
Bristol England
Hi Bodine,
So your clip is on 3, but your bike is way different.
Clip is on 4, cutaway 2 1/2, pilot jet 30 screw 1 1/2 out and still looking lean.
I have decided to look at this in another way, I will keep the Mik's , mount them properly as the advise I have had.
Then start on the jetting
Re: replacing Mikunis with Amal, BSA lightning [Re: redrooster] #744799
08/07/18 8:19 pm
08/07/18 8:19 pm
Farnham, Surrey, UK
gunner Online content
gunner  Online Content
Farnham, Surrey, UK
Hi Redrooster,
I have a 68 A65 Firebird fitted with AMAL 930 carbs (not the Premier version). I purchased these carbs from Burlen about 6 years ago when I was completing the rebuild of my bike. So far these carbs have performed well although my annual mileage is limited due to parenting commitments. I deliberately omitted the choke slides from both carbs as I felt this was a useless design and I can easily start the bike just using the ticklers, even in the UK winter. My feeling is that the standard AMAL Concentric is a good carb when new but it does have some drawbacks as already noted. Part of the problem is that it was not a high quality design when new and when combined with poor maintenance over several decades a bad reputation arises. I have no doubt the new Premier carb is better and more durable than the original AMAL Concentric, however I think we should show some respect (as Trevor suggests) to all the millions of concentrics which have kept BSA's, Nortons, Triumphs etc. running for all these years.
For what its worth, I'm running a single Mikuni 34 on my 750 Norton. It runs great and starts virtually first kick helped by the choke lever/enrichment circuit. I'm also using a JRC carb on my B44 also with a choke lever/enrichment circuit. Agreed that these carbs may look slightly odd on a British bike, but they do have a plus side.
I would keep the Mikuni;s and just get them jetted right. Maybe you can find a rolling road nearby and get them dialled in spot on.
Re: replacing Mikunis with Amal, BSA lightning [Re: redrooster] #744807
08/07/18 8:49 pm
08/07/18 8:49 pm
kevin roberts Online content
kevin roberts  Online Content
Originally Posted by redrooster
Can anyone post a picture of how they have mounted there Mik's on a brit bike twin ?
[Linked Image][Linked Image][Linked Image][Linked Image][Linked Image][Linked Image][Linked Image][Linked Image][Linked Image][Linked Image][Linked Image]
maybe there's something useful here? i've run 32mm and now 34mm mikunis on my morgo commuter for almost 40 years, and also use the same mounts for the keihin FCRs inb my LSR machine.
spigots are available for bothe the screw-in and bolt-on carburetor manifolds.
side covers on an OIF are always an issue. i used to use 1976 honda CB360 covers, which are a perfect fit. now i just don't run any. on a dry frame, carb extensions bump into the oil tank, but short mikunis shouldn't be a problem.
Re: replacing Mikunis with Amal, BSA lightning [Re: redrooster] #744809
08/07/18 9:01 pm
08/07/18 9:01 pm
Athens Greece
Konstantinos Offline
Athens Greece
Hi Redrooster,
I thought that you have a stock bike with modified engine but it' s modified at all
So no problem to keep VM because unfortunately they are much reliable than Amals
Just be sure to have right jets and good quality rubber manifolds
VM have old classic look.
My first reply was for Kevin with keihins.
Here in my country most of my friends have on their british bikes single VM because it' s more easy to fix it
But friends with old dual concentrics are faster so if you have dual VM are better at all.
I hear that old concentrics are much better than new and I have experience with my T140 when It was with stock head
And AMAL MKII 30mm with made in England bodies never had problems for many miles but when I modified to eight
valve and fitted New 36 mm AMAL MKII made in Spain after of 15.000 km the slides were bordeline.
So keep Mikunis I have the same opinion with gunner.
Re: replacing Mikunis with Amal, BSA lightning [Re: kevin roberts] #744816
08/07/18 9:42 pm
08/07/18 9:42 pm
England
F
ferretjuggler Offline
F
England
Just out of interest what sort of gas milage are you getting with twin 34mm Mikuni VMs ?
I've got no experience of them on a Triumph, but I swapped the 34mm Mikuni CV carbs on my XS650 for a pair of 34mm Mikuni VM slide type.
Turned it from a tame little kitten into a ferocious snarling beast - with no other mods.
But fuel economy went from 50+ mpg (imperial gallons) to the low 30s
Re: replacing Mikunis with Amal, BSA lightning [Re: Konstantinos] #744817
08/07/18 10:10 pm
08/07/18 10:10 pm
Originally Posted by Konstantinos
I wanted to have a pair of keihins on my T140 eight valve to see how it runs on the road.
I am very sure that works great.
And I am sure that your bike is flying with them but they are not looking good on classic Brit bike like the box section swingarm on my featherbed trident works great but not looking good to be honest
I think the reason is what you want from your bike.
If you want performance you need modern goodies.
If you want classic look have to stuck with stock parts.
i'm sorry, konstantinos, i missed this post of yours.
yes, what you change on the machine you ride is completely a function of what you want from it. if complete originality is the most important thing, then you must use original-style carbs. but you must also do without electronic ignition, modern tires, brighter lights, updated charging systems, and so on. most people compromise somewhere in the middle.
i use the keihins for a race machine. they would work very well on a street bike with a fabricated airbox, but i have used mikunis on the street for decades and they work well for me. i also have some concentrics, and they work too, but when they wear out i usually replace them with mikunis.
Re: replacing Mikunis with Amal, BSA lightning [Re: ferretjuggler] #744820
08/07/18 10:17 pm
08/07/18 10:17 pm
boy, i don't know. i never measure it. 35 years ago my machine was an unmodified 650 with concentrics, and got 43 mpg, US gallons. then i installed 32mm VM mikunis with no changes and highway mileage went to 55 mpg. then i had the head worked on and installed a 750 kit and the mileage went down to 42 again.
i broke one one of the 32s trying to get a float needle out and replaced them with VM34s. the 34s are more compatible with the original headwork and the bike is quite comfortable on the street. i've never measured the fuel mileage, but i'm running 21/47 gearing on it too, so that would have an effect. i tend to keep the rpms higher than i did with 19/47, so i probably get poorer fuel economy.
the 35mm keihin FCRs get about 7.2 mpg on my race 650, but that's not really comparable.
Re: replacing Mikunis with Amal, BSA lightning [Re: redrooster] #744853
08/08/18 3:31 am
08/08/18 3:31 am
Mark Z Offline
Mark Z  Offline
Hi Mark,
Judging by your photo I am being plank thick and will be looking at doing this set up.
Mik's are 30mm.
Bodine, idles highest at 2 turns out so have set a/m to 11/2. Everything I have read says no less than 11/2 so have been reluctant to go to 1. So I changed pilot jet from 25 to 30. This did not seem to change idle so left it at 1 1/2 out Is this the wrong approach ?
Ok. FWIW, my filters are Uni foam (sold in a sheet), soaked with Uni filter oil, over 3/16" wire mesh, all held on with hose clamps. Because of the small surface area, the foam needs to be cleaned (with gasoline) and re-oiled regularly. Triumphs and OIF BSAs offer more options for air cleaners, as shown in Kevin's photos, but on a dry frame BSA, there is only about 1/2" clearance between the carb mouths and the frame.
If it idles highest at 2 turns out, then that would seem to be the correct setting, no? Out = leaner, In = richer, so if you really want it at 1 1/2, I think you're going the wrong way with the pilot jet. (They do make a 22.5 pilot jet.)
When you get it where you think you want it, a good test of the idle mixture is this: Start and warm up the engine so it can be re-started without enrichening. Put in new plugs and re-start the engine. Let it idle for a few minutes without touching the throttle. Shut it down and look at the plugs.
Always let the head cool for about 10 minutes before removing the plugs, and always use the anti-seize lubricant that's made for spark plugs on the threads.
Re: replacing Mikunis with Amal, BSA lightning [Re: Mark Z] #744876
08/08/18 9:19 am
08/08/18 9:19 am
Bristol England
Bristol England
Hi Mark,
Ok, I changed the 25 for a 30 to make it richer and have made it leaner ?, I have 20 it my box I should try this.
Hi Ferret,
I see the aluminium adaptors on your photos that bolt straight on to the head, this is what I think I need but can,t seem to find them supplied by anyone here.will look harder.
Re: replacing Mikunis with Amal, BSA lightning [Re: redrooster] #744877
08/08/18 9:47 am
08/08/18 9:47 am
gavin eisler Offline
"Ok, I changed the 25 for a 30 to make it richer and have made it leaner ?, I have 20 it my box I should try this."
No .
When you put in the 30 the jet passes more fuel so the screw ends up at 2 turns for the correct balance, more fuel needs more air, the screw controls the air flow. try the 22.5 if you must have correct balance at 1.5 turns out.
Re: replacing Mikunis with Amal, BSA lightning [Re: gavin eisler] #744882
08/08/18 11:35 am
08/08/18 11:35 am
Bristol England
Bristol England
Ok got it, happy where I am now with the 30
Re: replacing Mikunis with Amal, BSA lightning [Re: redrooster] #744918
08/08/18 7:11 pm
08/08/18 7:11 pm
Bristol England
Bristol England
Hi all,
Your photos and advice is really appreciated, I am going to put this into practice and will let you know how it turns out.
Re: replacing Mikunis with Amal, BSA lightning [Re: redrooster] #744928
08/08/18 9:03 pm
08/08/18 9:03 pm
Bolton Lancs UK
Andy Higham Offline
Andy Higham  Offline
Bolton Lancs UK
Look at plate manifolds in the lower half of This page, they take up less space than the adaptor/rubber sleeve arrangement
Re: replacing Mikunis with Amal, BSA lightning [Re: redrooster] #744930
08/08/18 9:08 pm
08/08/18 9:08 pm
Bolton Lancs UK
Andy Higham Offline
Andy Higham  Offline
Bolton Lancs UK
On a B31 engine
[Linked Image]20170125_170939 by Sigma Projects, on Flickr
On a DBD type engine
[Linked Image]20180609_152238 by Sigma Projects, on Flickr
Re: replacing Mikunis with Amal, BSA lightning [Re: redrooster] #744945
08/09/18 1:24 am
08/09/18 1:24 am
Mark Z Offline
Mark Z  Offline
Hi Mark,
What Gavin said. I didn't explain it very well. Right, if you're happy with two turns out on the air screw, then leave in the 25 jet. If you want the air screw in farther (richer), then you want a smaller pilot jet to compensate.
Hi Ferret,I see the aluminium adaptors on your photos that bolt straight on to the head, this is what I think I need but can,t seem to find them supplied by anyone here.will look harder.
This may not help you over there, but I got my Mikuni kit from M.A.P. Cycle in Florida, which kit included the manifold adapters.
Re: replacing Mikunis with Amal, BSA lightning [Re: Mark Z] #749968
09/21/18 10:25 am
09/21/18 10:25 am
Bristol England
Bristol England
Hi all,
Thanks for help this is what I ended up with
Re: replacing Mikunis with Amal, BSA lightning [Re: redrooster] #750141
09/23/18 12:58 am
09/23/18 12:58 am
Mark Z Offline
Mark Z  Offline
RR, I don't know how well it will show up in this picture, but if you want to get some rudimentary filtering, you may want to try something like this:
"Filters" are 3/16" square galvanized wire mesh covered with oil-soaked Uni foam, all held on with hose clamps. Because of the small surface area, they need to be periodically cleaned (with gasoline) and re-oiled, but it's better than nothing.
Also, I have only about 1/8" between the two spigot mount clamps, and it looks like you have about 1/4". You may be able to gain a bit of clearance by cutting the coupler and/or the manifold adapter a bit shorter.
Last edited by Mark Z; 09/23/18 1:05 am. Reason: screwed up the picture the first time
Re: replacing Mikunis with Amal, BSA lightning [Re: redrooster] #750299
09/24/18 2:55 pm
09/24/18 2:55 pm
Bristol England
Bristol England
Hi Mark
Thanks, yes will do something like this.
Re: replacing Mikunis with Amal, BSA lightning [Re: redrooster] #753138
10/17/18 4:46 pm
10/17/18 4:46 pm
Bristol England
Bristol England
Re: replacing Mikunis with Amal, BSA lightning [Re: redrooster] #753139
10/17/18 4:52 pm
10/17/18 4:52 pm
Bristol England
Bristol England
Hi Mark and everyone,
Advice is really appreciated, Bike is running beautiful
and it goes on and on and on
Re: replacing Mikunis with Amal, BSA lightning [Re: redrooster] #753322
10/19/18 3:04 am
10/19/18 3:04 am
Mark Z Offline
Mark Z  Offline
RR, I like your air filters better than mine! What are they? Did you make them, or are they "store-bought"? Held on with set screws?
Re: replacing Mikunis with Amal, BSA lightning [Re: redrooster] #756510
11/18/18 9:08 pm
11/18/18 9:08 pm
Bristol England
Bristol England
Hi Mark, been away for a bit, Air filters are velocity stacks bought from a US website, they came with wire mesh gauze filter but have fitted the foam over. they are secured with 3 grub screws, Will try to find where I got them from.
Re: replacing Mikunis with Amal, BSA lightning [Re: redrooster] #757548
11/29/18 9:03 pm
11/29/18 9:03 pm
Bristol England
Bristol England
Hi Mark,
Just remembered, they are from Dime City Cycles 'polished aluminium shorty velocity stacks'
Page 2 of 3 1 2 3
