Sorry for the delay in replying to your request.
FIRST: what color is your oil tank and tool / battery box?
If the paint is BLACK, the
decals will be GOLD.
If the paint color is dark metallic SILVER-GREY, the
decals will be BLACK.
All Bonnevilles built 1959-1965 had the same particular "Bonneville 120"
decal (
decal was slightly changed 1966-67, changed again 1968, still again 1969-70.)
The BOTTOM of the "Bonneville 120"
decal will be placed about one inch above the horizontal center line of the mounting screw, and the zero of "120" will be directly above the vertical center line of that mounting screw.
Thus, "Bonneville 120" is located slightly forward of the center of the lid.
OIL TANK
decals I will describe as best I can:
Your tank should not be missing the trim valance between actual tank and the frame for this to be correct.
The "valance" is the piece of sheet metal with the slot that the top mount of the tank peeks through.
"IMPORTANT Drain Oil and Refill"
decal is on the valance itself, with it's BOTTOM border line next to the seam,
and the center line of the
decal should line up with the center line of the slot for the front top mount of the tank
If you look at the tank from the SIDE, you would be able to read this
decal.
The "USE ONLY"
decal listing recommended oils is also placed on the valance. It's placed with it's LEFT border line by the same tank / valance seam, and it's top border line sits about 1/16 of an inch below the right-side line of the "IMPORTANT"
decal.
This
decal will be read by looking at it from the FRONT of the bike, looking toward the rear.
For 1962 models, the proper
decal will read as follows (same
decal wording used 1961 - 1968)
USE ONLY
B.P. ENERGOL, SHELL,
WAKEFIELD CASTROL,
MOBILOIL, ESSOLUBE,
OR REGENT HAVOLINE
REFER TO HANDBOOK FOR
RECOMMENDED GRADES
The "MINIMUM OIL LEVEL"
decal on the side of the tank should be located with the bottom line of the
decal about half-way down the side of the tank. A common mistake is to locate it too high.
Again, the oil tank
decals will all be the same color as the "Bonneville 120"
decal on the tool box lid.
I will add to this, the location of the "MADE IN ENGLAND"
decal on top of the fuel tank.
This
decal is in GOLD ink (why it's not "black," who knows?)
This
decal is directly across the tank from the center of the filler neck, with the right end of the
decal about 1/4 inch away from the center seam. Photos of original-paint tanks show the factory placed it TOO CLOSE to the seam, and
the letter "D" in "ENGLAND" was covered by the rubber strap by which the tank was mounted.
Correct this if you wish, but that's the way they originally looked.
I hope this information is of help. Best of wishes for a successful restoration.
