TJD
TJD
Devonport Tasmania
52 registered members (998John), 348 guests, and 728 spiders.
Jeff Earle, Mike Fielding, matg80s, Al Anderson, John Billerbeck
10574 Registered Users
franko 97
NickL 71
reverb 48
810,322 mail-order LSR
Topics67,491
Posts669,176
Members10,574
Need coil mount picts. 69-70 #741436
07/10/18 9:49 pm
07/10/18 9:49 pm
Smackinthemiddle, NJ
rocketscientist Offline OP
Just like it says....I need to see some clear coil mounting brackets / coils for a 69-70 A65. That way IF i do go with stock coils, I can get the correct mounts. I'm not sure what I'm doing yet.
Thank you.....
Mike
Re: Need coil mount picts. 69-70 [Re: rocketscientist] #741489
07/11/18 10:50 am
07/11/18 10:50 am
V
VicCyclone Offline
VicCyclone  Offline
V
See Burton Bike Bits web site:-
https://www.google.co.uk/search?q=BSA+a65+Coil+mounts&source=lnms&tbm=isch&sa=X&ved=0ahUKEwinppfl75bcAhVSXsAKHQ7aBqQQ_AUICigB&biw=1600&bih=769#imgrc=mZklJEPjyOs2tM:
VicCyclone
1965 A50 Cyclone Clubman
1966 Victor GP
1967 Victor Special
1968 Victor Special
1968 A65L
2009 HD FXDC
Re: Need coil mount picts. 69-70 [Re: rocketscientist] #741688
07/13/18 12:41 am
07/13/18 12:41 am
Maryland
JD Offline
Moto-Amish
JD  Offline
Moto-Amish
Maryland
Mike, I'm putting the coils back on my bike tonight. What information do you need? I'll take some photos, but if you need specific angles or measurements, let me know.
Josh
Re: Need coil mount picts. 69-70 [Re: rocketscientist] #741699
07/13/18 2:01 am
07/13/18 2:01 am
seattle
tiumphdave Online content
tiumphdave  Online Content
seattle
The easiest thing to do is google "a65 coil mounting brackets", then select "images" from the list- lots of pictures. After selecting an image, hit "visit" for more info. Many will direct you back here to britbike forum.
I use google rather than the forum search- type what you're looking for then add "britbike forum" at the end.
Hope this helps.
Re: Need coil mount picts. 69-70 [Re: rocketscientist] #741700
07/13/18 2:07 am
07/13/18 2:07 am
Maryland
JD Offline
Moto-Amish
JD  Offline
Moto-Amish
Maryland
Here are some pics I took a few minutes ago:
The thing in the middle is not a washer, but the spacer I had to set on its end to keep from rolling off the table.
Josh
Re: Need coil mount picts. 69-70 [Re: rocketscientist] #741706
07/13/18 2:46 am
07/13/18 2:46 am
seattle
seattle
Re: Need coil mount picts. 69-70 [Re: rocketscientist] #741708
07/13/18 3:07 am
07/13/18 3:07 am
Maryland
JD Offline
Moto-Amish
JD  Offline
Moto-Amish
Maryland
I forgot one more I took that sort of shows the shape of the standoffs.
Josh
Re: Need coil mount picts. 69-70 [Re: rocketscientist] #741725
07/13/18 8:14 am
07/13/18 8:14 am
Brisbane, Australia
BrizzoBrit Offline
BrizzoBrit  Offline
Brisbane, Australia
The little spacer in the middle is very useful. I cracked a few of the bent mounts until I discovered that a spacer I had (bought as part of buying everything on the parts list) was meant to fit between the coil clips. I discovered that on a thread here just like this one (this Forum is great). In fact looking back through this thread it was the one linked to above by triumphdave. smile Burton Bike Bits have the coil clips currently at a reasonable price compared to others.
Be careful about the part number for the coil clip as coil diameter changed late 60's which buggered me up a bit when looking for the clips. I think the later bikes use the 'small' diameter coils and the early ones 'fat' coils, but you would need to verify that my rubbish memory is correct.
BSA 1969 A65F
BSA 1966 A65H
Triumph 1968 T120
Kawasaki A1R
& too many projects!
Re: Need coil mount picts. 69-70 [Re: rocketscientist] #741787
07/13/18 7:51 pm
07/13/18 7:51 pm
PERFECT ! ! ! thanks Josh!!!
Re: Need coil mount picts. 69-70 [Re: rocketscientist] #742271
07/17/18 10:42 pm
07/17/18 10:42 pm
SF Bay Area, CA
DJBSAOCNC Offline
DJBSAOCNC  Offline
SF Bay Area, CA
I am late to the party (as usual) and FWIW, my '69 A65T that appears to be mostly unmolested doesn't use the mounting shown above. My bike uses the larger coils (48mm?) with ring mounts that are at least similar to those above and the attach with the bolts that hold on the sidecover bracket (68-9340 shown on plate 14 of the 69 parts book).
D. James
