Tim Lynch
Tim Lynch
Devon, UK
49 registered members (998John), 347 guests, and 731 spiders.
Jeff Earle, Mike Fielding, matg80s, Al Anderson, John Billerbeck
10574 Registered Users
franko 97
NickL 71
reverb 48
810,322 mail-order LSR
Topics67,491
Posts669,176
Members10,574
71 A65 Firebird centre stand #741355
07/10/18 2:50 am
07/10/18 2:50 am
Rangiora, New Zealand
Mito Offline OP
Mito  Offline OP
Hey everyone, just about got a rolling chassis on my 71 A65FS. As it didn't have a centre stand when purchased, I got hold of an old re inforced OIF centre stand from a Police T120 as centre stands are a bit thin to the acre down here. After a bit of surgery removing and blending the re inforcing, I tried fitting it today and it's all wrong. The machined flats on the stand that butt up against the frame lugs are way to low and allow the stand to over pitch to far forward. Who would have thought that they made a special stand for the police models. Any centre stand gurus out there who can advise on this. Cheers, Stu
70 Rob North Rocket 3
71 T150
71 A65 Firebird
03 Buell Lightning
04 Buell Firebolt
08 Buell Ulysses
1974 Honda SL 125
75 Honda XL 350
84 Ducati 600 TTF2
Re: 71 A65 Firebird centre stand [Re: Mito] #742434
07/19/18 11:35 am
07/19/18 11:35 am
West Yorkshire
West Yorkshire
Not quite sure if this will answer your question, but when on centre stand, the OIF is back end heavy (stand too far forward... probably becasue of the long swing arm) so all OIF (A65's at least) will sit with the front wheel off the ground.
Re: 71 A65 Firebird centre stand [Re: Mito] #742438
07/19/18 12:05 pm
07/19/18 12:05 pm
gavin eisler Online content
gavin eisler  Online Content
My 71 came with no C stand, i fitted a later T140 type , it was about an inch too long, had it shortened and it works fine. As for balance, pretty much depends on fuel load, I can remove either wheel easily, if the tank is full and I am working at the front I put a weightt on the back of the seat to bring the front up, as soon as the front wheel is dropped the balance weight is unnecessary.. Dunno anything about police stands. it could be the stand mounts are bent? maybe you could add a couple of lumps to the stand stops to stop overtravel? its a bit grimy under there, HTH
Re: 71 A65 Firebird centre stand [Re: Mito] #742442
07/19/18 12:33 pm
07/19/18 12:33 pm
West Yorkshire
West Yorkshire
I think its the over travel why these stands start getting bent. On my friends I/we built the frame stops up with weld (dressed it properly) then fitted a T120 centre stand. works really nice now.
Re: 71 A65 Firebird centre stand [Re: Mito] #743110
07/25/18 2:57 pm
07/25/18 2:57 pm
Richmond, VA
tg4360 Offline
tg4360  Offline
Richmond, VA
My T'bolt stand goes way over and is too tall (as in difficult to deploy) also.
But then again it may have been a "Safety Feature" in that the bike has a "Reverse Gear" when you blip the throttle while it's on the center stand!
TG
'68 B25 Starfire (single)
'72 A65 Thunderbolt (twin (I'm sensing a pattern here..))
'78 XS750 Triple (Because I just can't get my hands on
a Rocket Three...)
'87 K100GS (four banger (Because NVT gave up too quick..)
Re: 71 A65 Firebird centre stand [Re: gavin eisler] #745907
08/18/18 6:31 am
08/18/18 6:31 am
Mito Offline OP
Mito  Offline OP
Thanks for the responses guys. The stand on mine pitches so far forward that the foot lever is lower than the stand and fouls the ground. Looks like I will have to reprofile the stops to bring it all back up. It is unusual as the stand showed no signs of wear.
71 T150
71 A65 Firebird
03 Buell Lightning
04 Buell Firebolt
08 Buell Ulysses
1974 Honda SL 125
75 Honda XL 350
84 Ducati 600 TTF2
Re: 71 A65 Firebird centre stand [Re: Mito] #745927
08/18/18 12:43 pm
08/18/18 12:43 pm
Irish Swede Offline
Irish Swede  Offline
"Over-travel" is a problem with pre-unit Triumph center stands as well.
I have welded up and re-profiled the stops on them to get them more "vertical" in use, and it works.
Now iIt'a also easier to get the bike OFF the stand,
