Dave Lid
Dave Lid
The Black Country UK
Page 6 of 6 1 2 3 4 5 6
Re: 1968 Triumph T100R Daytona 500 - Super Project
Mark. L #741168 07/08/18 3:22 pm
Originally Posted by Mark. L
Hey Dr. Jon, that was a fine bit of surgery you did removing that bolt.....
Thanks Mark ! Now, to look through my stash and see if I can find a decent 12 degree AA unit. I do have a Pazon ignition for it but am leaning toward points for initial startup and running right now.
1971 BSA A65 650 - Project
Jon W. Whitley #741175 07/08/18 4:11 pm
I'm putting a Pazon in my 71 T100R, I was hoping to have the bike on the road about a month ago, but some other non bike related issues happened, what about clutch adjustments, I have new plates and springs and have it pretty much straight, just how much can it be rode without the primary put back on if I want to do some tweaking to the clutch
Jon W. Whitley #741187 07/08/18 6:12 pm
Ive got a drawer full of advance units. Let me see if I can find one for you.
"I don't want a pickle. I just want to ride on my motor-cicle." Arlo Guthrie
Triumphs, BSA's, Nortons, Guzzis, Harleys & a few others.
TBolt72 #741239 07/09/18 1:19 am
Originally Posted by TBolt72
[quote=Jon W. Whitley]
Wow, that's awesome TBolt72 ! I have one in hand and the cam is badly pitted.
Jon W. Whitley #741337 07/09/18 11:32 pm
Cleaned up and installed new oil seal E4568. Didn't have to order one, as I just happened to have a few on hand !
Jon W. Whitley #741351 07/10/18 1:16 am
$20 plus shipping g.
TBolt72 #741486 07/11/18 10:16 am
Thanks for looking for the advance unit and posting the pics TBolt72. I have found a decent one in my stash.
Jon W. Whitley #743553 07/29/18 5:08 pm
Jon Glad to see things are still moving forward. It looks good.
57 A10 GF
61 A7
61 A10 GF
63 A10 SR
76 CB 125 Honda
76 FLH
2012 FLHTP
Red Lapierre #743554 07/29/18 5:30 pm
Thanks Red. I am working on the gas tank now as well as the oil tank and side cover. I should have the AA unit installed in the next day or two.
Jon W. Whitley #743781 07/31/18 12:49 pm
Sure is looking good!
BSA harness out in today's post...
GrandPaul #743903 08/01/18 10:04 am
Thank you x 2 Paul !
Jon W. Whitley #743929 08/01/18 2:23 pm
Missed the collection time at my neighborhood drop off yesterday, so you'll likely receive it Saturday.
GrandPaul #744078 08/02/18 2:27 pm
No Worries, Saturday is just fine !
Jon W. Whitley #744568 08/05/18 11:08 pm
Proper 12 degree AAU installed as well as the points plate. This was done after bringing the assembly to 38 degrees BTDC, confirmed with both valves closed on RH cylinder, pointer on primary cover pointing to line on alternator rotor aaand timing tool dropped in slot in crankshaft located at the timing plug at the rear of the cylinders.
Getting closer !!
Jon W. Whitley #748507 09/09/18 3:46 pm
Slowly but surely getting things done. Next task is the oil tank.
Gas tank with base coat of silver.
Side cover/toolbox stripped and getting ready for some filler to be applied. I hammered most of the deep gash/dent out from the backside.
A PO had cut the middle of the toolbox out with snips or something facepalm I just used my Dremel to clean up the jagged edges and leave it be.
Jon W. Whitley #749081 09/13/18 11:32 pm
I got the oil tank stripped the other day I got some more work done today on both the side cover and oil tank.
Here is the oil tank from this bike and what I have to work with. It has had a rough life !
Stripped of paint
Primer applied while it waits for the Bondo work
Jon W. Whitley #749084 09/13/18 11:40 pm
Got the Bondo applied. There are two layers applied so far to the large dent on the oil tank and I will do another layer on it tomorrow for good measure. There is quite a bit of sanding that has been done up to this point !
Jon W. Whitley #749131 09/14/18 11:57 am
#irideslow
#irideslow
Lookin' good, Jon! The joys of salvaging these old bikes, bit by bit.
Re. Bondo, maybe you do this already ... to cut down on sanding, I use a SurForm file before the Bondo is fully hardened, to shave down the excess before sanding. HTH smile
Kurt
Jon W. Whitley #749136 09/14/18 1:46 pm
Yes Jon it looking good I know it has not been easy. Red
57 A10 GF
61 A7
61 A10 GF
63 A10 SR
76 CB 125 Honda
76 FLH
2012 FLHTP
Red Lapierre #749141 09/14/18 2:13 pm
Thanks Kurt ! I do have the files to cut the Bondo down but just using 80 grit on it for this job for starters.
Thanks Red. Not easy like you say but I'm enjoying it !
Jon W. Whitley #749438 09/17/18 12:32 am
Coating the oil tank with sandable filler primer.
Side cover first coat of self-etching primer.
Jon W. Whitley #750267 09/24/18 7:34 am
Hi Jon,
Post 713091.
Test fitting the coils to the frame. I found a set of coils with the 99-1052 clips. With the standard spacers, they cause the largest part of the coils to contact the gas tank recesses. This is with the 2.5 gallon U.S. spec tank. I like this setup though.
'Fraid I've only just seen this post; frown advance apologies if you've solved the problem already.
An educated guess says the coils in your pictures are Lucas 17M12 or pattern? When I was building up my T100, I also encountered problems fitting a US-market tank over 'em. frown Afaict, the problem is - certainly on late-1960's US-market tanks - Triumph sized the "gas tank recesses" for the "Siba 32,000" coils listed in the late-1960's parts books; however, while 17M coils appear to have been Lucas's '70-on response, the Lucas coils have the ridge around the terminals end that the Sibas don't appear to have.
That said, I didn't fiddle around too long with a US-market tank; the UK & General Export tank has bigger recesses (the Lucas MA coils are fatter), as well as being an Imperial gallon bigger. Unlike other Triumph ranges, certainly '67-on C-range UK&GE and US tanks don't look dissimilar (unless you have the two side-by-side) so the bigger tank doesn't look obviously out of place on a US-market bike.
standard spacers,
Nevertheless, even with the bigger tank/recesses, I still had fitting problems with what were then being peddled by the trade as "standard" spacers. facepalm In the end, I fiddled around under the tank for a ridiculously-long time (would've been quicker to take the engine out, measure and refit the engine cool ) to calculate the length of spacers that gave the same clearance between frame and coils and between coils and tank. This might also be an option with your bike's tank?
Btw, if the coils in your pictures are Lucas 17M12 or pattern, the "coil clips" in your picture aren't 99-1052. 99-1052 are sized for the fatter MA coils and, when used with the smaller 17M coils, the gap allows for some anti-vibe padding between coil and clip. Not sure what those similar-looking clips that actually fit 17M coils are, they weren't used on '70 UK&GE bikes with '70-on 17M coils; the British Cub parts company Greystone Enterprises sell 'em, so it's possible they were originally intended for mounting 17M coils on Cubs?
Jon W. Whitley #752788 10/14/18 11:26 pm
I haven't been neglecting the Daytona and am still working the bodywork and painting of the sheet metal. Still need to do more work on all pieces and will post pics with the completed progress !!
