Topics68,224
Posts684,587
Members10,937
Most Online14,755 May 5th, 2019
52 registered members (Al Eckstadt),
504
guests, and 843
spiders. |
Key:
Admin,
Global Mod,
Mod
Re: 1968 Triumph T100R Daytona 500 - Super Project
[Re: Stuart]
#729619
03/22/18 9:26 pm
kurt fischer
#irideslow
#irideslow
Posts: 2,626 |
Hi Kurt phenolic (Tufnol?) spacers Thicker ones, 1/2" 3/4" 1" etc, are available from a UK supplier (can't recall the name at the moment), Surrey Cycles? Certainly they have (had?) them. Hth. Regards, Thanks, Stuart -- that's them! https://surreycycles.com/product/tufnel-spacers/
Kurt
[Re: Jon W. Whitley]
#729846
03/24/18 11:39 pm
Jon W. Whitley
Posts: 6,202 |
Found these in my stash today. ![[Linked Image]](https://i.imgur.com/gOoFXfA.jpg) And, into the cleaner you go ! ![[Linked Image]](https://i.imgur.com/D9ndy2K.jpg)
1957 6T Thunderbird 650 1968 T100R Daytona 500 1971 TR6R Tiger 650 1970 BSA A65F 650 1955 Tiger 100 - Project 1971 BSA A65 650 - Project 1972 Norton Commando 750 "Combat"
#729848
03/25/18 12:05 am
Mark. L
Posts: 179 |
We cant get that gunk in a can over here in Canada, about the best we have is a good nite of drinkin then piss on our parts in the morning.....
#729871
03/25/18 11:32 am
kurt fischer
#irideslow
#irideslow
Posts: 2,626 |
Jon, do you wear a HAZ MAT suit when anywhere near that GUNK?
Kurt
[Re: kurt fischer]
#729892
03/25/18 3:19 pm
Jon W. Whitley
Posts: 6,202 |
Jon, do you wear a HAZ MAT suit when anywhere near that GUNK?  No Kurt, just rubber gloves :bigt I have this Gunk and another 1 gallon can of Berryman's. I think the GUNK might be a tad bit better.
#729939
03/25/18 11:40 pm
Jon W. Whitley
Posts: 6,202 |
#729944
03/26/18 12:52 am
HughdeMann
Posts: 462 |
Jon, I've found that a large roll of aluminum foil is a better masking than tape. You can form it around things, and it will stay put. It covers a larger area, so no cleanup. Usually.
Hugh: Proof the Dodo is not extinct presently without a Brit Bike A couple others
[Re: HughdeMann]
#729971
03/26/18 10:38 am
Jon W. Whitley
Posts: 6,202 |
Jon, I've found that a large roll of aluminum foil is a better masking than tape. You can form it around things, and it will stay put. It covers a larger area, so no cleanup. Usually. Thanks, I may give that a go for another time.
#730012
03/26/18 8:41 pm
Red Lapierre
Posts: 354 |
Jon it looks great. The before and after picture will be a shock. Keep up the good work.
57 A10 GF 61 A7 61 A10 GF 63 A10 SR 76 CB 125 Honda 76 FLH 2012 FLHTP
#730020
03/26/18 10:32 pm
Mark. L
Posts: 179 |
Hey Jon, I thought you were waiting till it warmed up... man, it's looking good tho
[Re: Mark. L]
#730025
03/26/18 11:42 pm
Jon W. Whitley
Posts: 6,202 |
Thanks Red. Even now, it is hard to believe this is the same machine ! Hey Jon, I thought you were waiting till it warmed up... man, it's looking good tho Hi Mark....it warmed up a little and above all else, I just couldn't wait ! In years past, I have waited and then find when the next snowfall comes in the late fall that I didn't take advantage of every opportunity to get bike things done. No more ! In the past two or three year, I've completed more projects than I did in the previous 10 to 20 combined. My goal is to have this Daytona road ready by June :bigt
[Re: NickL]
#730055
03/27/18 7:24 am
Triless
Posts: 1,815 |
Nice work ! Must have been some regret letting that one go !
#730057
03/27/18 8:10 am
Mark. L
Posts: 179 |
Looking forward to seeing the bike in June, any idea for paint color? Hey Nick L, That's quite the transformation on that one
[Re: Mark. L]
#730070
03/27/18 12:06 pm
Jon W. Whitley
Posts: 6,202 |
Wow Nick, very nice. It certainly did have quite the transformation ! Looking forward to seeing the bike in June, any idea for paint color? Hey Nick L, That's quite the transformation on that one Mark, I am leaning toward blue with a silver stripe down the center. I have seen a couple of different shades I like and Honda cars seem to have the best colors. I saw a CRX a few weeks ago in this color and knew it was the one immediately. Here's what I'm thinking : [img] https://img.purch.com/o/aHR0cDovL3d...ZW50LzIwMTIvMTEvMjAxMy1ob25kYS1jcnouanBn[/img] ![[Linked Image]](http://www.hybridcars.com/wp-content/uploads/2015/03/2015_Honda_CR_Z_EX_Navi_03.jpg) ![[Linked Image]](https://icdn-5.motor1.com/images/mgl/O3wnR/s4/2014-512709-2015-honda-cr-z-us-spec1.jpg) ![[Linked Image]](https://lln.mnmcdn.com/photos/content/october2014/thumbnailsnew/honda-crz-2_653.jpg)
#730074
03/27/18 1:06 pm
Mark. L
Posts: 179 |
I like it, the silver and that blue, I think will look good on there
#730087
03/27/18 3:43 pm
Red Lapierre
Posts: 354 |
#730597
04/02/18 12:33 am
Jon W. Whitley
Posts: 6,202 |
I got the carb manifolds on today as well as the new Rocker Box Inspection Cap Locking Springs. With the springs, I found that to make them work correctly, I needed to use a hammer and drift to get them into the position seen in the pictures. I also installed the new inspection cap fiber washers. I was going to mount the carbs today as well but the behind the scenes fiascoes taking place to make this all happen necessitated I finish up and mount them tomorrow ! So anyway, here is the progress from today. ![[Linked Image]](https://i.imgur.com/gcYwzf1.jpg) ![[Linked Image]](https://i.imgur.com/vnhjw7b.jpg)
#730599
04/02/18 12:53 am
Tridentman
Posts: 4,579 |
Probably a trick of the photography but it looks as if the springs are bearing on the fibre washer rather than on the serrations of the inspection cap? HTH
[Re: Tridentman]
#730600
04/02/18 12:59 am
Jon W. Whitley
Posts: 6,202 |
Probably a trick of the photography but it looks as if the springs are bearing on the fibre washer rather than on the serrations of the inspection cap? HTH Hi Richard, No, they are in the correct position and clicking with the inspection caps as they are supposed to be.
[Re: NickL]
#730619
04/02/18 8:11 am
Stuart
Posts: 10,015 |
Hi, You'll stand a better chance of not loosing those caps if you use o-rings rather than the fibre washers. ... although that might depend on the thickness of the the O-rings. Years ago, before I aware of a thickness issue, the O-rings I was sold were thin and useless at keeping the caps, I had better luck with fibre washers after I discovered that's what Triumph fitted originally. Hth. Regards,
#730622
04/02/18 8:35 am
triton thrasher
Posts: 7,998 |
I’ve found that O-rings are the answer to the lost cap problem. O-rings that looked about right, picked from a box of assorted O-rings.
I’ve done a lot of miles and I recommend you do not fit those stupid fibre washers.
[Re: triton thrasher]
#730689
04/02/18 10:39 pm
Jon W. Whitley
Posts: 6,202 |
I’ve done a lot of miles and I recommend you do not fit those stupid fibre washers. I thought about using o-rings but had these washers on hand so put them to use. If I lose a cap, I'll get some o-rings. I've got several extra caps to replace one if need be. Thanks for the advice.
#730691
04/02/18 10:42 pm
Jon W. Whitley
Posts: 6,202 |
Got the carbs back on today as planned. Nice shiny new blanking plugs for the choke cable holes too. ![[Linked Image]](https://i.imgur.com/8Usg01n.jpg) ![[Linked Image]](https://i.imgur.com/ZC2sJOG.jpg)
#741108
07/08/18 1:20 am
Jon W. Whitley
Posts: 6,202 |
Apologize for the long overdue update but was finally able to start back on the T100R today. I decided to have a look at the points and advance unit and glad I did. This bike should not have this type of advance unit in it !!! ![[Linked Image]](https://i.imgur.com/vnlTnFe.jpg) ![[Linked Image]](https://i.imgur.com/mpZN5HA.jpg) .......and also, low and behold, there is a hole with the broken end of a points pillar bolt broken off in the case. ![[Linked Image]](https://i.imgur.com/yrIhIUt.jpg) So, after removing the points plate and auto advance unit, it is time to get to work. After carefully drilling through the broken stud, I was able to tap in an extractor. ![[Linked Image]](https://i.imgur.com/wJastGe.jpg) Steady as she goes. ![[Linked Image]](https://i.imgur.com/fSLib1H.jpg) Remnants of Pillar Bolt removed....wheeeew ![[Linked Image]](https://i.imgur.com/DUjLRZG.jpg) All Clear ! ![[Linked Image]](https://i.imgur.com/XHKSE1P.jpg)
#741109
07/08/18 1:36 am
Mark. L
Posts: 179 |
Hey Dr. Jon, that was a fine bit of surgery you did removing that bolt.....
