TJD
TJD
Devonport Tasmania
51 registered members (998John), 346 guests, and 730 spiders.
Jeff Earle, Mike Fielding, matg80s, Al Anderson, John Billerbeck
10574 Registered Users
franko 97
NickL 71
reverb 48
810,322 mail-order LSR
Topics67,491
Posts669,176
Members10,574
A65 Cast Iron Oil Pump ? #740387
07/01/18 11:05 am
07/01/18 11:05 am
England
F
ferretjuggler Offline OP
F
England
Would it be possible to manufacture one ?
I have a tame model engineer with a small lathe in his shed, and possibly access to other machine tools.
I don't mean making a new shaft or gears, but simply replicating the distortion prone mazak casing parts with cast iron ones.
After seeing an unknown condition late cast iron pump sell on eBay for over £300 I'm not inclined to go chasing after used ones.
Obviously someone is going to tell me to buy a SRM pump.
Please don't.
I will never allow anything from SRM inside my engine, I simply don't trust their stuff.
A nice new standard spec iron body pump would be a very desirable thing to have IMHO.
Any good reason why it can't be done ?
Re: A65 Cast Iron Oil Pump ? [Re: ferretjuggler] #740392
07/01/18 1:12 pm
07/01/18 1:12 pm
Irish Swede Offline
Irish Swede  Offline
My Dad was a machinist.
He always said: "What one man can make, another man can duplicate."
If you have one in your hand, you have the model to make another, so long as you have the means to do it.
Re: A65 Cast Iron Oil Pump ? [Re: ferretjuggler] #740399
07/01/18 1:47 pm
07/01/18 1:47 pm
Farnham, Surrey, UK
gunner Offline
gunner  Offline
Farnham, Surrey, UK
If you have the right tooling and skills available then I would give it a go, it doesn't appear that complicated though accuracy will be vital.
You will need to find the clearance between the gears and pump body and this will be a vital measurement to carry over to the new pump.
Also don't forget that the later alloy "DD" pumps were better than the original alloy pumps. A number of improvements were added over the years including larger gears and dowel locating pins. If youre going to transfer the gears from an alloy pump to the new then best to use a "DD" pump as the source.
Theres a good article on A65 pump evolution Here
Re: A65 Cast Iron Oil Pump ? [Re: ferretjuggler] #740412
07/01/18 4:56 pm
07/01/18 4:56 pm
England
F
F
England
Thanks for the link.
Most useful.
I wonder if there are any NOS gears and shafts available for the DD type pumps ?
Probably too much to hope for (or available at absolutely extortionate prices)
New rotating parts would make building a "brand new " quality pump that much easier, and remove the need for measuring used parts and grading them for wear.
Re: A65 Cast Iron Oil Pump ? [Re: ferretjuggler] #740418
07/01/18 5:35 pm
07/01/18 5:35 pm
Farnham, Surrey, UK
gunner Offline
gunner  Offline
Farnham, Surrey, UK
You can get oil pump gears for Rocket 3/Trident's, see This link, so maybe these could be used as a basis for a new pump?
Re: A65 Cast Iron Oil Pump ? [Re: ferretjuggler] #740423
07/01/18 6:10 pm
07/01/18 6:10 pm
Mark Z Offline
Mark Z  Offline
How about using billet steel instead of cast iron? That is, unless you're planning to cast the parts...
Re: A65 Cast Iron Oil Pump ? [Re: ferretjuggler] #740428
07/01/18 6:33 pm
07/01/18 6:33 pm
gavin eisler Online content
gavin eisler  Online Content
I asked SRM if they sold spare gears for the pumps recently, not to me they wouldnt, suppose they want you to buy a new one, they used to, bought some years ago to refresh an old pump , might be worth hunting by part number for individual bits.
just recently refreshed an iron pump, had to lap about 4 thou off the body to take up the gears endfloat. I reckon there was more wear on the gear flanks than the tips of the teeth.
Re: A65 Cast Iron Oil Pump ? [Re: ferretjuggler] #740429
07/01/18 6:33 pm
07/01/18 6:33 pm
England
F
F
England
I was actually under the impression that the right type of cast iron was the ideal material to make the pump body from.
I'm not planning to cast anything, AFAIK machining is the way to go.
Re: A65 Cast Iron Oil Pump ? [Re: ferretjuggler] #740453
07/01/18 10:09 pm
07/01/18 10:09 pm
Mark Z Offline
Mark Z  Offline
Yeah I was assuming casting and then machining, if you were going to cast.
I don't know enough about metallurgy or machining to say what would be the best material for this; I just figured a block of steel would be more of a "known entity" in terms of consistent composition.
Re: A65 Cast Iron Oil Pump ? [Re: ferretjuggler] #740456
07/01/18 10:42 pm
07/01/18 10:42 pm
Aus
NickL Online content
NickL  Online Content
Aus
Several people over the years have manufactured iron oil pumps for the a65. I bought one in about 1992
from MCS in Leytonstone, he used to have them made using the standard gears. Machining the iron blocks
would need more than a lathe though, you would need a mill at least and some quite good tooling as well.
A surface grinder and a hone would be good as well. Then, once you have that lot, you need to learn how to use it........
The monkey metal D and DD types are OK if you spend the time rebuilding them properly, it's just time,
patience and a square and flat plate. I have never needed to scrap a late a65 pump because it wouldn't pump well.
I can get new pump gears in limited quantity from a source here, he bought some from the 'states.
Bring in the 'Comfy Chair'
Re: A65 Cast Iron Oil Pump ? [Re: ferretjuggler] #740635
07/03/18 3:59 pm
07/03/18 3:59 pm
Pittsburgh,Pa.
Redd32 Offline
Redd32  Offline
Pittsburgh,Pa.
How about machining the pump body out of bronze? Dissimilar metals work well together. That is why cast iron.
Re: A65 Cast Iron Oil Pump ? [Re: ferretjuggler] #740672
07/03/18 11:31 pm
07/03/18 11:31 pm
Aus
Aus
One or more of the 400 types of bronze would probably be fine.
SRM use Aluminium, that's fine, Dural would probably be fine as well.
Cryptonite would probably be ok as well as would Plutonium.
Re: A65 Cast Iron Oil Pump ? [Re: gavin eisler] #740674
07/03/18 11:44 pm
07/03/18 11:44 pm
Aus
Aus
There is a guy on eBay in the 'states who has new gears listed at the moment. (Dotler)
Re: A65 Cast Iron Oil Pump ? [Re: NickL] #740675
07/03/18 11:52 pm
07/03/18 11:52 pm
Rich B Offline
Rich B  Offline
Which gears, there are several lengths. The late long gears are the best.
Re: A65 Cast Iron Oil Pump ? [Re: ferretjuggler] #740679
07/04/18 12:47 am
07/04/18 12:47 am
Aus
Aus
67- 1403, 1404, 1405, 1406.
Re: A65 Cast Iron Oil Pump ? [Re: ferretjuggler] #740710
07/04/18 9:32 am
07/04/18 9:32 am
BSA_WM20 Offline
BSA_WM20  Offline
Please don't.
Because Britsh bike riders in general and BSA riders in particular are way too cheap to pay enough for them for it to be a profitable exercise.
Do a little search on this site for the words BEST and CHEAPEST / CHEAPER.
The latter will bring up thousands of post while the former could be counted on your fingers.
Just about all of the people who make improved quality aftermarke BSA parts do it because they are passinate about BSA's and none of them are wealthy people.
You would probably sell 50 in the first year then 3 or 4 per annum ther after and yoour great grandkids will probably still have 1/2 of a minimum 200 order in their shed when they die.
Like most things BSA owners would much rather whinge & bitch about them than to spend a reasonable amount of money to fix them properly.
Note all the owners who bitch about the poor fit of fuel tanks they bought on eBay from India while the local makers of top quality tanks that fit perfectly are closing down due to lack of sales support.
Re: A65 Cast Iron Oil Pump ? [Re: BSA_WM20] #740717
07/04/18 10:35 am
07/04/18 10:35 am
OZ
Triless Offline
Triless  Offline
OZ
And then there's the idiot who sights all your special, uprated parts going into a performance engine and states "aw, not much Triumph, BSA, Norton, etc, left now, is there !" And then, when everything clicks, and works nicely ,comments , "well, so it bloody well should all the money spent ........!"
Re: A65 Cast Iron Oil Pump ? [Re: ferretjuggler] #740719
07/04/18 11:04 am
07/04/18 11:04 am
Aus
Aus
That's a little scathing i think, the truth of the matter is these things are only toys to most blokes.
I regard spending 20% of the bike's cost (in my case) on a replacement oil pump a trifle too much.
I still feel that if reconditioned properly the late a65 oil pumps are adequate for the engine. I have
never had to scrap one due to poor performance. Time and a little application provide a good result.
Most of the ones i have seen have been tightened up too hard and have distorted, the gears are fine,
some bodies have been badly scored due to the bike having no oil filter or having debris in the engine
when being rebuilt. Patience is the thing that's most lacking not money. I would also point out that
many expensive aftermarket parts are no better than the cheap ones, which is why people are a
bit reticent to buy the more expensive ones. Trevor's comment on things like fuel tanks may be true
but once again in my case the tank i bought from India cost less than i could have my one repainted for.
It does an adequate job and my bike is not an exhibition piece.
Many people do not regard their bike as anything other than a toy and one that should be affordable.
If they view it that way they should be prepared to either get it right when building it or live with the
alternate result. Just bolting on very well made aftermarket bits does not mean the package is any
better than it was before.
Once again, this is only my 2c. worth. (1c if i bought it from India.........)
Nick
Re: A65 Cast Iron Oil Pump ? [Re: NickL] #740720
07/04/18 11:20 am
07/04/18 11:20 am
OZ
Triless Offline
Triless  Offline
OZ
Fair enough . I guess its really just a personal thing, but I've simply have always wanted to attempt something the best I can with what careful research and asking many questions to purchase the best pieces I could afford to see what I could achieve. As I say, a personal thing ! Plus, nothing wrong with giving iconoclasts a good scathing, I reckon !
Re: A65 Cast Iron Oil Pump ? [Re: ferretjuggler] #740721
07/04/18 11:43 am
07/04/18 11:43 am
Aus
Aus
If i followed that practise when racing i would have gone broke in 3 months, there is no ceiling to the money one can spend.
Competing with guys who spent $30,000 a year on their engines was way out of my league and as a personal thing it would
have been contrary to the spirit of club level racing as most ended up not complying with eligibility regulations in truth.
Plus there was no better reward than beating the buggers! Knowing that you did it yourself was a huge kick.
I've said before that walking into Cosworth Engineering, placing any twin cylinder engine of the era on the counter and
saying 'make me something vaguely like this, it must win. here is an unlimited supply of cash' would be the answer and that's
probably where it'll end up.
Re: A65 Cast Iron Oil Pump ? [Re: NickL] #740722
07/04/18 12:09 pm
07/04/18 12:09 pm
OZ
Triless Offline
Triless  Offline
OZ
Ah, well, I do all my assembly work, but I can assure you I do as much as I can with other stuff. Like many, I've sweated blood just to do something special for no other reason that I want to do it ! For myself. A final fling at 66 !
Oh, and Nick, although I was never in top class, many years ago I did know what it was like to compete ( only club level ) but on a very tight budget . Wouldn't have missed it for quids, though !
Re: A65 Cast Iron Oil Pump ? [Re: ferretjuggler] #740723
07/04/18 12:23 pm
07/04/18 12:23 pm
Aus
Aus
Stephen, i was in no way questioning your philosophy, i know how hard it is to be a 'privateer'.
I had to resort to corrillo rods etc to make inroads. Best of luck with the motor.
Also..............
Top class was a distant vision for me too.
Re: A65 Cast Iron Oil Pump ? [Re: NickL] #740724
07/04/18 12:35 pm
07/04/18 12:35 pm
OZ
Triless Offline
Triless  Offline
OZ
Thanks, Nick. Although engine machining stuff I can't handle has been done, and all parts at hand, I 'm still working on the bloody frame and running gear. Can't rush this stuff, y'know !
Re: A65 Cast Iron Oil Pump ? [Re: ferretjuggler] #740754
07/04/18 6:58 pm
07/04/18 6:58 pm
Mississauga, Ontario.
Adam M. Offline
Adam M.  Offline
I thought about only changing part of mechanism of the pump, switching from 3 : 1 ratio to 2 : 1 ratio for a long time. Norton did the same with their pumps with a good result.
Asked about a price for such a project.
You have to invest more than a few thousand of $ without any warranty the parts would be properly machined and heat treated, if something goes wrong you are without money and with worthless parts, impossible to sell. If everything works, I was still not sure I'd be able to sell all the sets before kicking the bucket, so asked myself why bother ?
Forget about it.
This is probably the answer why nobody but SRM is making new pumps.
Re: A65 Cast Iron Oil Pump ? [Re: ferretjuggler] #740774
07/04/18 10:24 pm
07/04/18 10:24 pm
Aus
Aus
Yes, norton did a 2 start worm gear to speed up the pump.
Once again though, if you don't rebuild the pump properly it won't do you any good,
if the joints are leaking due to the pump being bent or distorted, it'll still leak at twice the speed.
