Tim Lynch
Tim Lynch
Devon, UK
49 registered members (998John), 347 guests, and 731 spiders.
Jeff Earle, Mike Fielding, matg80s, Al Anderson, John Billerbeck
10574 Registered Users
franko 97
NickL 71
reverb 48
810,322 mail-order LSR
Topics67,491
Posts669,176
Members10,574
Removing Gearbox Sprocket? #739845
06/25/18 6:05 pm
06/25/18 6:05 pm
GA
E
eelmgren Offline OP
eelmgren  Offline OP
E
GA
I've got a 1970 A65. What's the best/easiest way to remove the drive sprocket? I've read several threads that speak to this, but neither the thread discussions or my manuals are real clear.
I've got the clutch basket off, haven't got the cover plate off or split the cases yet. I understand once the cover plate is off I can fit a VERY deep socket, but have also seen references to removing it after the cases are split. I don't see a removable splined shaft in the overhaul or parts manuals. Wouldn't I still need the deep socket? Or - if all looks good, can I just leave it on with the transmission?
Re: Removing Gearbox Sprocket? [Re: eelmgren] #739851
06/25/18 6:41 pm
06/25/18 6:41 pm
melbourne florida
bodine031 Offline
bodine031  Offline
melbourne florida
Pull off the cover plate (5or6) flat head screws. I would use a Impact driver you wack with a hammer with the proper slot bit. Then with the cover off jam the sprocket so it won't turn and a deep socket with a 1/2 impact to remove the nut.
Re: Removing Gearbox Sprocket? [Re: eelmgren] #739864
06/25/18 8:22 pm
06/25/18 8:22 pm
ca, us
DMadigan Offline
DMadigan  Offline
ca, us
You can dismantle everything in the gearbox except the high gear and bearing if you leave the sprocket in place.
A deep 1-1/2" socket is needed. I believe there are 4WD ball joint sockets in that size deep enough. I welded a 1" socket 1/2" drive onto a 1-1/2" 3/4 drive socket.
Re: Removing Gearbox Sprocket? [Re: eelmgren] #739869
06/25/18 8:55 pm
06/25/18 8:55 pm
Farnham, Surrey, UK
gunner Offline
gunner  Offline
Farnham, Surrey, UK
In my experience the gearbox sprocket nut usually needs a box spanner to undo it, the main problem is finding a socket deep enough to fit, box spanners are easier and cheaper to find although being made of softer steel can cause wear and slippage.
If you can find a socket to fit the go for it as it will be easier, either way use penetrating oil and heat before attempting to undo.
For info the 1970 A65 manual posted Here page 20 part no 2, suggests the nut is 1-3/16 whitworth so might be worth checking what size nut is fitted.
Re: Removing Gearbox Sprocket? [Re: eelmgren] #739871
06/25/18 8:57 pm
06/25/18 8:57 pm
Windsor, Virginia, USA
V
VANDOLSON Offline
VANDOLSON  Offline
V
If you are not pulling the transmission I bought a very deep 1 1/2 in socket for doing this.
The socket is about 4 1/2 inches deep internally. Fits over the trans main shaft all the way to
The sprocket nut. Had a rounded crown that I had to grind flat so it would lay flush
Against the sprocket to grip the nut. Then as stated jam or use the chain to prevent
The sprocket from turning. The torque on the nut is 100 ft lbs on my 1971! Harder to
Retorque then to take off. Socket cost me around $25 but well worth it to me. I mean
Who can pass off buying a tool?! LOL
Re: Removing Gearbox Sprocket? [Re: eelmgren] #739872
06/25/18 9:27 pm
06/25/18 9:27 pm
gavin eisler Online content
gavin eisler  Online Content
old mini ball joint socket.
https://www.minispares.com/product/classic/TOOL03.aspx,
get a 2 foot length of 2 x 3/4" wid, use that as a lever on the brake pedal, undo the nut. If it has been on a long time, after the tabs are knocked back dont be surprised if its finger tight.
Re: Removing Gearbox Sprocket? [Re: VANDOLSON] #739873
06/25/18 9:31 pm
06/25/18 9:31 pm
GA
E
eelmgren Offline OP
eelmgren  Offline OP
E
GA
Thanks, guess I'll shop for an extra deep socket
Re: Removing Gearbox Sprocket? [Re: eelmgren] #739907
06/26/18 2:56 am
06/26/18 2:56 am
Mark Z Offline
Mark Z  Offline
eelmgren, from your original post, it sounds like you're doing a total tear-down. If that's the case, and you're planning on pulling the gear cluster anyway, you could do that first, and then the tranny mainshaft won't be in your way, and you won't need such a deep socket to remove the sprocket nut.
Re: Removing Gearbox Sprocket? [Re: eelmgren] #739910
06/26/18 3:17 am
06/26/18 3:17 am
Eelmgren: If you have a welder there, just go to the plumbing supply and buy a water heater element socket. They are plenty deep. Then weld a little flat on top, and then a nut.
Re: Removing Gearbox Sprocket? [Re: eelmgren] #739955
06/26/18 6:18 pm
06/26/18 6:18 pm
GA
E
eelmgren Offline OP
eelmgren  Offline OP
E
GA
Got it off with a drift punch, but I will still have to get it back on. And yes, it is a total teardown. I've got no problem buying tools, but my box is already full of both tools I've used maybe once and special tools made for applications I haven't worked on in decades. I'd much rather modify something I already have.
Plumbing socket... Will they handle the torque? What is the torque? My books only list a few torque values and I don't see this nut listed.
Re: Removing Gearbox Sprocket? [Re: eelmgren] #739962
06/26/18 7:50 pm
06/26/18 7:50 pm
Man, that's the arkansas way, chisel and a BFH. I use my homade socket with the impact wrench. Ugly, but it's removed dozens of those big nuts.
Re: Removing Gearbox Sprocket? [Re: eelmgren] #739996
06/27/18 2:59 am
06/27/18 2:59 am
Mark Z Offline
Mark Z  Offline
I think 100 ft-lbs is overkill. The locktab washer does an adequate job of holding it in place. Just get it as tight as you reasonably can and bend up the locktab washer. You can probably dress up the nut and reuse it, but the locktab washer should be replaced.
Re: Removing Gearbox Sprocket? [Re: eelmgren] #740051
06/27/18 5:38 pm
06/27/18 5:38 pm
V
VANDOLSON Offline
VANDOLSON  Offline
V
I agree that 100 ft lb torque as called for in the work shop
manual may be overkill since as stated it has a lock tab
Washer. I got mine torqued up to 85 and could really
Not get it more torqued with my 3/4” torque wrench
Without adding a pipe to extend the wrench for more
Leverage (my comment anout harder to retorque).
Bent the lock tab over the nut and called it a day.
