The Bonneville Shop
triton thrasher
triton thrasher
26 registered members (Alan_nc), 264 guests, and 450 spiders.
SuzyTice, Steve Funke, JD8, John Rowley, Zoot
10531 Registered Users
franko 96
Lannis 81
NickL 66
789,359 mail-order LSR
Topics69,252
Posts674,577
Members10,531
A65L exhaust pushrods #737788
06/05/18 8:28 pm
06/05/18 8:28 pm
Louisiana
GeauxTwins Offline OP
Louisiana
I'm new to the forum,
Last week I replaced my 4 tappet adjusters on my 70 A65T (old ones tip worn out and gaps difficult to set)
I noticed (after adjusting the 4 gaps correctly) with the exhaust valves in close position there is a side play between to tip of the exhaust pushrods and the exhaust rocker balls.
That side play is feeling the same for R and L
Didn't notice a side play with the inlet valves in close position
Never noticed such play on my Triumphs
So, should I replace those two exhaust rods or live with it keeping an eye on it?
Trophy 67, A65T 70, T100C 70, TR6R 71, Daytona 72
Re: A65L exhaust pushrods [Re: GeauxTwins] #737792
06/05/18 9:22 pm
06/05/18 9:22 pm
Lancaster, California
C.B.S Offline
Parts Dealer
C.B.S  Offline
Parts Dealer
Is this "side play" from the thackery washers or the ball is moving in the cup? Are the push rods new or original? As long as the tappets are contacting in the center of the valve tips I don't see how there would be any problems. Nothing is misaligned... I suppose if the side play is excessive there could be a problem. Perhaps BSA did this to take up any misalignment issues
- Kyle
Re: A65L exhaust pushrods [Re: C.B.S] #737796
06/05/18 9:49 pm
06/05/18 9:49 pm
Louisiana
Louisiana
Thanks Kyle,
No misalignment, all perfect,
Yes, side play between the exhaust pushrod cup and rocker ball on R and L
I guess the cups are worn out
I got that bike 7 years ago, put + 10,000 miles on it
PO rebuilt the engine (I did the rest) but no clue if he replaced the rods
Re: A65L exhaust pushrods [Re: GeauxTwins] #737800
06/05/18 10:13 pm
06/05/18 10:13 pm
C.B.S Offline
Parts Dealer
C.B.S  Offline
Parts Dealer
Try a new set, too bad Kibblewhite isn't making A65 push rods...
Re: A65L exhaust pushrods [Re: GeauxTwins] #737823
06/06/18 2:38 am
06/06/18 2:38 am
Mark Z Offline
Mark Z  Offline
How much side play? Is this with the cam backed off (i.e., so there is no tension on the pushrod), or with the play taken up? I would expect a LITTLE side play with the cam backed off, especially if you haven't yet taken up the adjuster to the proper clearance.
However, if there's a noticeable difference between the intake and exhaust pushrods, under the same conditions and with valve clearances set, then I guess something is wrong.
Re: A65L exhaust pushrods [Re: GeauxTwins] #737829
06/06/18 4:47 am
06/06/18 4:47 am
ca, us
DMadigan Offline
DMadigan  Offline
ca, us
Measuring the rocker pins, pushrods and tappets, the spherical ends are 5/32" radius. You should have minimal lateral movement between the pushrod and either end.
A65 CrMo tubular steel pushrods with tool steel ends can be sourced if there is interest.
Re: A65L exhaust pushrods [Re: Mark Z] #737868
06/06/18 4:10 pm
06/06/18 4:10 pm
Louisiana
Louisiana
Side play feeling like + 1/32 on both exhaust pushrod cups with the play taken off
Yes, should get a new set if that side play abnormal
What kind? Standard alu? CrMo (SRM) as DM recommends? MAP ones?
Thanks to all
Re: A65L exhaust pushrods [Re: GeauxTwins] #737903
06/06/18 10:41 pm
06/06/18 10:41 pm
Aus
NickL Offline
NickL  Offline
Aus
Use standard ones. If you change to moly or similar you will need to run different clearance settings due to expansion rates etc.
I would be looking for a reason why they wore out. Poor lubrication? crap oil type? I've never known anyone needing to replace them.
(If you are racing you may gain 0.1 BHP by fitting steel ones.)
Bring in the 'Comfy Chair'
Re: A65L exhaust pushrods [Re: NickL] #737997
06/07/18 10:26 pm
06/07/18 10:26 pm
Louisiana
Louisiana
Good point Nick about a different metal expansion,
Will get new std pushrods then,
Lubrication great around the rockers (Castrol 20W50),
Re: A65L exhaust pushrods [Re: GeauxTwins] #738003
06/07/18 11:02 pm
06/07/18 11:02 pm
gavin eisler Offline
I dont think anything is wrong here.
"I noticed (after adjusting the 4 gaps correctly) with the exhaust valves in close position there is a side play between to tip of the exhaust pushrods and the exhaust rocker balls."
If you give the exhaust 0.010 " clearance there will be a little shake at the push rod end unless you take up the play by pushing on the rocker end.
at 0.008" inlet this will be less noticeable, try moving the exhaust setting in to 8 and see if it still feels weird , just for the hell of it, go to 10 once you are happy.
Re: A65L exhaust pushrods [Re: gavin eisler] #738365
06/11/18 12:32 pm
06/11/18 12:32 pm
West Yorkshire
West Yorkshire
+1
If you set your exhaust tappet clearance when the inlets are fully open (and vise versa) then you will have the respective .010" and .008" clearance when the valve is fully closed, you should be able to freely spin the pushrod or rattle it to a small extent.
Re: A65L exhaust pushrods [Re: Allan Gill] #738470
06/12/18 2:51 am
06/12/18 2:51 am
Mark Z Offline
Mark Z  Offline
+1
Agree, .010" clearance (exhaust) will allow more side to side play than .008" (intake). However, the correct procedure is to set each clearance when the opposite exhaust or intake valve is fully open. At no point are both intakes or both exhausts fully open.
Re: A65L exhaust pushrods [Re: GeauxTwins] #738557
06/13/18 12:56 am
06/13/18 12:56 am
Aus
NickL Offline
NickL  Offline
Aus
Correct maybe but i always adjust clearances,,,,,, exhaust just opening, do inlet,,,,, inlet just closing, do exhaust. (same cylinder)
You may find it helps with the a65 top end rattle.
Re: A65L exhaust pushrods [Re: GeauxTwins] #738571
06/13/18 4:10 am
06/13/18 4:10 am
Louisiana
Louisiana
Hi Guys, thanks all for the advices. Sorry for no reply.
Little Rock last weekend till today, Houston till Friday then driving back home.
Will open rocker cover this weekend to re-check, re-adjust exhaust to 0.008 and see how is the side play.
I got the new pushrods too
Yes I adjusted gaps with the correct procedure
Re: A65L exhaust pushrods [Re: GeauxTwins] #738596
06/13/18 12:12 pm
06/13/18 12:12 pm
West Yorkshire
West Yorkshire
Can’t understand why people insist on using smaller gaps. There is an article somewhere stating that for more performance to set tappers to 10 inlet and 12 exhaust, the 8 and 10 were settings to quieten it down a little. Unless you have an aftermarket cam that states differently I’d be inclined to leave that exhaust valve at 10 thou.
I used to run 10 thou on inlet and exhaust, it made a slight difference to performance as even that tiny adjustment would alter the cam timing. The timing of the closing of the valve being the part most significant. I tried smaller gaps and it made the bike less tractable at lower revs and harder to tick over.
Re: A65L exhaust pushrods [Re: GeauxTwins] #738648
06/13/18 10:37 pm
06/13/18 10:37 pm
Aus
NickL Offline
NickL  Offline
Aus
The performance gains from having these things rattling like tins of nails or running reasonably quietly, is bugger all, if done properly.
Most of what i'm doing is compensating for wear on the cam/followers and bushes, the actual valve clearance is 8+10 at it's operating point.
You would need to close the clearances down a silly amount to make any real difference to power on these things, a thou or two is naff-all.
Re: A65L exhaust pushrods [Re: GeauxTwins] #739069
06/18/18 11:19 am
06/18/18 11:19 am
Louisiana
Louisiana
Okay, this weekend I replaced the exhaust pushrods with a new set and here is what I found:
First, as Allan recommended with the old rods in place I decreased the gap to 0.008 from 0.010: still some important side play.
I went down to 0.006 and still some play.
Took the rods out and compared with the new set:
New ones longer by 1mm
Head length: old 15 mm / new 14 mm
Head external diameter: old 10.0 mm / new 9.5 mm
Cup diameter: old 8.3 mm / new 8.0 mm (5/32") - visually clear old rods have deeper cups - didn't have on hand a 5/32" ball for comparing how it sinks in.
No clue if the old rods are original or not - no marking on them
Anyway, no more side play with the new set @ 0.010" exhaust gap
Will post something interesting concerning the tappet adjusters on my second post.
