KarlB
KarlB
Kent
Support Your #1 Forum
Buy BritBike's staff a coffeeStill here since 1996.. Click here to buy BritBike staff a coffee.
44 registered members (Al de Haas), 373 guests, and 729 spiders.
brennan devine, sivaraj, LarryL, chickin, Hill Easterwood
10612 Registered Users
franko 124
koan58 78
Mori55 71
reverb 70
NickL 61
830,984 mail-order LSR
Topics67,834
Posts671,990
Members10,612
B25 rear wheel removal #738255
06/10/18 3:58 pm
06/10/18 3:58 pm
Canada
Alexp Offline OP
Alexp  Offline OP
Canada
Should the axle just slide out the right side after unscrewing? The axle isn’t unscrewing anymore, yet it refuses to come out. Any tips would be great thanks!!
Alex
Re: B25 rear wheel removal [Re: Alexp] #738258
06/10/18 4:52 pm
06/10/18 4:52 pm
Yes it should slide out, it can rust and then it seizes in the bearing inners within the hub. The whole wheel may need to come out so you can force the axle out of the hub after the brake has been taken off. Always wipe some grease on it when reinstalling to sto repeats.
Re: B25 rear wheel removal [Re: Alexp] #738552
06/12/18 11:15 pm
06/12/18 11:15 pm
Canada
Alexp Offline OP
Alexp  Offline OP
Canada
Thanks Kommando! If it unscrews without issue, what’s the axle actually rusted to? Sorry, I’m trying to get an image in my mind to figure out what it’s actually rusted to!!
Thanks so much again!
Alex
Re: B25 rear wheel removal [Re: Alexp] #738574
06/13/18 5:24 am
06/13/18 5:24 am
The 2 bearings inside the hub have a spacer in between them, the axle is seized inside and the spacer is free to turn.
https://m.youtube.com/watch?v=kQK2YAD5OCQ
Re: B25 rear wheel removal [Re: Alexp] #738640
06/13/18 9:43 pm
06/13/18 9:43 pm
Canada
Alexp Offline OP
Alexp  Offline OP
Canada
Thank you!! Working on this tomorrow!!! smile
Alex
Re: B25 rear wheel removal [Re: Alexp] #738899
06/16/18 3:59 pm
06/16/18 3:59 pm
Alex: I have a slightly different opinion. Given that all the bits are pressed together through the center of the wheel when the axle is threaded in, if you are able to unthread the axle so that it has come part way out it must be coming through all center the bits because those bits cannot move laterally. I think is just tight but free to be drawn out with some effort.
Re: B25 rear wheel removal [Re: Alexp] #738913
06/16/18 5:10 pm
06/16/18 5:10 pm
Canada
Alexp Offline OP
Alexp  Offline OP
Canada
Hi Gordo!!
The problem turned out to be the speedometer gearbox was on there super tight. I greased the axle, and managed to remove it by lightly tapping it down the centre axle using a hide mallet. Re-greased everything and it all comes apart much easier!!
Next step is to learn how to replace a tire while not ruining 3 brand new tubes (grumble grumble).
Alex
Re: B25 rear wheel removal [Re: Alexp] #738968
06/17/18 7:48 am
06/17/18 7:48 am
Stuart Offline
Stuart  Offline
Hi Alex,
Here, local garages and tyre shops fit tyres they supply for free, £15 for a tyre you supply. Given decent tubes are £15 ...
Re: B25 rear wheel removal [Re: Alexp] #738997
06/17/18 4:56 pm
06/17/18 4:56 pm
Canada
Alexp Offline OP
Alexp  Offline OP
Canada
Thanks Stuart!! It’s 50 dollars a wheel here.
Re: B25 rear wheel removal [Re: Alexp] #739000
06/17/18 5:26 pm
06/17/18 5:26 pm
Ouch! $15 a wheel labor here to change a tire and tube. It would pay you to upgrade your tire-changing equipment!
You should have to pass a drug test to receive a welfare check... because I had to pass one to earn it for you.
Re: B25 rear wheel removal [Re: Alexp] #739062
06/18/18 8:18 am
06/18/18 8:18 am
BSA_WM20 Online content
BSA_WM20  Online Content
Hi Gordo!!
Alex
Get yourself a Breezer tyre tool .
Photos & instructions about 1/2 way through this thread mounting new tyres on 70 A65L
Some where on the web there was instructions for making one from some alloy rod.
Re: B25 rear wheel removal [Re: Alexp] #739080
06/18/18 1:54 pm
06/18/18 1:54 pm
Found it
Dans bike repairs page.
I had a flat on the M20 on a club run some long time ago & another member popped myself & the wheel into his chair to go home & replace the tube while the rest of the group had a long lunch stop.
His eyes popped out of his head when he saw the tyre off, tube replaced & tyre back on before the kettle had boiled for our cuppa.
He borrowed it and made some slightly longer ones , about 12" against the 8.5" original . I tried one of his latter on and despite what I had been telling girls for decades ,the extra few inches did make a big difference
HE also did a bigger version again in steel this time then made 2 steel rings welded together at right angles so one went over the handle end while the other end slipped over the axel thus making tapping the tyre off even easier
But even with the short original, you will never ever pinch a tube again.
And another variation on the same theme @ $ 40 ( inc postage ) it is about 1.5 x a tube price Stubby on amazon
Re: B25 rear wheel removal [Re: Alexp] #739436
06/22/18 12:26 am
06/22/18 12:26 am
Canada
Alexp Offline OP
Alexp  Offline OP
Canada
You’re amazing thanks. Getting one very soon! In the meantime, I’m glad I did take it in, as they found a defect with the front tyre. Whew!
Alex
Re: B25 rear wheel removal [Re: BSA_WM20] #740190
06/29/18 1:03 am
06/29/18 1:03 am
kevin roberts Online content
kevin roberts  Online Content
i was intrigued. i went to eBay and found this:
it arrived today and appears never to have been used.
my old tire spoons from the reign of charlemaigne are somewhat worn. i shall give this a try.
Re: B25 rear wheel removal [Re: Alexp] #740217
06/29/18 8:05 am
06/29/18 8:05 am
If you can not read the instrucion that were posted I can rescan them and PM them to you.
The one thing omitted from the instructions is LOTS OF LUBE.
When doing a rear, work on the plain side . not the sprocket side cause you can not get it flat enough with the sprocket in the way.
Like a tyre changing machine the tool need to be held so it is at a radius position.
Pull back with the hand holding it so the grove rubs on the outside of the rim and smack it hard.
I found small lump hammer worked really well
Like all new tools takes a litle getting used to but way ease than levers and far less likely to damage the tyre or rim.
Re: B25 rear wheel removal [Re: Alexp] #740234
06/29/18 2:31 pm
06/29/18 2:31 pm
no, your instructions are clear. i copied them down in case the world ends. i have some bald tires to swap out soon, so i'm curious how it works.
sometimes a good idea just never catches on for murky reasons. maybe this was one of them.
Re: B25 rear wheel removal [Re: Alexp] #740295
06/30/18 9:06 am
06/30/18 9:06 am
The motorcycle industry changed over to cast wheels almost overnight.
They are about 1/2 the price to make but could be sold for a lot more and of course opened the door to tubeless motorcycle tyres
The makers of tyre changing machines suitable for motorcycles were caught flat footed by the change and it took quite a while for machines that did not distort the soft alloy rims to hit the market.
The Breezer was the answer, particularly for bike shops where scratching the wheel during tyre change could result in warranty claims.
I was good friends with Alan Bradshaw at the time ( the privateer who beat all of the worlds factory 125 teams at Phillip Island ) who was spares manager at the biggest Yamaha dealer in Sydney
The RD 250/350 took Australia by storm but they were fitted with the Japanese Dunlops so most new bikes got shod with Michalens or Parillis much more suitable for the pocket racers.
It was he who introduced me to th Breezer which was the tool they used in the workshop.
Honda then followed up by fitting the pressed / cast alloy wheels to their entire range save the step through & 750/ 4.
A few years latter the Alloy tyre changing machines came out and as the early alloys all had deep rims, most riders took their wheels to the shop for fitting.
Al set up a stand alone motorcycle tyre shop in order to amortise the cost of the new machine and even the competing shops took their wheels there for tyre changes.
Thus the market dried up just as quick as it was created and being that breezers needed a hammer , they did not become part of the riding tool kit.
Back when I was substantially stronger than now I could grip the tool and a spoke in one hand and work it around the rim to remove the tyre, but since then I have learned how to adjust the clutch a lot lighter so the left hand withered.
