The Bonneville Shop
KC in S.B.
KC in S.B.
Santa Barbara, California
36 registered members (AML), 247 guests, and 393 spiders.
SuzyTice, Steve Funke, JD8, John Rowley, Zoot
10531 Registered Users
franko 92
Lannis 80
NickL 68
787,674 mail-order LSR
Topics69,242
Posts674,479
Members10,531
A65 rockers, fitting tip. #738248
06/10/18 1:40 pm
06/10/18 1:40 pm
gavin eisler Offline OP
One of my least favourite jobs is refitting the exhaust rockers after a head torque check.
Today I tried a new to me method, I fitted the timing side rocker and thackeray washers first, lined this up with the spindle so all was Concentric,
removed the spindle leaving TS assembly in position , then fitted drive side assembly , got it all lined up and the spindle popped through with no snags. Didnt drop anything. No cursing, easiest method I have tried.
Previously I fitted the DS first, then struggled to fit the TS as the DS washers would shift with all the finagling, maybe I just got lucky this time, will be doing this again soon, lets see if it works twice.
Re: A65 rockers, fitting tip. [Re: gavin eisler] #738327
06/11/18 5:12 am
06/11/18 5:12 am
ca, us
DMadigan Offline
DMadigan  Offline
ca, us
You might find it easier if you make up a dummy spindle slightly undersize with a champher on the end to centralize the rockers and washers. That will align everything except the last washer.
Re: A65 rockers, fitting tip. [Re: gavin eisler] #738391
06/11/18 5:20 pm
06/11/18 5:20 pm
thats a good idea, I think I am due one after 30 odd years of ownership/ messing around.
Re: A65 rockers, fitting tip. [Re: gavin eisler] #738425
06/11/18 9:30 pm
06/11/18 9:30 pm
Louisiana
GeauxTwins Offline
GeauxTwins  Offline
Louisiana
I'm not familiar yet with the BSA set up but as DM's idea for my Triumphs I use an old spindle with all the champhers grinded smooth for aligning everything then I push in the spindle which pushes out the old one keeping everything in place.
Trophy 67, A65T 70, T100C 70, TR6R 71, Daytona 72
Re: A65 rockers, fitting tip. [Re: gavin eisler] #739012
06/17/18 9:46 pm
06/17/18 9:46 pm
Second time around my tip failed, dis placed the TS while fiddling with the DS, oh that it was as simple as a Triumph, the BSA wont permit displacing one spindle with another.
i did find that the wee fork for crab meat picking is ideal for chivvying the wee bits around.
Re: A65 rockers, fitting tip. [Re: gavin eisler] #739024
06/18/18 12:23 am
06/18/18 12:23 am
Aus
NickL Offline
NickL  Offline
Aus
You'll find the assembly much easier with spacers as opposed to the thackery washers.
You've now got a lathe so away you go. you'll still need the thin thrusts at the centre but
make up the outer spacers from a bit of bar giving a few thou clearance it does make it
easier to assemble, the thackerys' always get tangled with the outer thrusts etc.
Bring in the 'Comfy Chair'
