The Bonneville Shop
triton thrasher
triton thrasher
26 registered members (Alan_nc), 264 guests, and 450 spiders.
SuzyTice, Steve Funke, JD8, John Rowley, Zoot
10531 Registered Users
franko 96
Lannis 81
NickL 66
789,359 mail-order LSR
Topics69,252
Posts674,577
Members10,531
69 A65 Clutch Cable Adjustment #737612
06/04/18 2:26 am
06/04/18 2:26 am
Oceanside California
mrcarb Offline OP
mrcarb  Offline OP
The adjustment where the clutch cable goes into the hand lever on my 69 Lightning is at an end and the adjuster sleeve barely goes into the handle assembly. If there was an adjustment in the cable this would allow the adjuster sleeve to go into the handle assembly. However the clutch operates just fine.
Would anyone know of a fix for this instead of say removing a 1/4" or so from the inner cable?
Thanks.
Re: 69 A65 Clutch Cable Adjustment [Re: mrcarb] #737630
06/04/18 9:02 am
06/04/18 9:02 am
gavin eisler Online content
gavin eisler  Online Content
do you have the correct assembly on the motor end ?,
parts 35, 36 , 37 on this diagram https://www.draganfly.co.uk/index.php/bsa/bsa/a50-a-a65/1969/category/318-gearchange-mechanism
the cable nipple engages in a small spring loaded connector that links the cable to the clutch op arm, supposedly to allow a cable change without opening up the case, if this part is missing your cable ( ie cable connects directly to op arm) will appear to be the wrong size. If the connector is there then shortening the cable inner would seem to be the solution.
