injunmort
injunmort
sugarloaf ny
25 registered members (Alan_nc), 193 guests, and 437 spiders.
10257 Registered Users
Stuart 77
Lannis 60
TBolt72 46
609,510 mail-order LSR
Topics67,125
Posts651,425
Members10,257
A65 Lightning Parts #737143
05/30/18 10:28 pm
05/30/18 10:28 pm
Tampa Fl.
737Captain Offline OP
Tampa Fl.
I’m starting to freshen up a 1966 Lightning but having trouble sourcing some of the missing or damaged parts and was curious if anyone had any recommendations for potential suppliers.
Specifically battery tray fasteners and parts
68-4575
68-4568
46-0004
68-4562
Also my exhausts could use replacement, mine have a tubular lug on each one that connects with a rod. All the ones I see have either a balance pipe or strap. Ideas anyone?
Any help is appreciated.
I'm not young enough to know everything.
Heavy Equipment Operator
T150V
Velocette Thruxton
Norton Commando
Honda ST1300
BMW 1200GSA
Honda Grom
Honda XR75
Triumph Trailblazer
Honda Cub
BSA A65 Lightning
Re: A65 Lightning Parts [Re: 737Captain] #737151
05/30/18 11:05 pm
05/30/18 11:05 pm
Texas, USA
Ray Elliott Offline
Ray Elliott  Offline
Texas, USA
Check with www.britishonly.com. They have a complete BSA parts supply. NOS & used. When you search for a part# on their site use 01- before the BSA #.
Ray Elliott
Re: A65 Lightning Parts [Re: 737Captain] #737156
05/30/18 11:20 pm
05/30/18 11:20 pm
gavin eisler Online content
gavin eisler  Online Content
Whatever you do , keep the old exhausts, the balance pipe type are from 70 onwards, the pipe does help to keep the pipe in the ports, but the rod or strap does the same job.
Re: A65 Lightning Parts [Re: 737Captain] #737215
05/31/18 3:29 pm
05/31/18 3:29 pm
Originally they would have had a flat bar strap, some repop pipes have the tubes as you mention, it pulls the pipes in well but depends if your wanting originality. Armours do about the best downpipes on the market but not always a good fit and often need shortening at the silencer end. Some pipes are a thing gauge of steel and go golden very quickly (unfortunately these are about the best shaped and unlike armours have the correct tie bar lugs) you could always have those ceramic coated on the inside which will help to stop the pipe going gold.
Re: A65 Lightning Parts [Re: 737Captain] #737249
05/31/18 8:49 pm
05/31/18 8:49 pm
West Virginia, United States
Beach Offline
Beach  Offline
I've has good luck with Brituro pipes and mufflers. Nice fit and fairly thick.
1974 Norton Commando
1966 Lightning
1965 Lightning Rocket
1966 Norton Atlas
1967 Norton Atlas
1948 Panhead
Re: A65 Lightning Parts [Re: 737Captain] #737414
06/02/18 2:24 pm
06/02/18 2:24 pm
Tampa Fl.
Tampa Fl.
My pipes are still sound, just not very pretty. Is there a case to have them rechromed?
T150V
Velocette Thruxton
Norton Commando
Honda ST1300
BMW 1200GSA
Honda Grom
Honda XR75
Triumph Trailblazer
Honda Cub
BSA A65 Lightning
Re: A65 Lightning Parts [Re: Ray Elliott] #737415
06/02/18 2:25 pm
06/02/18 2:25 pm
Tampa Fl.
Tampa Fl.
Thank you Ray, I’ll give them a try.
T150V
Velocette Thruxton
Norton Commando
Honda ST1300
BMW 1200GSA
Honda Grom
Honda XR75
Triumph Trailblazer
Honda Cub
BSA A65 Lightning
Re: A65 Lightning Parts [Re: Ray Elliott] #737417
06/02/18 2:40 pm
06/02/18 2:40 pm
Tampa Fl.
Tampa Fl.
Ray, I found what I needed, thank you so much.
T150V
Velocette Thruxton
Norton Commando
Honda ST1300
BMW 1200GSA
Honda Grom
Honda XR75
Triumph Trailblazer
Honda Cub
BSA A65 Lightning
Re: A65 Lightning Parts [Re: 737Captain] #737451
06/02/18 6:47 pm
06/02/18 6:47 pm
Mark Z Offline
Mark Z  Offline
I would say there is a case for having the original header pipes re-chromed, if you have a good source for the chroming. (I say that because cosmetic chroming has been virtually regulated out of existence in NYS - maybe better down your way.) Then there are no worries about fit. I bought what were supposed to be good quality header pipes a while back, and they were, as far as thickness and finish, but they didn't quite fit between the head ports and the lugs at the bottom of the frame - that is, the curve needed to be relaxed a bit, which is no mean feat.
I think the flat strap is more attractive than the rod. If the bosses on the header pipes are the same, I would go with the flat strap. Easy to make out of SS, just a piece of flat stock with two holes in it, no plating required.
Another source for used BSA parts is Skinner's Motorcycles in Auburn, Alabama.
Re: A65 Lightning Parts [Re: 737Captain] #737509
06/03/18 8:14 am
06/03/18 8:14 am
Lytham St. Annes, UK
Andy Carr Offline
Andy Carr  Offline
For the tie bar, I sourced a length of stainless rod, cut it to size and threaded each end. Add two stainless dome nuts and it looks good and does the job.
1973 Lightning
1966 Lightning
So lightning does strike twice.
Re: A65 Lightning Parts [Re: Andy Carr] #737598
06/04/18 12:16 am
06/04/18 12:16 am
Mark Z Offline
Mark Z  Offline
Oh, I guess then that the '66 header pipes are different from the '67s - sounds like the '66s have horizontal tubular lugs. So in that case you would have to go with a round rod. The '67s have drilled and tapped screw bosses pointing downward, to accept the mounting bolts for the flat bar.
Re: A65 Lightning Parts [Re: Mark Z] #737617
06/04/18 3:19 am
06/04/18 3:19 am
Beach Offline
Beach  Offline
Original 1966 uses tie bar and pipes with threaded bosses.
1966 Lightning
1966 Norton Atlas
1967 Norton Atlas
1948 Panhead
Re: A65 Lightning Parts [Re: 737Captain] #737645
06/04/18 1:39 pm
06/04/18 1:39 pm
Ewing. NJ
E
edunham Offline
edunham  Offline
E
Ewing. NJ
My '66 Spitfire (late in the year cause it has the matching frame and engine numbers) has the drilled and tapped bosses for a flat piece. I believe they are the original pipes.
Ed from NJ
