The Bonneville Shop
KC in S.B.
KC in S.B.
Santa Barbara, California
33 registered members (AML), 243 guests, and 380 spiders.
SuzyTice, Steve Funke, JD8, John Rowley, Zoot
10531 Registered Users
franko 92
Lannis 80
NickL 68
787,674 mail-order LSR
Topics69,242
Posts674,479
Members10,531
Page 2 of 2 1 2
Re: 48' B31 head repair? [Re: Magnetoman] #736908
05/29/18 7:55 am
05/29/18 7:55 am
OZ
Triless Online content
Triless  Online Content
OZ
MM, I don't think "Stilsons" or multi grips was meant here. A ring spanner with a segment cut out is known as a flare nut spanner. The cut out gives access over the pipe to enable the business end to be located on the nut that locates the assembly (as in a brake pipe, fuel pipe, etc.) onto a union.
Re: 48' B31 head repair? [Re: Triless] #736952
05/29/18 3:05 pm
05/29/18 3:05 pm
Magnetoman Online content
Magnetoman  Online Content
Originally Posted by Triless
MM, I don't think "Stilsons" or multi grips was meant here. .
On re-reading the post it seems you're right. However, 'pipe wrench' and 'flare nut wrench' are not interchangeable terms even in popular usage. If you google images of 'pipe wrench' in the U.S. you will find many pages of "Stilsons" without a single flare nut wrench. Also, flare nut wrenches (spanners) usually have six flats as well as considerably thicker cross sections than ring spanners, which almost always have 12 points. So cutting a gap in a ring spanner will give you a weak substitute for a flare nut wrench that is likely to spread and round off a nut that was on so tight that an open-ended spanner was insufficient.
Re: 48' B31 head repair? [Re: dean toensing] #737533
06/03/18 2:50 pm
06/03/18 2:50 pm
Northern Ireland
B31 Ally Offline
B31 Ally  Offline
Northern Ireland
Any B31 head studs I used to work on I get two open end spanners or three if there is enough hexagon left to fit them on to and use them all at once on the stud. Different makes of spanners sit at slightly different positions in you hand when your loosening the stud but it works for me every time and I haven't had one slip yet. Early B31's had a smaller hexagon on the studs than the later ones. What I eventually did was get some 5/8 thick steel plate and made two spanners for the head studs, milling the jaw gap was crucial to a good fit on the stud but it worked a treat.
Re: 48' B31 head repair? [Re: dean toensing] #737537
06/03/18 3:38 pm
06/03/18 3:38 pm
Bolton Lancs UK
Andy Higham Offline
Andy Higham  Offline
Bolton Lancs UK
On my B31 fitted with Goldie head and barrel I drilled the head all the way through and fitted through studs with nuts on top of the head. OK not much use to you but it is a more satisfactory arrangement
BSA B31 500cc "Stargazer"
Greeves 200cc "Blue Meanie"
Greeves 360 Challenger
Jawa 500cc "Llareggub"
'35 OK Supreme
'36 OK Supreme
Re: 48' B31 head repair? [Re: dean toensing] #737856
06/06/18 1:11 pm
06/06/18 1:11 pm
boerne texas
dean toensing Offline OP
boerne texas
Used the double wrench technique, worked great!
Page 2 of 2 1 2
