SReppel
SReppel
Abbeville, Louisiana
75 registered members (68 royalstar tony), 458 guests, and 737 spiders.
Simon J, Hwallman, Fumi, brennan devine, sivaraj
10615 Registered Users
franko 118
koan58 97
Mori55 82
reverb 65
NickL 58
832,892 mail-order LSR
Topics67,864
Posts672,276
Members10,615
cam shaft quill broken. :( #736388
05/24/18 2:24 am
05/24/18 2:24 am
Smackinthemiddle, NJ
rocketscientist Offline OP
52 MAC woes continue;
I pulled off the timing cover, to remove the magneto to send it off to have the sparks reinstalled. All was fine, until I noticed the oil quill on the cam pinion spindle was broken off, and left sticking in the timing cover.
In a perfect world, I would removed the cam and replace the shaft. However, that shaft is an interference fit, and would be a PITA to do, maybe impossible, with the engine still in the frame in the full up bike.
What is a lubrication work around for the cam shaft??????????
Option 1: I was thinking that the retaining nut outer edge on the steady plate is nearly flush with the oil supply boss in the cover. Cut an O-ring to fit on the face of the nut. When the cover is put on, the O-ring would compress against the face of the oil
Option 2: grind off the remaining quill piece from the cam shaft. make another quill to jbweld into the end of the shaft, to extend into the oil boss on the cover.
Option 3: cry and sell the bike.
Support your #1 Velocette Forum
Velocette Motorcycles on e-Bay UK, Velocette motorcycles on e-Bay North America
Re: cam shaft quill broken. :( [Re: rocketscientist] #736485
05/25/18 12:23 am
05/25/18 12:23 am
Australia
Joolstacho Offline
Joolstacho  Offline
Australia
I suppose the only way it could break off is mismatched timing cover/timing CC half. Any ideas how it broke off?
Option 1 is good, that's an 'known' mod, o-ring to ensure oil doesn't 'escape'.
Option2 good BUT I personally wouldn't use JB Weld for something like this 'mission-critical' application, -It's just an epoxy glue after all and there's very little surface area for the glue to fix.
unless you can accurately drill deep into the shaft.
Maybe cut it flush, then drill in maybe 1/8", and silver-solder in a short length of steel or DuBro brass tubing, - maybe that'd do it?
I've never pulled one of those camshaft spindles, but seems to me if you could fabricate a puller (using the existing thread on the spindle), I don't see why, with the heat spanner, it wouldn't extract.
A tricky job though, agreed. Though possibly one of those jobs (like extracting the oil pump) that looks harder than it actually is once you've done it once.
(BTW, especially need to watch out for the lower quill jet that feeds the crank,
because if it's not correctly aligned and adjusted, it wears, breaks off and you lose oil pressure to the big end).
Sympathy. Sorry I don't know of an easy fix.
Yes cry by all means, (but don't sell!)
Re: cam shaft quill broken. :( [Re: rocketscientist] #736603
05/26/18 1:05 pm
05/26/18 1:05 pm
I'm going to drill and set a new quill into the shaft. 3/16 OD should work. That's .1875 the quills measure slightly under at .185. I'll carefully drill in and set it with loctitle bearing/sleeve retainer. Its no load, just heat and vibration. I won't walk into the shaft, only towards the case IF it moves.
How did it break? prob. when the cover was removed, earlier in its life....or possibly by me? don't know. Just when I opened it, the quill was stuck in the cover. when I tried the quill into the cover, it was a tight fit....maybe it cracked on assembly 60 yrs ago!!!!!! and was fine over that period. who knows.
Re: cam shaft quill broken. :( [Re: rocketscientist] #736606
05/26/18 1:35 pm
05/26/18 1:35 pm
Australia
Joolstacho Offline
Joolstacho  Offline
Australia
Yes, good solution. I wonder how hard that shaft is.
Re: cam shaft quill broken. :( [Re: rocketscientist] #737203
05/31/18 1:00 pm
05/31/18 1:00 pm
Ontario , Canada
RGSROB Offline
RGSROB  Offline
Ontario , Canada
if you are successful drilling the cam spindle,say la large enough hole for oil to pass through, could you just fit a quill into the timing cover
Re: cam shaft quill broken. :( [Re: rocketscientist] #737861
06/06/18 2:45 pm
06/06/18 2:45 pm
Used a diamond grinder bit to start the hole where the quill was broken. Once in approx. 1/16....the shaft is softer. the oil passage acts as a pilot hole, so I could hand drill . I'm going in with a 3/16", to a dept of 1/4" only. I don't want to weaken where the threads end and the shaft begine. The steady plate nut bears down at that point.
Now the the hole is drilled, I'm fitting the new quill. Had to sand the OD slightly, and will bearing retainer it in place. The outer part of the quill is machined down slightly under 1/16 . Picts to follow.
Re: cam shaft quill broken. :( [Re: rocketscientist] #739751
06/24/18 10:08 pm
06/24/18 10:08 pm
quill repair. done
