The Bonneville Shop
triton thrasher
triton thrasher
26 registered members (Alan_nc), 264 guests, and 450 spiders.
SuzyTice, Steve Funke, JD8, John Rowley, Zoot
10531 Registered Users
franko 96
Lannis 81
NickL 66
789,359 mail-order LSR
Topics69,252
Posts674,577
Members10,531
BSA A65 Gearbox Oil #554521
07/23/14 8:39 pm
07/23/14 8:39 pm
PA, USA
Rob Barker Offline OP
PA, USA
Hi All. I can't seem to get the search engine to come up with answer to this: What kind of oil should I put in the gearbox of my 1970 BSA Thunderbolt? I have a workshop manual that says SAE 50, but the only fifty weight oil I can find is Valvoline "Racing Oil". Is this what I need?
Also: I don't know what was in it before, but when I drained the old oil it came out all creamy and emulsified. I can't imagine that it was water, because it sleeps in a dry garage. If it's just air, is it the fault of the old oil or what?
Rob
Re: BSA A65 Gearbox Oil [Re: Rob Barker] #554530
07/23/14 9:18 pm
07/23/14 9:18 pm
Mark Z Offline
Mark Z  Offline
80-90W gear oil.
Yes, the milky look is from water. Some say that condensation alone can result in that much water in the oil. If not, then water getting in through the filler cap or through the clutch cable stanchion - there's supposed to be a rubber boot on that, which is often broken or missing. The filler cap gasket (fiber washer) may also be worn or missing. The water could have gotten in there a while ago... In any case, water in there for too long can ruin your tranny bearings. Good idea to change the oil at least once a year.
Re: BSA A65 Gearbox Oil [Re: Rob Barker] #554559
07/24/14 1:01 am
07/24/14 1:01 am
Does the '70 model have the nylon cap with the dipstick?
Those caps are vented, and can admit water. I end up changing my gear oil quite often.
Re: BSA A65 Gearbox Oil [Re: Rob Barker] #554563
07/24/14 1:30 am
07/24/14 1:30 am
Modern gear oil for me as well. In my humid climate oil turns milky even with bikes mostly inside after a year or two.
Re: BSA A65 Gearbox Oil [Re: Rob Barker] #554572
07/24/14 2:01 am
07/24/14 2:01 am
Stuart Offline
Stuart  Offline
Hi Rob,
Not specifically for an A65 but this was recommended by then British triples' dealer, builder and racer Phil Pick.
It probably is emulsified old oil but, if that synthetic has a disadvantage, it's a similar colour to emulsified old dino juice. whistle
Re: BSA A65 Gearbox Oil [Re: Rob Barker] #554711
07/24/14 7:40 pm
07/24/14 7:40 pm
PA, USA
PA, USA
It could have been condensation, but I would tend to doubt it. It does get pretty humid in my garage sometimes, though.
Yes, it has the nylon plug with the dipstick. And the boot around the clutch cable is intact and tight.
I'll try filling it with EP90 for now, but I may end up stripping the gearbox to see if everything's okay because I have a phobia about gearboxes seizing up while I'm dodging tractor-trailers on the interstate.
Re: BSA A65 Gearbox Oil [Re: Rob Barker] #555007
07/26/14 2:03 pm
07/26/14 2:03 pm
Mark Z Offline
Mark Z  Offline
I don't know if it's necessary to strip the gearbox - you can tell if the bearings are ok by turning the shafts with no load on them. For instance, for the high gear bearing, remove the drive chain and, with the gearbox in neutral, turn the gearbox sprocket with your fingers. For the mainshaft ball bearing, remove the clutch discs and turn the mainshaft. Or, if you have the inner timing cover off, you can turn the mainshaft from that end. The bearings should feel silky-smooth. If they feel "rocky", time to replace. This is of course after changing the oil.
I worked on a T140 with a bad high gear bearing, and you could feel that it was bad just rolling the bike across the floor in neutral.
Re: BSA A65 Gearbox Oil [Re: Rob Barker] #555238
07/27/14 10:44 pm
07/27/14 10:44 pm
Also check for any end play (lateral movement) on the main shaft. I just replaced main-shaft bearings because of this. Both 'rolled' just fine, but the center was loose. Made my clutch act funny, hard to adjust properly.
Re: BSA A65 Gearbox Oil [Re: Rob Barker] #555979
08/01/14 12:08 am
08/01/14 12:08 am
Victoria, BC
illingworth Offline
illingworth  Offline
Victoria, BC
Does old oil go bad sitting in a bottle? I just found an old half bottle of EP gear oil from about a dozen years ago. It was in the garage but the lid was on. Is it ruined?
jeremy
Re: BSA A65 Gearbox Oil [Re: Rob Barker] #557180
08/07/14 9:37 am
08/07/14 9:37 am
Cape Carteret, NC
Mr Mike Offline
Mr Mike  Offline
Cape Carteret, NC
I run gear oil in all the my BSA's. I rarely change it, just keep it topped off. The stuff lasts a long time. How often do you change it in the rear differential of your car?
Re: BSA A65 Gearbox Oil [Re: Rob Barker] #557497
08/08/14 11:15 pm
08/08/14 11:15 pm
Mark Z Offline
Mark Z  Offline
Gotta call you on this one, Mike, not a fair comparison. The rear end in your car is a much simpler and less delicate device than your BSA transmission. And for some reason, car diffs. don't tend to absorb moisture. Ever since I first saw milky oil come out of my gearbox, I change it at least once a year.
Actually, what did it for me was replacing the tranny bearings in a T140, ruined because of water in the gearbox. It was someone else's, so I didn't have to pay for the parts, and I did get a small stipend for my work, but I noted that this was not something I want to go through on my BSA, and it's completely avoidable, for the price of a pint or two of gear oil a year.
Re: BSA A65 Gearbox Oil [Re: Mark Z] #557514
08/09/14 6:25 am
08/09/14 6:25 am
Arlington, Massachusetts 02474
kurt fischer Online content
#irideslow
kurt fischer  Online Content
#irideslow
What Mark said, absolutely. I change the gear fluid on my Britbikes every year, it usually comes out a little milky despite dry storage and mostly dry running conditions.
Kurt
1968-70-71 Triumph TR6R Bitsa - 1969 Triumph TR6R - 1971 BSA A65L - 1973 Triumph TR5T
2005 Ducati MTS 1000S DS - 2012 Ducati Hyper 796 - 2014 Kawasaki ZX1000
Re: BSA A65 Gearbox Oil [Re: Mr Mike] #557621
08/09/14 9:49 pm
08/09/14 9:49 pm
Every 30,000 miles, got the 17mm hex key to prove it.
However, as Mark said, our gearboxes tend to admit water, especially with the vented nylon cap.
I think I've solved this problem by drilling a vent hole near the top of my inner cover and using an O ring on the cap. Still, I shall change the oil at least once per season.
Re: BSA A65 Gearbox Oil [Re: Rob Barker] #735546
05/16/18 3:00 pm
05/16/18 3:00 pm
Bethlehem, Pennsylvania
Benny Offline
Benny  Offline
Rob
Can anyone offer a Stateside Brand of Gear oil that would be preferred for my upcoming gear oil dump? I already use VR1 20W50 for engine oil changes, is it OK to use in the trans as well?
1970 A65T Thunderbolt SRM 750 Rework
Re: BSA A65 Gearbox Oil [Re: Benny] #735551
05/16/18 3:47 pm
05/16/18 3:47 pm
Stuart Offline
Stuart  Offline
Note "gearbox" and "trans[mission]" are two different things/compartments on a Britbike.
For the gearbox (the collection of gears in the compartment behind the crankcase), I use https://www.redlineoil.com/lightweight-shockproof.
For the (primary) transmission (the chain between the crankshaft and the clutch in the compartment beside the crankcase and gearbox), you have to use engine oil if the crankcase vents through the primary to atmosphere; if it doesn't, I use ATF.
Re: BSA A65 Gearbox Oil [Re: Benny] #735613
05/17/18 2:16 am
05/17/18 2:16 am
Mark Z Offline
Mark Z  Offline
Benny, read back through the thread. You want 80W90 gear oil in the gearbox. Any good brand will do.
Re: BSA A65 Gearbox Oil [Re: DavidP] #735625
05/17/18 8:00 am
05/17/18 8:00 am
Brisbane, Australia
BrizzoBrit Offline
BrizzoBrit  Offline
Brisbane, Australia
Good to hear. I was thinking of the same solution as my bike gets ridden in the rain all the time.
I tried the Redline, nice oil, I liked it, bit hard to get here, but when I did a strip I found it had emulsified badly without me knowing. In doing so had turned quite solid and was deposited inside the gearbox, covering the free surfaces where I couldn't really detect it until I stripped the gearbox. It was actually a bit like margarine in consistency. I went back to Castrol EPX (80/90W I think). It emulsifies if water gets in, but I've found it stays quite liquid and anything emulsified drains out OK it seems.
BSA 1969 A65F
BSA 1966 A65H
Triumph 1968 T120
Kawasaki A1R
& too many projects!
Re: BSA A65 Gearbox Oil [Re: Rob Barker] #735628
05/17/18 8:06 am
05/17/18 8:06 am
West Yorkshire
West Yorkshire
Sounds like it’s not breathing properly or getting hot enough.
Re: BSA A65 Gearbox Oil [Re: Rob Barker] #735645
05/17/18 12:06 pm
05/17/18 12:06 pm
new jersey usa
pushrod tom Offline
pushrod tom  Offline
new jersey usa
I like Valvoline or Mobil 75-90 Synthetic. PRT
Re: BSA A65 Gearbox Oil [Re: Rob Barker] #735693
05/17/18 7:23 pm
05/17/18 7:23 pm
New Jersey
F
Fetch Offline
Fetch  Offline
F
New Jersey
Rob, If you look at the service manual that calls for SAE 50 for the gear box, it also says the service schedule is something like 500 miles. Modern lubricants will hold up much better.
Re: BSA A65 Gearbox Oil [Re: Rob Barker] #735700
05/17/18 8:43 pm
05/17/18 8:43 pm
gavin eisler Online content
gavin eisler  Online Content
EP 90 gear oil will do fine. Change annually
Re: BSA A65 Gearbox Oil [Re: gavin eisler] #735726
05/18/18 4:16 am
05/18/18 4:16 am
Denver CO
Jerry Roy Offline
Jerry Roy  Offline
Denver CO
Can you find any of these?
Then Bob's your uncle.
ISO VG 220, AGMA 5, SAE 50, 90Wt. Oil
Home
Industrial & Manufacturing Lubricants
Industrial Lubricants By Weight
Description
ISO VG 220 oils (also known as AGMA 5 oils, SAE 50 oils, and 90WT Gear oils) are applicable in various industrial applications that include gearboxes, hydraulics, compressors, and slideways. Though these classification systems seem confusing and different, they all essentially stand for the same thing - a measured viscosity, or relative oil thickness. In most applications, these oil classifications are interchangeable - however, it is wise to consider OEM specifications to determine which exact lubricant specification is to be used.
ISO VG 220 oil has a midpoint kinematic viscosity of 220 mm2/s, also referred to as centistokes (cSt). The midpoint is derived by taking the average of both the minimum and maximum kinematic viscosities. In the case of ISO VG 220 oil, those numbers are 198 cSt and 242 cSt, respectively. SAE 50W oil has a minimum high-temperature kinematic viscosity of 16.3 mm2/s (cSt). AGMA 5 lubricants have a minimum viscosity of 198 mPa.s and a maximum viscosity of 242 mPa.s. These numbers refer to the standard testing mechanisms used to determine how much resistance to flow (i.e. viscosity) these oils demonstrate.
Re: BSA A65 Gearbox Oil [Re: Rob Barker] #735761
05/18/18 1:38 pm
05/18/18 1:38 pm
melbourne florida
bodine031 Offline
bodine031  Offline
melbourne florida
Hey Rob !!!! not rocket science, the Valvoline VR-1 goes in the engine oil tank, ATF(Type "F")or Harley Primary oil in the P-case, & Redline V-Twin Shock Proof in the gear box
Enjoy your Beeza!!!
Re: BSA A65 Gearbox Oil [Re: Rob Barker] #735804
05/19/18 12:14 am
05/19/18 12:14 am
Aus
NickL Offline
NickL  Offline
Aus
Any EP90 90 is fine.
Bring in the 'Comfy Chair'
