The Bonneville Shop
john toghill
john toghill
chatham kent UK
11 registered members (bsawood), 185 guests, and 377 spiders.
10528 Registered Users
franko 90
NickL 66
785,052 mail-order LSR
Topics69,219
Posts674,257
Members10,528
sprocket nut size? #735493
05/16/18 2:22 am
05/16/18 2:22 am
Smackinthemiddle, NJ
rocketscientist Offline OP
Whats the front chain sprocket nut size on the MAC ?? anyone stock a castlenut for it? I lost mine.....somewhere on the garage floor..... frown
Support your #1 Velocette Forum
Velocette Motorcycles on e-Bay UK, Velocette motorcycles on e-Bay North America
Re: sprocket nut size? [Re: rocketscientist] #735512
05/16/18 8:34 am
05/16/18 8:34 am
Australia
Joolstacho Offline
Joolstacho  Offline
Australia
Iron MAC or Alloy swing-arm MAC?
- Might make a difference.
My VM (late type gearbox obviously), mainshaft sprocket nut is 1/2" BSF (16TPI) Uses a 7/16" Whit spanner.
My two other mainshafts: Iron MAC and iron MSS / KSS use a 1/2" BSC 20TPI (yes, cycle thread but 20TPI not 26TPI) Nut is smaller than BSF type- measures 3/4" across the flats
Question is, did they change the thread type between the iron models and the Alloy models.
Hmm, another veloconundrum.
I reckon if you measure the TPI you'll be able to ID it, -check if your mainshaft uses cycle or BSF.
(Sorry it's not more conclusive, but, well, it IS a Velo after all!)
My original earlier type nut is a locknut type, not castellated or nyloc but slit, taper-threaded, (Dunno what you'd call it really).
Now I've re-read this, -you do mean the front gearbox mainshaft sprocket nut don't you?
Or did you mean the PRIMARY CHAIN front sprocket nut?
Re: sprocket nut size? [Re: rocketscientist] #735611
05/17/18 1:43 am
05/17/18 1:43 am
Alloy Head - Ridgid 1952! 1/2-20 US fine thread lock nut fits with no binding. ONly diff. is 60 vs 55 degree thread angle I believe.
Re: sprocket nut size? [Re: rocketscientist] #735614
05/17/18 2:55 am
05/17/18 2:55 am
Australia
Joolstacho Offline
Joolstacho  Offline
Australia
Hey who needs locknuts when you're putting UNF on a BSC!
(Just kidding Rocket-man) :-)
