The Bonneville Shop
john toghill
john toghill
chatham kent UK
13 registered members (bsawood), 194 guests, and 374 spiders.
10528 Registered Users
franko 90
NickL 66
785,052 mail-order LSR
Topics69,219
Posts674,257
Members10,528
A10 frame oddity #734532
05/08/18 8:48 pm
05/08/18 8:48 pm
bon Offline OP
bon  Offline OP
On the swingarm frame of my A10 which i am rebuilding, there is a large tapered hole. This is about an inch in diameter at its widest. It is where the toolbox top mounting bolt passes through the frame on the shock top mount area.
I can see no real reason for this feature and having looked online, don't see it on any other frames. I do not really care about it, but it is making fitting the lifting handle difficult to fit.
What was it for ? my best stab in the dark is sidecar mounting.
Re: A10 frame oddity [Re: bon] #734567
05/09/18 1:25 am
05/09/18 1:25 am
..... I'd like to see a pic of this!
Re: A10 frame oddity [Re: bon] #734568
05/09/18 2:49 am
05/09/18 2:49 am
Tridentman Offline
Tridentman  Offline
What year is the frame?
Re: A10 frame oddity [Re: bon] #734634
05/09/18 3:56 pm
05/09/18 3:56 pm
bon Offline OP
bon  Offline OP
Its a 1957-58 frame. I will try to post photos later on.
Re: A10 frame oddity [Re: bon] #734642
05/09/18 4:57 pm
05/09/18 4:57 pm
Tridentman Offline
Tridentman  Offline
The A7/A10 swinging arm frames were introduced in 1954..
For the first few years BSA recommended use of the plunger frame (which was still in production ) for sidecar use.
When the production of the plunger frames ceased (I am not sure of the year but maybe 1957/58) BSA then recommended use of the swinging arm frame for sidecar use.
When they did that I think that they added a sidecar fitting lug to the frame just under the nose of the seat and one within the pillion footrest frame loop.
So your frame may have been one of the swinging arm frames without the sidecar lugs fitted at the factory and someone has made his own attempt to get a sidecar fitting near the top of the suspension unit.
OR--of course--it may not have been anything to do with that at all!
